Polo 9n SDI 02
Dutcho
Drives: SDI 9N
Re: Polo 9n SDI 02
Post by Dutcho »
And only fuse blown in the drivers side slot was cigar lighter
Dutcho
Drives: SDI 9N
Re: Polo 9n SDI 02
Post by Dutcho »
Had a guy from a garage pop round and put his snap on reader onto car. It pulled about 17 fault codes with 4 saying defective ECU so all these problems might be down to a dodge ECU
Anyone paid to have one repaired before ?
alexperkins
Site Admin
Re: Polo 9n SDI 02
Post by alexperkins »
You need a proper scan with VCDS and pop the results up on here. There aren’t ‘defective’ ECU codes
Re: Polo 9n SDI 02
If in the end it does end up being a faulty engine ECU, there are places like BBA REMAN that, it is said, will repair your unit if it is possible and return it to you so that it can get refitted and all its original programming is still intact.
Edit:- http://www.bba-reman.com/gb/index.aspx
Dutcho
Drives: SDI 9N
Re: Polo 9n SDI 02
Post by Dutcho »
alexperkins wrote: Sat Mar 23, 2019 10:08 am You need a proper scan with VCDS and pop the results up on here. There aren’t ‘defective’ ECU codes
Unfortunately I don't have a full version for vcds I'm very cautious about throwing more money at the car as well :-(
Dutcho
Drives: SDI 9N
Re: Polo 9n SDI 02
Post by Dutcho »
Well buit the bullet and cracked open ecu. No signs of water getting in there ?? Doing my head in do I take the gamble whats testing cost ?
Re: Polo 9n SDI 02
Contact places like BBA REMAN directly for a price.
alexperkins
Site Admin
Re: Polo 9n SDI 02
I’m still going for a bad earth somewhere :lol:
Dutcho
Drives: SDI 9N
Re: Polo 9n SDI 02
Post by Dutcho »
Haha I hope so but dammed if I know where 🤣🤣🤣
Dutcho
Drives: SDI 9N
Re: Polo 9n SDI 02
Post by Dutcho »
Solved ..... dodgy egr fuse that tested ok continuity wise but not under load very weird but sorted just a engine flush now and back on the road cheers for all your help
alexperkins
Site Admin
Re: Polo 9n SDI 02
Excellent :) Glad its sorted
