ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP. 🧙♂️
Re: ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP
As you all know, when it's combined a 55W ballast with a 35W 5500K xenon lamp the final color will be around 4300K-5000K (depends on several factors). It's a good combination, but I also want to try to get a whiter color.
To try to achieve this whiter color I have also bought these xenon lamps D2H 35W 6500K Yeaky (1 pair) , this way I can continue with the festival of tests that I am doing.
I received the Quick Start 55W-35W 5500K xenon kit, which is a lot better (HQ) than the monstrous xenon kit included in the purchase of the Replica LED Headlights.
I suppose the monstrous xenon kit is like those gifts we see and we immediately would return them... (slow start, super decoder with WTF Resistors, etc)
Yes, there are many high quality brands for a good xenon kit, but, finding the perfect combination (projectors-lenses, ballasts, and xenon lamps) according to our needs is like finding the perfect audio system, it requires some time and Tests, because we all don't see or hear the same.
At the moment, these Replica LED headlights have the correct structure for the tests.
Improvements so far:
- VW Holder for xenon lamps.
- Rubbers for the Headlight corner.
- HID xenon Kit a lot of better quality.
vs
Comparison
Yeaky and DLT installation
Yeaky Tests when possible
While I'm waiting for the Yeaky D2H 6500K xenon lamps arrive to do the Tests and my wife choose if she wants the 6500k or 5500K, this is the way of How I installed the TPMS unit.
Golf 7.5 Direct TPMS (RDKS)
viewtopic.php?p=574274#p574274
Coding:
Autoscan:
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H04 0009
Serial number: 30000000250801
ROD: EV_RDKBERU30_006_VW37.rod
VCID: 3431E1AC5EBC84C74A5-8060
Coding:
-Direct TPMS
Address 19:
Installation List, enable Address 65
Adaptation
SECURITY ACCESS ---> 20103
Installation list: specified installations-Tire Pressure Monitoring 1,Not coded ,32 (coded)
Indirect TPMS deactivation / Direct TPMS activation
Address 17: Instruments
Coding
Byte4 Bit0 (disable)
Byte3 Bit7 (enable)
Byte11 Bit2 (enable)
Address 03: ABS Brakes
Coding
Byte27 Bits 4/5/6 (disable)
Byte28 Bit7 (disable)
Address 5F: Information Electr.
SECURITY ACCESS---> 20103
Adaptation
Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Suspension data bus ,64 (Databus extended)
RDKS editor / VCP
Generate and load zdc file (comfort/standard/fully loaded)
Autoscan:
Sunday,17,February,2019,14:35:37:32438
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4436.4
Data version: 20190114 DS296.0
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW License Plate: TPMS OK!
Mileage: 10621km-6599mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 20 42 44 52 5F 65 BB BC
VIN: WVWZZZAUZKPCICLOW Mileage: 10621km-6599miles
BB-Door Rear Drv -- Status: Not registered 0001
BC-Door Rear Pass -- Status: Not registered 0001
Address 01: Engine (J623-DKRF) Labels: None
Part No SW: 04C 906 025 L HW: 04C 907 309 BB
Component: R3 1.0l TFS H20 6198
Revision: D7H20000
Coding: 01190032232415082000
Shop #: WSC 00028 028 00070
ASAM Dataset: EV_ECM10TFS01104C906025L 002003
ROD: EV_ECM10TFS01104C906025L_002.rod
VCID: 290F00D8897EC92FE93-807C
Readiness: 1110 0001
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 DD HW: 5Q0 614 517 AC
Component: ESC H25 0424
Revision: 00000000 Serial number: 51998000000173
Coding: 01FA6AA114202170477B060560CA2580562884E26006A4733020F0084002430B00000012121212B835351919323200
Shop #: WSC 00028 028 00068
ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
VCID: 76B51BA40840D6D7B41-8022
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5G0 907 044 CE HW: 5G0 907 044 CE
Component: Climatronic H04 1801
Revision: 00001K08
Coding: 00020003200110011005004000101022
ASAM Dataset: EV_ACClimaBHBVW37X 006145
ROD: EV_ACClimaBHBVW37X_006_VW37.rod
VCID: 6C8139CC460C1C07525-8038
Fresh Air Blower Front:
Refrigerant Pressure And Temperature Sender:
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 DA HW: 5Q0 937 084 CD
Component: BCM MQBAB B H38 0273
Serial number: 00001820800697
ASAM Dataset: EV_BCMMQB 019001
ROD: EV_BCMBOSCH_019_VW37.rod
VCID: 7AAD0F943C58B2B7D09-802E
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 180621 043 0551
Serial number: 180705074106
Coding: 0E4DDD
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 052 0107
Serial number: SBY18M08D06H04M32S34
Coding: 03A8DD
Steering Column Switch:
Subsystem 3 - Part No SW: 5Q1 953 507 HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0060
Serial number: 00000002081804401346
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 5QA 919 294 C HW: 5QA 919 294
Component: PDC 8 KanalH07 0050
Serial number: 000308418018193
Coding: 0471151001
ASAM Dataset: EV_EPHVA18AU3700000 009039
ROD: EV_EPHVA18AU3700000_009_VW37.rod
VCID: 4CC1994C264CFC07325-8018
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A
Component: ACC BOSCH MQB H11 0682
Coding: 2B00600111FFC728949C810500400600000000000000000004
ASAM Dataset: EV_ACCBOSCHVW416 002008
ROD: EV_ACCBOSCHVW416_002_VW37.rod
VCID: 44D1B16C0E1C3447FA5-8010
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 BJ HW: 5Q0 959 655 BJ
Component: AirbagVW21 006 0339
Serial number: 003VWR4F1CUQ
Coding: 98CCC000000000005C0000CF000800000065
Shop #: WSC 00028 028 00064
ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 094F605869BEA92FC93-805C
Belt Pretensioner left:
Subsystem 1 - Part No SW: 5G0 980 945 B HW: 5G0 980 945 B
Component: BeltPretRevFL H37 0350
Serial number: 34169667E30071820325
Coding: 333135
Belt Pretensioner right:
Subsystem 2 - Part No SW: 5G0 980 946 B HW: 5G0 980 946 B
Component: BeltPretRevFR H37 0350
Serial number: 34169668E31071830145
Coding: 333135
Side Sensor Driver Front:
Subsystem 3 - Part No SW: ----------- HW: 480 002 307 18
Component: SideSensor_Df 001 0887
Serial number: 35700000000F8745C23S
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 4 - Part No SW: ----------- HW: 480 002 807 18
Component: SideSensor_Pf 001 0887
Serial number: 358000000000EC18233G
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 5 - Part No SW: ----------- HW: 480 403 107 18
Component: SideSensor_Dr 003 6149
Serial number: 3510001A729FD154210-
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 6 - Part No SW: ----------- HW: 480 403 107 18
Component: SideSensor_Pr 003 6149
Serial number: 3520001A929FD1515577
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 7 - Part No SW: ----------- HW: 480 402 306 18
Component: FrontSensor_D 003 6149
Serial number: 3550001A326704A3C63.
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G1 920 740 D HW: 5G1 920 740 D
Component: KOMBI 211 2500
Coding: 07A52A802280000801883A051401000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009065
ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
VCID: 270B06E09F6AFF5FFF7-8072
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 Q HW: 3Q0 907 530 C
Component: GW MQB High 518 5344
Serial number: 14071810801894
Coding: 030100047F085700FA000248080F00010001070000000000000000000000
ASAM Dataset: EV_GatewNF 013023
ROD: EV_GatewNF_VW37.rod
VCID: 3D27C4886DF6458FB5B-8068
Alternator:
Component: 1-01-02-01-04
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 5G0 959 442 AA HW: 5G0 959 442 AA Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0052
Serial number: 39180001255750088264
Coding: 28FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Component: J367-BDMHella H10 9070
Serial number: 9353818504
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 3G0 857 511 BD HW: 3G0 857 511 BD
Component: FLA H01 0010
Revision: AA001001
Coding: 0101000000000000000000
ASAM Dataset: EV_HighBeamAssisAU33X 001019
ROD: EV_HighBeamAssisAU33X_VW37.rod
VCID: 6B833AD043021B3F5BF-803E
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q4 959 593 F HW: 5Q4 959 593 F
Component: TSG FS 005 0240
Serial number: 42018727800277
Coding: 00150320D000048000001000
Shop #: WSC 17301 666 28888
ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
VCID: 48C9A55C3234102716D-801C
Drivers Door Rear Control Module:
Subsystem 1 - Part No SW: 5Q4 959 811 F HW: 5Q4 959 811 F
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000009798407
Coding: 010000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 AA HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 131 1081
Coding: 011F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 73B322B01B32C3FF93F-8026
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q4 959 592 F HW: 5Q4 959 592 F
Component: TSG BFS 006 0246
Serial number: 0000336638884
Coding: 00150320DE00048000001000
ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
VCID: 47CBA6603F2A1F5F1F7-8012
Passengers Rear Door Control Module:
Subsystem 1 - Part No SW: 5Q4 959 812 F HW: 5Q4 959 812 F
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000009846262
Coding: 090000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 824 C HW: 3Q0 035 824 C
Component: MU-S--ER 724 0890
Serial number:
Coding: 02731000FF0000005111000100080A001F0500D40120010003
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 2D07F4C8BD96D50F05B-8078
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 5G6 919 605 A HW: 5G6 919 605 A
Component: ABT_Std-2 H52 8130
Serial number: VWZ6ZJV2140047
Address BB: Door Rear Drv
Cannot be reached
Address BC: Door Rear Pass
Cannot be reached
End----------(Elapsed Time: 01:21, VBatt start/end: 14.6V/14.6V)-----------
Ventilation of these "Replica" LED headlights.
Ducts vent x3
Front
Middle
Rear
Speculation:
I'm not sure because it's hard to see, but I think this Replica headlight has an electronic ventilation system, inside there is a box with a cover that belongs to the headlight structure, I opened it and seems to be a temp sensor or related with the temperatures. On the other hand in the headlight center in the inner bottom part seems to have a fan or a valve. Difficult to see or remove (I did not). Their locations are shown in the following image.
I've taken a precautionary measure that is not necessary to do, but I prefer to make sure that the ventilation ducts are not lost, the foam that is seen in the following image is very important.
In addition, inside these Replica LED headlights brings a bag of desiccant silica gel, IMHO is perfect, clearly it's to absorb the moisture condensation inside the headlight.
Ducts vent x3
Front
Middle
Rear
Speculation:
Yeaky 5500K 35W xenon lamps + 55W DLT ballast. Test and BCM adaptation.
- Fast Bright. Quick start OK!
- After adaptation, NO BCM faults.
Original Video : https://www.youtube.com/embed/CPDHANyWc ... autoplay=1
More information in OP when the tests with Yeaky 6500K 35W xenon lamps finish. (waiting for them)
- VW Holder for xenon lamp.
- Rubber for the Headlight corner.
- Plastic Clamps for ducts vent.
VCDS
Golf 7.5. Active Window Switch when Ignition Switch goes from ON to OFF and opening the doors.
09
SA 31347
ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen,active ,8 ...to not active
Note: ... until you start a new operative cycle by closing one of the front doors. Rear doors status does not influence.
09
SA 31347
Golf mk7.5 removing / installing headlights. PDF 1 page
I've made the adjustment of the light patterns with the wall method, applying the 1% ECE, at no time the oncoming traffic warned me of being dazzled by my headlights.
However, I will make an adjustment of the light patterns with a regloscope in a workshop. Once done I will show more images.
At the moment everything works correctly with these Replica LED headlights, including the Light Assist function (HBA).
Original Video : https://www.youtube.com/embed/1fzBxv-C7 ... autoplay=1
Halogen Headlights
There are circumstances in daylight conditions in which the turn signal in that place/position is not seen laterally by pedestrians, cyclists, or rest of people that circulate by the asphalt jungle...
The beam pattern of my Replica LED headlights were adjusted with a BOSCH regloscope, ... just perfect, just like this, Bosch HTD 815.
Coincidentally, it's raining where I live and taking pictures with my poor tools doesn't make sense, I still haven't washed the car after installing these headlights and do the tests.
When be possible...
When be possible...
"to infinity and beyond"
Original Video : https://www.youtube.com/embed/ZDAzWvl4o ... autoplay=1
In my first attempt to take pictures of my Replica LED headlights without success because of the rain, a fast snail that was circulating at the speed of light come through near my. Afortunalely I had the camera in my hand and I was fast enough to take the image shown in the video.
