GTI engine specs
alandbess
- Drives: Scirocco
GTI engine specs
Evening all....
I've seen a few bits and pieces floating around regarding the specs of the engine in the GTI. But I can't find that much info. I'm really interested because I'm considering a OBD plug in remap system from Revo or APR. Having looked at pictures of the engine, it's not the same as in the Golf GTI, so I'm wandering what's actually different.
Also, this will be my first DSG car, I know they're pretty bomb proof, but what are the thoughts on how much torque can be run through this 6 speed, wet clutch setup?
Thanks all
Alan
Sent from my SM-G935F using Tapatalk
Thanks all
Alan
Re: GTI engine specs
That would all depend on what wet 6speed DSG box you have, if they do vary. I do know that the Golf GTI and R manuals have a "just enough clutch that you'd be foolish to remap without facing the inevitability that you'll need a new clutch soon enough. DSGers with the same cars have had 450Nm remaps without any bother, and even then the DSG boxes can be mapped for higher clutch plate clamping pressures. Is there only one variant of the 6 speed DSG? If so, i'd say the box could handle 380PS and 450Nm as a remapped R gives, but the Polo will probably struggle to get over 250PS unless you start replacing small turbos for bigger ones, same for injectors etc.
alandbess
- Drives: Scirocco
I'm not after big power anyway. I'd only go stg 1. I'm too old for too much more. The surge of adrenaline would probably give me a heart attack if I went for any more than that [emoji23][emoji23]monkeyhanger wrote:That would all depend on what wet 6speed DSG box you have, if they do vary. I do know that the Golf GTI and R manuals have a "just enough clutch that you'd be foolish to remap without facing the inevitability that you'll need a new clutch soon enough. DSGers with the same cars have had 450Nm remaps without any bother, and even then the DSG boxes can be mapped for higher clutch plate clamping pressures. Is there only one variant of the 6 speed DSG? If so, i'd say the box could handle 380PS and 450Nm as a remapped R gives, but the Polo will probably struggle to get over 250PS unless you start replacing small turbos for bigger ones, same for injectors etc.
Should be fine stage 1 if there is only one DSG 6 speed variant. As far as i'm aware, the Golf GTI and R (pre-facelift) use the same DSG box, now GTI PP and R get 7 speed wet DSG with a tall economy led 7th gear.
PoloBlueGT
- Drives: Landrover Freelander
Just to add a question into this I’ve got a Blue GT with A 7 speed dry setup what are the numbers on that if anyone knows?
loadswine
- Drives: Golf 7.5 GTi Performance
In response to Alan's original question, I spoke to DTUK last week, and they said that colleagues had looked at the Polo GTi engine and the basic EA88 is very similar, apart from smaller injectors, smaller turbo and MAF situated on the inlet pipe. I guess it will have a particulate filter in the system as well.
As for gearbox, it is likely to be the DQ250 box, as has been said and it is pretty robust. I have this in my Skoda Superb 280 and it is pretty decent. One of the chaps on Briskoda has been running his superb on stock box at around 500bhp, so guess its tough enough for the Polo.
jylydesign
- Drives: GTI+ on order
Here is an interesting article on the engine used in the 2018 Polo GTI. Although from the EA888 family, there several significant differences not least a higher compression ratio and smaller turbo which probably doesn't bode well for tuning
http://e-hike.net/content/behind-audis- ... n3b-family
Sent from my LG-H840 using Tapatalk
fazzy
- Drives: GTi++/TT/TDi/190E
You guys are talking about a smaller turbocharger... then the logical question is what turbocharger is used in the new Polo GTI?
jylydesign
It's an IS20.
Sent from my SM-A530F using Tapatalk
fazzy
IS 20? Thank you.
Then it's not a smaller turbo and it's the same blower as in the Golf GTi. Thus, the potential for tuning is quite substantial and should be sufficient for most and if it's not, then a IS38 almost plug-and-play blower should be sufficient for 350 hp+ at which point traction will be much more of a problem rather then insufficient power
Traction is a problem now on stock 200ps and Brescia wheel standard tyres (Bridgestone Turanza), and the Polo GTI apparently has a significantly smaller intercooler.fazzy wrote: Sun Feb 17, 2019 2:15 pmIS 20? Thank you.
Then it's not a smaller turbo and it's the same blower as in the Golf GTi. Thus, the potential for tuning is quite substantial and should be sufficient for most and if it's not, then a IS38 almost plug-and-play blower should be sufficient for 350 hp+ at which point traction will be much more of a problem rather then insufficient power![]()
Couple that with the 3b tech making for a high effective compression ratio and there might not be much scope for increasing output by using a tuning box to fool the car into overfuelling - with further fuelling potentially causing pinking - unless you start to use RON98/99.
jylydesign
I have a JB4 tuning box fitted from Burger Motorsports. They say the biggest restriction is indeed the small cooler and potentially causes issues particularly in the summer here and warmer climates. It is supposed to be good for 245 hp but not much more without improving the cooling.
steeve
- Drives: Mk10 GTI+
Be wary when tuning the Polo that you dont lose your warranty, the system is able to identify changes.
jylydesign
Yes I'm well aware of the pros and cons, had two previous tuning boxes on other cars. The JB4 is one of the best and has ability to delete error codes if necessary
