Tom's 6R 1.2 TDI Match to 6C Beats + Component protection Bypass
gaza1994
Drives: Match 1.4 2012 (6r) (85ps)
Re: Polo 6r Beats conversion
Post by gaza1994 »
Out of interest, what was the procedure for fitting/getting the LED headlights?
Tombirch95
Drives: 2011 Polo Match 1.2 TDI
Post by Tombirch95 »
gaza1994 wrote: Mon Feb 04, 2019 10:16 am Out of interest, what was the procedure for fitting/getting the LED headlights?
I managed to find a set on Ebay total cost was £125 delivered, whilst they where on my desk I cleaned them up and installed "Lampa 57840 10–30 V Halo LED (H7)" found on amazon around £60 each needed 4, two main beam two low beam, rebuilt the loom to suite original, tested and fitted.
the lights where originally plug and play but used the standard bulbs I wanted LED so made the changes.
Tom
gaza1994
Post by gaza1994 »
Tombirch95 wrote: Mon Feb 04, 2019 10:22 am
Tom
ah - so if i was to find a unit similar, i still couldn't get LEDS in there :P
Tombirch95
gaza1994 wrote: Mon Feb 04, 2019 11:55 am
Tom
hello,
you could but just install the correct wiring relatively easy job.
Tom
massimo23
Drives: Polo Beats 2017
Post by massimo23 »
Hi there Tombirch95. Great work on the Polo. I Have a Polo Beats and looking at yours you wouldn't notice the difference. I am just finishing off a few interior/exterior visual touches. Adding a shark fin aerial and waiting for Interior Door Bins Mat Cup Holder Rubber Pad Set.
Love the car and the power of music :D :D
JaegerStriker
Drives: 6C GTI
Post by JaegerStriker »
Tombirch95 wrote: Thu Oct 25, 2018 9:03 pm Quite a bit of movement on the electronics
Sourced all the parts for the composite media, created the looms and got to work with removing component protection (permanently)
Took a good few days of work but I’ve successfully Removed/disabled component protection, all features on the head unit work, such as app connect and nav etc, device has been on for well over 24 hours straight with no issues or errors.
Just need to neaten up the wiring and it’s ready to fit to the car.
I’ve had the whole test bench set up, spare BCM and ECU and cluster and diagnostics port and all works and talks.
how did you manage to get app connect working without using the dealership. ive swapped my glovebox unit out with one with app connect and even vw couldnt get it to enable.
i know it works because it did when i connected it up but as soon as the cp was removed i lost that functionality
Tombirch95
JaegerStriker wrote: Mon Feb 04, 2019 6:13 pm
Hello, VW are utter useless sometimes, I took a unit to them first to set about them removing component protection they did not want to go near it, that was Liverpool Volkswagen.
I then set aside allot of time and researched into how CP worked and what it did, then I found a polo in a breakers yard and got my hands on the interior loom, BMC, Infotainment unit, Cluster to be fair looking back most of the electronics on the interior side that use the CanBus system. I then set it all up on my test bench and made it work like in the car although it wasn't in the car. I then spent alloy of time with different signal analysers reading the signals when different functions are turned on, started reading EEproms and memory chips on the different modules to work out how CP Worked. when I had gathered all my data I was able to reconstruct the data to run without CP and flash it back to all the modules, I did have to replace quite allot of the electronic chips.
not for the faint hearted :p
Tom
JaegerStriker
Drives: 6C GTI
would you ever consider charging to do this for others?
Tombirch95
JaegerStriker wrote:would you ever consider charging to do this for others?
I’m working on a way to offer a plug and play option to retrofit
Tombirch95
More bench testing today, getting closer to a being able to offer this to others.
Just a thought who would be interested in having this done?
Tom
ag69
Drives: 1.2TSi 77Kw 7DSG
Re: Tom's 6R 1.2 TDI Match to 6C Beats + Component protection Bypass
Post by ag69 »
I loved your test bench!!!
Lktuning
Drives: Vw Polo 6C 1.0 TSI Highline
Post by Lktuning »
Nice testbench 👍
davitio_979
Drives: Polo Advance
Post by davitio_979 »
Congratulations !!! Very good work!!!
JaegerStriker
Drives: 6C GTI
Tombirch95 wrote: Thu Feb 28, 2019 7:04 pm More bench testing today, getting closer to a being able to offer this to others.
Tom
i would be interested
Tombirch95
One step closer to offering a solution to 6R and other vag cars to fit the Volkswagen infotainment system allowing CarPlay and other features.
So far i have 9 units running non stop with no more component protection issues.
I have a body control module and also a cluster ( both from the same car) and infotainment units that are not programmed to the BCM or cluster so CP would kick in.
Infotainment units tested so far:
3Q0035820
3Q0035820A
3Q0035842
3Q0035842B
5G00358874
3Q0035874B
3Q0035846A
5C0035680G
5K7035200G
I’ve also managed to get “component protection active” removed without dealer assistance.
Will soon be documenting the whole set up as it’s in my car (polo 6R 2011) with working infotainment system.
ImagegImageImage
Sent from my iPad using Tapatalk
