Hi Guys,
Has anyone found/worked out some VCDS mods you can use for the 6C? I've had a look for some mods like adding a teardrop wipe or activating the heated mirrors with the rear window de-mist but most results are for 6R models only and the mods aren't compatible.
Any help is greatly appreciated.
6C VCDS Mods
ArcheryCharlie
- Drives: 6C GTI
Re: 6C VCDS Mods
I've yet to be convinced that the tear drop function for the front wipers can be enabled when you have auto wipers, which is a pity, I'm sure that it was enabled at the factory with my 2011 S4 which has auto wipers and my daughter's late 2009 Ibiza which does not have auto wipers!
Edit:- my wife's August 2015 Polo came without auto lock/unlock enabled and not even available via the options menu, and I sorted that out okay.
