Hi guys,
Does anyone knows where i can order the wireless charging unit or aftermaket unit for the new polo 2018-19 ? Thx
Wireless charging unit vw polo 2018-19
Andy Beats
Re: Wireless charging unit vw polo 2018-19
Curious as to why you'd want wireless charging?stephke74 wrote: Wed Mar 13, 2019 12:39 pm Hi guys,
It means you can't use the excellent Apple/Android carplay features.
hi Andy Beats
thx for your reply
so you mean that the car with wireless charging pad under the 2 usb slots can not be use for carplay?
if i just want to charge the phone .. my friend has both usb connectors and also the wireless pad , he can use carplay when he want to by just plug it in one of the usb ports.
thx for your reply
Andy Beats
Using the USB carplay also charges the phone.stephke74 wrote: Wed Mar 13, 2019 2:55 pm hi Andy Beats
thx for your reply
Which is why I don't understand why you'd need separate charging.
Even if you use the USB for charging only, you don't have to use carplay.
You can switch to radio etc.
hi, yes i know
but that is the point of wireless charging to , that we not have to connect it with a cable
Andy Beats
So you want to charge the phone while ignoring carplay?
Ok, I undertstand now.
I don't know why you would want to do this, but OK.
Is wireless charging available right now? It was disabled/removed from spec for a host of VWs and other VAG cars early/mid last year after it had some non-compliance issue with radio/broadcasting/interference regs.stephke74 wrote: Wed Mar 13, 2019 3:30 pm hi, yes i know
but that is the point of wireless charging to , that we not have to connect it with a cable![]()
Was not aware that it was reinstated.
The OP is from Belgium and I think the non-compliance issues around radio/broadcasting interference was a UK issue.monkeyhanger wrote: Wed Mar 13, 2019 5:27 pmIs wireless charging available right now? It was disabled/removed from spec for a host of VWs and other VAG cars early/mid last year after it had some non-compliance issue with radio/broadcasting/interference regs.stephke74 wrote: Wed Mar 13, 2019 3:30 pm hi, yes i know
