Polo 6C Cruise control retrofit
will3733
- Drives: 2014 6C (yeah the weird 6R/6C one)
Hi
Does anyone know if it is possible to retrofit cruise control to a Polo 6C Bluemotion 2014, either through a new stalk or mfsw?
I would prefer to fit a mfsw but looking online there seems to be very little info on doing so and I assume it is harder than retrofitting stalks.
Would I need to get component protection removed and if so Is there anywhere in particular someone could recommend I go to?
My stock stalk look like this
Dink
- Platinum Member
- Drives: 2015 GTI
Re: Polo 6C Cruise control retrofit
the only retrofit way is to use the stalks on a 6c.
will3733
Thanks for the info
Any idea on what part numbers I should order / how to find the part numbers i need?
I asked the seller and he said this would be compatible with my 6C but I am a little sceptical.
Lktuning
- Drives: Vw Polo 6C 1.0 TSI Highline
This part number:
6C0953513B with out trip computer
Or
6C0953513C With trip computer
Or
will3733
Thanks i'm gonna order 6C0953513C With trip computerLktuning wrote: Wed May 08, 2019 5:19 am This part number:
Or
Does it need additional wiring loom or can I just plug it into the existing stalk sockets and enable it with vagcom?
It's unlikely that the wiring for CCS is pre-installed. Furthermore you'll need to buy the retrofit kit, as it will contain a SWaP code. This code needs to be installed by the VW dealer to activate your CCS. Otherwise it will not work. This is the only way to do it.
Shappers01
- Drives: Polo Highline 1.0 TSI 81kW. R-Line
My dealer retrofitted cruise on my 6C. I have the same stalks as you. It’s done by adding additional buttons to the steering wheel. The wires are not in place to do it by stalks.
The dealer has to get a license key to enable the option. It was not expensive so just let them do it..
will3733
Shappers01 wrote: Fri May 10, 2019 9:36 pm My dealer retrofitted cruise on my 6C. I have the same stalks as you. It’s done by adding additional buttons to the steering wheel. The wires are not in place to do it by stalks.
Can you remember roughly how much it was?
I'm not going to bother fitting it myself since its too much of a faff but if I can find someone to do it I might get it done.
Shappers01
Sorry for the slow reply. It cost me €380 (£300) which was about the same as the option price when new.
My dealer managed to break a bit of rubber off the back of the steering wheel while removing the switches so I even got a brand new steering wheel out of them for free!
ed.silmon-monerri
- Drives: 6c 1.4 TDI SE
Hi Shappers, Do you have a pic of the "additional buttons" fitted to the steering wheel please as I'm considering this upgrade for my motor and for 300 sheets (including a potential new steering wheel lol) it is worth considering. I have an SE bluemotion with trip meter and the phone/dash buttons on my wheel...
ed.silmon-monerri
If they're added below the MFSW buttons with the addition of a new shiny black trim piece then I think I've just seen them...
Shappers01
Hello, I'm sorry for my slow reply. I've been having some extensive cancer surgery. Hoping to drive my Polo again soon
Here is the part removed from my car:
Here is the new switchgear:
And here is my work sheet (In Finnish) but it clearly shows the new part number is 6C0054690A. Parts €175, labour €205:
Brgds, Shappers
Brgds, Shappers
Hi guys, i have volkswagen polo confortline 6c
I changed the wiper levers with the buttons to control the instrument cluster, how could I activate the on-board computer control? the car does not have a steering wheel control
