Retrofitting Reverse Camera to 2016 Polo 6c Match
FiftyPlus
Drives: Polo 6C Bluemotion "Match" 2016
Re: Retrofitting Reverse Camera to 2016 Polo 6c Match
Post by FiftyPlus »
Dink wrote: Tue May 07, 2019 6:04 pm The brains are in the glovebox the display is just that.
I'm not sure from your post but did you connect it to the brains or the screen?
Ho Hum. My immediate reaction when I removed the screen was ... problem. I had expected a large infotainment module. I was certain I was on a road to nowhere, but the instructions said " clear wire to pin 6, Black wire to pin 12" on 12 pin connector. As there were empty pins 6 & 12 on a 12 pin connector that's where I went. Clearly now wrong.
But in hindsight (the only other word of instruction) are Radio/Navi Quadlock Green 12 pin connector So clearly I am in the wrong place.
I will revisit in the morning, But I wonder will this be OK. Does it sense the camera signal, or will I still have a coding problem?
Apologies for the errors, just totally new to the polo. feeling my way around..
Dink
Drives: 2015 GTI
Post by Dink »
FiftyPlus wrote: Tue May 07, 2019 6:52 pm
You don't have to apologise for anything.
the main problem is the the 6r and 6c are both technically the same but the biggest change is the electrics, so instructions for 6r don't get changed to actually suit the 6c.
i'm pretty sure that once you plug it into the brains in the glove box it should work fine
FiftyPlus
Post by FiftyPlus »
OK, I finally got to revisit this Rear View Camera installation this morning. removed the glovebox, slid out the "brains" located pins 6 & 12 on the green connector, etc. All good.
Made temporary connections for ground & power.
Then I revisited the VCDS coding.
Unfortunately I still have the same behaviour.
1) If I select RVC in the Infotainment module (Bit19 I think) the display re configures with a smaller image of the car and space for the camera image: but no camera image. But it just works for one "putting into reverse" cycle, and then displays "park assist not available" and no parking related screen displayed. (i.e no front/ rear sensors/ camera space). If I deselect camera in long code the parking screen reappears.
2) If I select RVC installed in "Park-Steer Assist" Module it has no apparent affect, either singly or in combination with 1) above.
So I have no proof that the camera works, but it probably does.
I strongly suspect the issue is coding related. I have done the coding , powered off, locked the car, had a cup of tea, etc, but behaviour is always the same
I can't find any other reference to camera in the VCDS.
What thoughts?
See below the scan I have right now
Saturday,11,May,2019,18:20:50:16756
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4436.4
Data version: 20190114 DS296.0
www.Ross-Tech.com
Workshop Code: 790 31414 000001
VIN: WVWZZZ6RZGU082432 License Plate: POLO 6C MAY 11
Mileage: 34484km-21427mi Repair Order:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 10 15 17 19 44 5F
VIN: WVWZZZ6RZGU082432 Mileage: 34484km-21427miles
Address 01: Engine (J623-CHYA) Labels:. 04C-906-020-CHY.clb
Part No SW: 04C 906 057 AA HW: 04E 907 309 CB
Component: R3 1.0l MPI H20 2495
Revision: 33H20000
Coding: 01110072022401080000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM10MPI01104C906057AA 001002
ROD: EV_ECM10MPI01104C906057AB.rod
VCID: 6491AF277EDFA8671A5-8030
Readiness: 0000 0000
Part No SW: 6C0 907 379 K HW: 6R0 907 379 BA
Component: ESP9.0i H03 0004
Serial number: 08504439160426
Coding: 23DD2485492B33C20918106C0053C42492CC90080005CB098F00
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
ROD: EV_Brake1ESP90iBOSCHPQ26.rod
VCID: 372B286B9FC993FF6F7-8062
Address 08: Auto HVAC (J301) Labels:| 6C0-820-045.clb
Part No SW: 6C0 820 045 C HW: 6C0 820 045 C
Component: AC Manuell H03 0202
Serial number: 1604221B-0344
Coding: 200100001000100000
ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
ROD: EV_ACManueKMMValeoPQ26.rod
VCID: 1F1BE0CB1739CBBF877-804A
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-089-V1.clb
Part No SW: 6C0 937 089 C HW: 6C0 937 089
Component: BCM PQ26 Hi4R H08 0087
Serial number: 006098188715
Coding: 0300084042530A7B0FA44080B12703C800005B0257010000000000000000
Shop #: WSC 131071 1023 2097151
ASAM Dataset: EV_BCMA0 005005
ROD: EV_BCMA0_005.rod
VCID: 303913777AA744C72ED-8064
Rain Light Recognition Sensor:
Subsystem 1 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A Labels: 5Q0-955-547.CLB
Component: RLS 037 0059
Serial number: S3Y16M05D20H15M49S32
Coding: 9038DD
Drivers Door Control Module:
Subsystem 2 - Part No SW: 6R0 959 802 DM HW: 6R0 959 802 DM Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 0610
Serial number: KU0KU010051661314151
Coding: 1400A1
Front Passengers Door Control Module:
Subsystem 3 - Part No SW: 6R0 959 801 DK HW: 6R0 959 801 DK Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 0610
Serial number: KU0KU002051661238443
Coding: 0400A1
Sensor For Anti Theft Alarm System:
Subsystem 4 - Part No SW: 6C0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY160321GRQ
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0313
Serial number: 00000000000065394010
Drivers Door Rear Control Module:
Subsystem 6 - Part No SW: 6R0 959 812 AA HW: 6R0 959 812 AA
Component: J389__TSG_HR 003 0610
Serial number: KU0KU006051661271634
Coding: 1400A0
Passengers Rear Door Control Module:
Subsystem 7 - Part No SW: 6R0 959 811 AA HW: 6R0 959 811 AA
Component: J388__TSG_HL 003 0610
Serial number: KU0KU028041661195010
Coding: 0400A0
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39331612511631
Coding: 0031051001
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_EPHVA18AU3700000 002026
ROD: EV_EPHVA18AU3700000_VW26.rod
VCID: 43D34CBBDB11CF5FC3F-8016
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 J HW: 6C0 959 655 J
Component: VW20Airbag00C 002 0380
Revision: -------- Serial number: 003TH006DZ2J
Coding: 88C0C000000000005C000000008800000000
ASAM Dataset: EV_AirbaVW20BPAVW26X 001001
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 3A2D315FACDB8E97909-806E
Side Sensor Driver Front:
Subsystem 1 - Part No SW: ----------- HW: 410 822 504 16
Component: SideSensor_Df 151 0800
Serial number: 3575H00A52085D128218
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 2 - Part No SW: ----------- HW: 410 822 404 16
Component: SideSensor_Pf 151 0800
Serial number: 3585H00A9209A1C332FS
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 3 - Part No SW: ----------- HW: 442 152 404 16
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A00AF1D5E5B1A35X
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 4 - Part No SW: ----------- HW: 442 150 303 16
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A0016294B6C9A66N
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 6C0 920 940 C HW: 6C0 920 940 C
Component: KOMBI 201 1420
Coding: 272409002180260001086A001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009046
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 2411EF273E5FE867DA5-8070
Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 HW: 6C0 937 089
Component: GW MQB A0 H08 0087
Revision: -------- Serial number: 006098188715
Coding: 030100046F0A640071000000000000010001010000000000000000000000
ASAM Dataset: EV_GatewA0Lear 013020
ROD: EV_GatewA0Lear_013_VW26.rod
VCID: 6597B22375E5D16F0DB-8030
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 6C0 959 442 A HW: 6C0 959 442 A Labels: 3C8-959-537.CLB
Serial number: 1181614220001412AD1B
Coding: 280000
Subsystem 2 - Part No SW: 6C0 915 181 A HW: 6C0 915 181 A
Component: J367-BDM H08 0223
Serial number: 63127I00412821093134
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C2 909 144 AG HW: 6C2 909 144 D
Component: EPS_TRW_ALow 322 3232
Serial number: CG6B0465
Coding: 000700
ASAM Dataset: EV_SteerAssisUDSTRW 016026
ROD: EV_SteerAssisUDSTRW.rod
VCID: 6E85CD0FA01312377C1-803A
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 874 A HW: 3Q0 035 874 A
Component: MU-S-ND-ER H24 0252
Serial number: VWZAZ2S0275217
Coding: 02720001BE00000051111101008808001F0100C601200100CF
ROD: EV_MUStd4CTSAT_VW26.rod
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 6C0 919 603 A HW: 6C0 919 603 A
Component: ABTm_Std2_Nav H53 1031
Serial number: VWZ8Z9SKX0174S
End----------(Elapsed Time: 00:55, VBatt start/end: 14.7V/14.8V)-----------
massimo23
Drives: Polo Beats 2017
Post by massimo23 »
Hi there my coding for the 8K OPS and RVC for polo 2017 is:
Revision: -------- Serial number: 39331616502046
Coding: 0031151001
Shop #: WSC 00788 648 00255
VCID: 43D2BACECB12EF2FC3F-8016
Long Coding - Byte 02 Bit 4 enabled for RVC Low
Adaptations:
Speaker volume for rear park assist:
Stage 2
Speaker frequency for rear park assist:
Stage 1
Speaker volume for front park assist:
Stage 2
Speaker frequency for front park assist:
Stage 2
Audio reduction request:
On
Park assist activation tone:
On
Switch-off speed for parking assist:
15 km/h
Production mode:
Deactivating
Deactivate production mode:
Deactivating
In 5F - Information Electronic Unit -
Long Coding - Byte 19 Bit 4 enabled for Rear View Camera Low
in Adaptions:
In Vehicle_configuration:
RVC_video_input: FBAS
rvc_low_black_screen_velocity_threshold: Not activated
rvc_low_failsafe: Not activated
rvc_low_black_screen_trunk_open: Not activated
Pilot_Parking: Not activated
OPS_display_in_dash_board_display_unit: Off
Car_Function_Adaptations_Gen2:
menu_display_pdc: activated
menu_display_pdc_clamp_15_off: Not activated
menu_display_pdc_over_threshold_high: activated
menu_display_pdc_standstill: Not activated
menu_display_pdc_after_disclaimer: Not activated
Car_Function_List_CAN_Gen2:
PDC_audio_lowering: available
PDC_audio_lowering_msg_bus: Suspension data bus
Car_Function_List_BAP_Gen2:
parking_assist_0x0A: activated
parking_assist_0x0A_msg_bus: Terminal 15
FiftyPlus
Post by FiftyPlus »
Great thanks for going to the bother of doing this. Will try & confirm.
massimo23 wrote: Sun May 12, 2019 1:59 pm Hi there my coding for the 8K OPS and RVC for polo 2017 is:
Coding: 0031151001
massimo23
Post by massimo23 »
Hi fifty plus I was looking at a couple of sites that sell the rvc camera system and found these 2 images:
Also this is schematics for my rvc fitting guide:
So correct me if I am wrong but are the transparent and black cable, that are added to pin 6 and 12 respectively, suppose to go to the blue connector and not the green one?
FiftyPlus
Post by FiftyPlus »
massimo23 wrote: Tue May 14, 2019 11:36 pm So correct me if I am wrong but are the transparent and black cable, that are added to pin 6 and 12 respectively, suppose to go to the blue connector and not the green one?
Huge thanks. I have been busy so did not get back to this. I will revisit tomorrow.
I checked the "instructions" from VAG-tec. Definitely says green... :x
Thanks Again
FiftyPlus
Post by FiftyPlus »
Still no joy, getting a bit baffled at this stage
I had another look at this and revised the connection to the blue connector, pins 6&12 (thanks for that correction). I will post a photo later.
I was certain I had found my error: as well as the incorrect instructions that shipped with the camera I have ( it said to connect to pins 6 & 12 on the GREEN connector), I had been cheating by not digging out the reversing light wire to connect to the yellow wire and just connection to +12 to test, but suggestions are this causes a timing error and causes the "Park Assist unavailable" error that others have mentioned.
I planed to prove function before pulling off the bumper.
So now I have everything connected correctly ( pins 6 (transparent) & 12(black) on Blue connector, Brown to gnd, Red to +12 & yellow to reversing light.
VCDS coded on Steer/Park to "RVC fitted" and also on 5f infotainment to RVC fitted.
I have seen several references to this coding and it appears to be all that is needed.
But still no joy. When I re-coded and put into reverse, I got the correct revised screen layout, but no image: black space where an RVC image should be. Then I realised the hatch was not shut, so closed it fully, in case it expected that closed. Unfortunately it then reverted to the "Park Assist not available" message. I coded, uncoded, checked wiring multiple times, but no progress.
I am beginning to think I have a dodgy camera. I am suspicious of Vag-tec as while the website is lovely, I think it's a chap in Poland in a shed. (nothing wrong with that, but this chap does not reply to email...)
Thanks All!!
FiftyPlus
Post by FiftyPlus »
Just to wrap this up, I returned this kit & received a refund. The fact of incorrect connection details supplied with the item, a used part delivered (being sold as a new OEM VW item), and overall lack of clarity left me with no faith in the items supplied.
This I did not know if I was chasing a real problem, or working with a faulty item.
Does anyone have a recommendation of a decent supplier of a POLO 6C RVC, at a reasonable price?
Thanks!!
Dink
Drives: 2015 GTI
Post by Dink »
FiftyPlus wrote: Sun Jun 02, 2019 3:43 pm Just to wrap this up, I returned this kit & received a refund. The fact of incorrect connection details supplied with the item, a used part delivered (being sold as a new OEM VW item), and overall lack of clarity left me with no faith in the items supplied.
Thanks!!
https://www.carsystems.eu/new-vw-polo-6 ... d1673.html
it is another polish company but don't try hide the fact and you can see there building on google maps.
i have the low line camera and thinking of changing to the one in the boot lid as the one in the bumper is useless when wet/dirty
belastingdienst
Drives: 6C GTI
Post by belastingdienst »
might be slightly off topic, but does anyone know what the partnumber is of the flip logo camera that is used to retrofit on a polo 6C? carsystems have it but do not mention the partnumber. It's not a golf 6 fliplogo camera either as they do not match, but have the same fit?
Golf 7 logo should work
CNK
Drives: 6R
Post by CNK »
iichel wrote: Wed Jun 05, 2019 2:53 pm Golf 7 logo should work
but you need different logo, eg. Passat B8, T-Roc, Polo AW, not from Golf 7 because it's thicker in the middle (Golf 7 has a crease on the tailgate):
Golf 7:
Passat B8:
the emblem with black mounting part is possible to replace:
black mounting part is bolted with about 3 screws
this is part number of emblem from Passat B8: 510853617A
belastingdienst
Drives: 6C GTI
thank you for your reply CNK, I have a Polo 6C, is the passat b8 handle the same? Or can I just replace the current one I have on my polo with a golf 7 emblem camera and buy a bracket to be done with it?
CNK
Drives: 6R
Post by CNK »
Passat B8's logo is the same like in Polo AW/T-Roc, but Passat B8 has HighLine camera:
and need special adaptations to work properly:
Polo AW has Lowline camera so it's plug&play, only required little coding.
Golf 7 has also Lowline camera, but different logo because of tailgate, but you can use Golf 7 wiring ;-)
