Dashboard swap! Seat Toledo Instrument Cluster on Cross Polo 6R
pranaynewton
Drives: 6R 2014 (Vento TSI 1.2L)
Re: Dashboard swap! Seat Toledo Instrument Cluster on Cross Polo 6R
Post by pranaynewton »
Can someone provide information on how to update 6R0920870C Blue GT cluster SW? In the sense what tools would be required?
Are there any limitations of max software version for a particular hardware version?
It currently has HW03 SW0604
It would be great if someone provided the files for the upgrade as well. Goal is to enable Direct TPMS.
pranaynewton
Bump
Can anyone help with this?
Pranay
exantas
Drives: Skoda Fabia 5J 1.2 TSI
Post by exantas »
Has anybody tried this tool?
https://www.aliexpress.com/item/SUPERVA ... 2e0egzfwIR
I know that is a clone but does it have any chance to work with PQ25 cluster swap ?
Or the specific software needs internet connection to work (not talking about upgrades).
Jerryncg93
Drives: Volkswagen Vento 1.2 tsi
Post by Jerryncg93 »
MaDwArLoCk wrote: Sat May 19, 2018 7:53 pm High Beam Assist
I was following Fernando's manual viewtopic.php?f=56&t=58703&p=503577&hil ... nt#p503577 Thank you! 🙏
Necessary parts
Old mirror mounting
I used Firegrafik's stencil
Applied primer
New mirror mounting
Mirror on the place
New rain/light sensor
HBA -ON 😎
And all light indications are ON
To activate Front Fog Light indication is necessary to change Byte in eeprom
Byte 02D4 from 7C to 7E
And Fog light should be connected to BCM or a wire T32a/30 :wink:
Hi, may i know is the primer you applied resulting the black shade?
Jerryncg93
I can't find both original primer and adhesive here in Malaysia.
Do you guys have any recommendations for after market brands with similar performance?
Jerryncg93
Oh yess, got it! Show you guys when it's done! :D
Activating the automatic lights on your 6R LED Headlights is very interesting, please open a new thread when you install the light sensor.
It will be useful for other users, who, like you, will seek help in the forum. Thanks.
Lucero79
Drives: Polo
Post by Lucero79 »
Sorry for the incursion.
I have a 2012 SEAT Ibiza ST 1.6 CR TDI (CAYC). I need to swap the IC as my bulbs have started to die. I have a used cluster from a 2013 SEAT Ibiza. There is a lot of confusing information about what I should need to make this work. I have VCDS and HEX cable. Some places say I need a PIN to swap over. Others say I won't be able to correct the mileage, but when I look, all this seems to be for older VAG cars. SuperVAG mentioned here, is that it, is it free, do I need the Key or Toolbox plugin??)
This seems like a comprehensive thread at least, so I'm really really hoping some one can help me out.
I have a few more wishes (swapping to Ibiza 6R dash from 6J so I can use the new light and Climate modules, etc), but let's start with this first :D
MaDwArLoCk
Drives: Cross Polo 2010 TSI
Post by MaDwArLoCk »
Lucero79 wrote: Mon Sep 23, 2019 8:38 am Sorry for the incursion.
I have a 2012 SEAT Ibiza ST 1.6 CR TDI (CAYC). I need to swap the IC...
I think you are missing something!
PIN is necessary for adaptation IMMO3 clusters, your car have IMMO4.
So you can do it only with device like SupeVAG or Abrites.
Both (clones) cost €100+, so I think it will be cheaper or at least same price, and much easier if you will ask your local specialists to do that job! :wink:
Jay-Jay
Drives: Polo 6R HL 1.2TSI 77kw, Audi S1 MY2018
Post by Jay-Jay »
Hi MaDwArLoCk,
I've read you updated your ECU firmware from 9694 to 9851?
What are the differences between these two versions?
Does the new version implements new features?
MaDwArLoCk
Hi Jay-Jay,
I haven’t noticed any difference between those firmwares.
Just flashed it because it’s the latest firmware available for my ECU.
Probably there are some minor bug fixes.
BTW if you want to try 9851, I have good St1 tune with activated GRA-High on VR firmware. So it’s possible to flash it in any 03F906070D ECU.
PM me if you are interested.
Paride89
Drives: Polo 6c 1.4 tdi
Post by Paride89 »
Hello everyone, I bought a Toledo used cluster due to swap my polo original ic, in order to have a fully working instrument besides the immo coding with a tool such as abrites or super vag what else should I need to do?
MaDwArLoCk
Paride89 wrote: Thu Oct 17, 2019 11:09 am Hello everyone, I bought a Toledo used cluster due to swap my polo original ic, in order to have a fully working instrument besides the immo coding with a tool such as abrites or super vag what else should I need to do?
Hi Paride89,
Besides moving IMMO you need to make some adjustments in eeprom.
Check first post in this topic, everything is there! 😉
Paride89
Post by Paride89 »
MaDwArLoCk wrote: Thu Oct 17, 2019 3:55 pm
Hi Paride89,
Thank you MaDwArLoCk Best way to use the mfa+ is the mfsw or the stalk?
