monkeyhanger wrote: ↑Sun Apr 28, 2019 9:46 pm
One plug on the boxes you have? Sounds like the enhancement will be pretty crude with only one channel input unless the one input is the OBD port.
I've had a very crude box on my Golf GTD (TDI Tuning) which massively overfuelled on every level of throttle input. The DTUK box was much more refined. Maybe therein lies the 1st gear S mode wheel spin problem? Too much fuel too early? Or the tyres aren't up to the job of providing enough grip to rein in tramping?
If not through the OBD port, what is your one lead altering? Fuel rail or boost sensor?
If the box hasn't caused any fault codes to have lit anything up in the dash, it's unlikely you'll get busted for having used the box. They will only investigate a fault and look deeper (they won't scan every courtesy car on return if there's no reason to scan - too much time and expense).
If it does throw up a fault code related to engine management or gearbox then they will discover that you've used a box. That'll cost you your drive train warranty on your own car if it happens on that.
While using their car with your box on, you are invalidating any insurance policy covering you to drive the car.
For different engines, there is different types of harness. For the Gti, it's a two plug harness. For example a Volvo D5 has a six plug harness.
The one plug is the boost sensor on the pipe just after the turbo.
Like I said, this one in particular, I haven't run on the dyno being a Sunday. But I have been using these boxes for the past 5 years and so far no problems starting with a 0.9 litre Renault engine, going all the way up to the current M5 boosting it from 625 HP up to 677 HP on the dyno, all within the current Euro 6 Spec and with a TUV certificate. So I don't think the overfuelling is a problem... Too much fuel too early, would flood the engine and best case scenario, it would be jerking like a toddler's rattle. The boost increase is adjustable on the digital boxes and I ran the entire range of settings from 0,05 up to 0,2 bar increase without throwing an error code. That simply means, that all was done within VW safety margin and personally I don't see a problem with that.
As far as the dealer is concerned, since the owner is a friend of mine, I will specifically ask him to scan the car... so we'll see
BMW dealer, with which I cooperate, told me straight: if they suspect that the car had a box, they will tell the customer in their own convincing way, that the car had a box, but if he customer does not give in and admit to it, then there is no legal way of proving it in court.
As far as insurance is concerned, maybe that is the case where you live, but there is still a lot of places around the globe, where that makes absolutely no difference
If the car throws a code, that is no proof that a box has been used. Nobody will tell me that if you don't use a box, you will not have a code thrown at you for other reasons. Let's see what VW says
