Hi All
I have recently purchased a 2007 1.4tdi for my daughter as her first car. The only thing she is insisting on is that the stereo has an Aux plug or USB.
So i have purchased an RCN210 to replace the RCD200.
The issue i have got is which adapter do i need to buy. Looking around the forum i believe i need a quadlock adapter, but am getting lost with all the different options, what is the CAN connection, do i need it and what does it do? Do i need to take an extra live from the cigar lighter?
Sorry for the questions, but the last time i installed a stereo i was able to simply strip the wires and twist them together. Links to websites would be great.
Thanks in advance for any help.
Si
Another Stereo Topic
Re: Another Stereo Topic
All the info you need is in this thread
viewtopic.php?t=71905
As far as I know the can simulator was to address an issue with battery drainage
You need 2 connections from the ciggy lighter
12V for power to the memory to keep tuned stations and phone
approx 8V i think it was for the illumination of the buttons on the radio when the vehicle lights are turned on
Both supplies can be found at the ciggy lighter
When I fit mine, I only used an ignition live from the fuse box and the canbus adapter from the old wiring. Not had any issues.gerinemo wrote: ↑Sun Mar 17, 2019 7:54 am All the info you need is in this thread
Unless I'm misunderstanding.
***to clarify, I meant to fit my stereo, not to fit a 210. I have a Pioneer. Sorry for the confusion
Hi
Thanks for help so far.
Radio is up and running and BT works correctly for both calls and audio. However I got what i think is a CANbus emulator with the unit and am currently using it. The only issue i have now is the illumination. I have got the light connection at the ciggy lighter, but where does it connect to in the radio harness. I have tried tracing with a meter, but have not had any success.
Simon
Simon
Orel - got your PM but can't reply.
I don't have the RCN200, I have a pioneer. Sorry, it was unclear in my original comment.
Found this pic of the ISO plug from when I was changing the stereo the orange was the illumination
Thanks for the reply. eventually found time to get back on to this. However mine doesnt have any orange wires.
