Retrofitting of Cruise Control by MFS on Polo 6R, T5, T6
marin6r
Drives: Polo 6R 2010
Re: Retrofitting of Cruise Control by MFS on Polo 6R, T5, T6
Post by marin6r »
Has anyone managed to succesfully retrofit and enable just CC via MFSW without automatic distance option? (Just basic Cruise Control)?
marin6r wrote: Sun Feb 03, 2019 11:20 pm Has anyone managed to succesfully retrofit and enable just CC via MFSW without automatic distance option? (Just basic Cruise Control)?
We are playing 🐹 with this mod (again :)) but everything indicates that it will not be possible due to limited conditions within the units to be modified.
I wish I was wrong...
poethardo
Drives: VW polo 1.2 TSI
Post by poethardo »
is there any update how to enable ccs from mfsw for vw polo 6c ?
can ccs be able to use without ccs stalk ?
poethardo
Post by poethardo »
hi iichel and ciclo,
please your advise..
i'm using vw polo 1.2 tsi and want to retrofit cruise control for my polo from mfsw.
my polo specification seems like vw polo 1.2 gt india.
based on https://volkswagen.7zap.com/en/rdw/polo ... 53-953050/ it using stalk with part number 6R0953507B to activate cruise control and it dont have steering button with cruise control
but when i see from https://volkswagen.7zap.com/en/rdw/polo ... 53-953050/ for europe version it used stalk with part number 6C0953513 and the steering button have cruise control.
can i used stlak 6C0953513 to my vw polo ? is there any different ?
oh my vcds scan as below
Saturday,02,March,2019,19:35:21:00006
VCDS Version: 18.2.0.3
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: WVWZZZ60ZGT023762   License Plate: B1503ZVM
Mileage: 36680km-22791mi   Repair Order:
Chassis Type: 60-VW25 (6RU)
Scan: 01 02 03 08 09 15 17 19 25 44
VIN: WVWZZZ60ZGT023762   Mileage: 36680km-22791miles
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 KC    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 6270
   Revision: --H10---    Serial number:
   Coding: 00250056232400080000
   Shop #: WSC 12345 123 08192
   ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
   VCID: 6DD17FB6BC91F82CC3-8038
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 0AM-927-769.CLB
   Part No SW: 0AM 300 065 N    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6501
   Revision: 00043014    Serial number: CU501610015204
   Coding: 0000024
   Shop #: WSC 00020 000 90108
   VCID: 3A7B84EA755F9F9416-806E
   Part No SW: 6R0 907 379 BN    HW: 6R0 907 379 AS
   Component: ESP9.0i front H03 0001
   Serial number: --------------
   Coding: 62DD2463412503C3461B246F8253C0800908
   Shop #: WSC 01234 785 00200
   VCID: 0B15112EA245561C7D-805E
Address 08: Auto HVAC (J255)       Labels: 6R0-907-044.CLB
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 4189F306D889CC4C57-8014
Address 09: Cent. Elect. (J519)       Labels:. 6R0-937-08X-09.CLB
   Part No SW: 6RU 937 087 M    HW: 6RU 937 087
   Component: BCM IM H+4    H40 0432
   Revision: BZ040001    Serial number: 0300 224150036
   Coding: 3AB02BFF08A10000003800007C2B049000C0414F60040000200000000000
   Shop #: WSC 124697 483 00190
   VCID: 6CD772B28F8BF124D4-8038
   Subsystem 1 - Part No SW: 6R0 959 802 CC    HW: 6R0 959 802 CC  Labels: 6R0-959-802.CLB
   Component: -------------  007 5551
   Serial number: 13102670150608191142
   Coding: 050000
   Subsystem 2 - Part No SW: 6R0 959 801 BT    HW: 6R0 959 801 BT  Labels: 6R0-959-801.CLB
   Serial number: 13202671150608214932
   Coding: 050000
   Subsystem 3 - Part No SW: 5TA 959 442 B    HW: 5TA 959 442 B
   Serial number: 2921522315902374AS2B
   Coding: 2D0000
   Subsystem 4 - Part No SW: 6R0 959 811 L    HW: 6R0 959 811 L
   Component: -------------  006 5550
   Serial number: 13202580150519203020
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 812 L    HW: 6R0 959 812 L
   Serial number: 13102581150610044634
   Coding: 020000
   Component: VW10AirbagU0F H10 0020
   Revision: --------    Serial number: 003GW01045P0
   Coding: 003046
   Shop #: WSC 00000 000 08192
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4999EB26E8B9040C8F-801C
   Part No SW: 6RF 920 861     HW: 6RF 920 861
   Component: KOMBI         H01 0214
   Coding: 140A000000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
   VCID: 081F2E22B3333D0450-805C
Address 19: CAN Gateway (J533)       Labels: NONE
   Part No SW: 6RU 909 901     HW: 6RU 937 087
   Component: GW-K-CAN TP20 H40 0432
   Revision: BZ040001
   Coding: 002300
   VCID: 19397B661099B48CFF-804C
   Component: IMMO          H01 0214
   Serial number:
   Shop #: WSC 00000 000 00000
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADB74AA8D7FEF14A6-803E
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Coding: 0001000000000000
   ROD: EV_SteerAssisNSK_014.rod
   VCID: 4189F306D089CC4C57-8014
End---------------------(Elapsed Time: 06:14, Deb=2)-----------------------
many thanks and wait for your reply
Could you perhaps post a photo of your current stalks?
poethardo
Post by poethardo »
hii iichel,
this my current stalk
thank you
waiting for your advise
If you want cruise control via the stalk, you should order the 6r0 stalk. Not the 6c0, in any case. If you plan to fit mfsw with mfa buttons, you can install stalks without mfa buttons.
poethardo
Post by poethardo »
Hii iichel,
Is that possible to install cruise control with mfa?
How about steering wiring to do that? is your experiment already finish?
Now i use steering wheel from tiguan mk2 and all button work also with backlight, but cruise control can not work...i still using current loom with part number 6R0959654.
poethardo
Post by poethardo »
please help me master ciclo :D
I dont think CC by MFS is possible on CBZB engine, I'm sorry.
poethardo
Post by poethardo »
so..last option is just activate this using stalk...
thank you very much for your advise.
Yes, I would recommend to do it by stalk.
iichel wrote: Wed Mar 13, 2019 2:44 pm Yes, I would recommend to do it by stalk.
In the autoscan posted the CCS is already activated (ECU, BCM).
Maybe I'm not understanding this conversation correctly.
CCS by MFSW Buttons it's not possible with that ECU software (for the time being :lol:).
It's possible the GRA_High function with that ECU software in case of MFD+. Not is the case.
Yes, I guess he acitvated the CCS functions in the ECU and BCM to make the buttons for the MFSW work. Since that won't work (for the time being, I like the way you think), the stalks must be changed.
