Front window rubber strip
Aybesea
- Drives: Polo 9Ns 1.2 AZQ 2003 Reflex Silver
Is there anyway of fixing the rubber strip that clears the water off the window when it goes down,as mine is not contacting very well so the water does not clear well,also is that all there is and not anything like some sort of felt futher down inside the black rubber strip.Or is it a case of buying new ones if i can get some.Info would be helpfull
Re: Front window rubber strip
I'd think that with age, that strip hardens and so you would need to replace it.
Aybesea
Thanks ,That is what i thought but decided to ask on here first to make sure .Probably have to take the door panel and top part off to get to it but will check first.
