Hello gents!
I have IBIZA IV 6J 2009 – “almost” POLO 6R.
Ibiza with ESP, angle sensor, Fog lights (cornering lights), without RLS. Engine BXW
According to tutorials from this forum (concerning POLO) I wanted to make BCM upgrade and add RLS and AUTO lights.
In Ibiza I had BCM 6R0937087, I’ve bought 7H0937090B
I made new wirings according to wiring diagrams from ELSA (for IC, switch and lights, no RLS yet) . After upgrade all lights work. No errors.
Unfortunately after replacing BCM I found one serious problem.
After assembling 7H0937090B, using VCDS I cannot connect to controller of Engine. I thought that BCM is damaged, I borrowed other 7H0937090 and found the same situation – not possible to connect to controller.
VCDS (original) trying to connect to the engine – feedback – “questionable protocol” or “no response from controller”. Rest of controllers I can connect via CAN without any problems.
I used other device ELM 327 – the same situation.
With 6R0937087 that problem doesn’t appear – I can connect to the engine.
What is going on?
Regards
Tom
After BCM upgrade – problem
kowaltom99
- Drives: SEAT IBIZA IV
Re: After BCM upgrade – problem
Do you maybe have a scan of the rest of the car?
kowaltom99
Hi
Below autoscan before BCM upgrade with original BCM 6R0937087
Unfortunately after changing BCM to 7H0937090B I cannot make autoscan.
Autoscan stops, because VCDS cannot connect to 01 Engine
What is strange, when I try to enetr OBDII mode in VCDS (with 7H0937090B) - I receive feedback "questionable protocol"
Chassis Type: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 4B 56
4B-Multifunc. Module -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine Labels: 03C-906-024-BXW.lbl
Part No SW: 03C 906 024 BK HW: 03C 906 024 BK
Component: BXW MM4HV G 3474
Revision: --H11--- Serial number:
Coding: 0000071
Shop #: WSC 06402 785 00200
VCID: 68D5E6725873DD04B0-5178
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 H HW: 6R0 907 379 H
Component: ESP8.2i front H04 0005
Revision: --------
Coding: 110228DB016D00B3882514E380D300401300
Shop #: WSC 04941 000 00000
VCID: 438F11DEC695DE5C45-8016
Address 08: Auto HVAC Labels: 6J0-820-045.clb
Part No SW: 6J0 820 045 HW: 6J0 820 045
Component: J301 Klimaanlage 0280
Revision: 00 23 08 Serial number: 0000000074211-
Shop #: WSC 00000 000 00000
VCID: 63CFF15EA255BE5C65-8036
Part No SW: 6R0 937 087 HW: 6R0 937 087
Component: PQ25 BCM H07 0012
Revision: BF007001 Serial number: 9425B333080762
Coding: 3C8829A8A8610100002000007E2B1CC8B0C040FF608C00402000
Shop #: WSC 64564 324 38760
VCID: 7AF1AC3AF5DF5F9456-802E
Subsystem 1 - Part No SW: 6R0 959 801 HW: 6R0 959 801 Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 001 0247
Coding: 020000
Subsystem 2 - Part No SW: 6R0 959 802 B HW: 6R0 959 802 B Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 001 0251
Coding: 020000
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10AirbagA01 H08 0018
Revision: -------- Serial number: 003000000000
Coding: 003031
Shop #: WSC 06401 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 428114DAD58FD7544E-8016
Serial number: 3492ERB402L7IPVCNC1B
Serial number: 3502ERB402J85LSIT42U
Address 17: Instruments (J285) Labels:| User\5K0-920-xxx-17.lbl-SRI1
Part No SW: 6J0 920 800 K HW: 6J0 920 800 K
Component: KOMBI 017 0018
Coding: 110A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
VCID: 2E59506A71174334BA-807A
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 0012
Coding: 422000
VCID: 70E58E12A3A315C4E8-8024
Address 25: Immobilizer (J334) Labels:. User\5K0-920-xxx-25.lbl
Component: IMMO 017 0018
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
ROD: EV_Immo_UDS_VDD_RM09.rod
Part No: 6R0 423 156
Component: LenkhilfeTRW V272
Coding: 10111
Shop #: WSC 06402
VCID: 6DDB97662091F82CC3-8038
Address 4B: Multifunc. Module Labels: 6J0-959-441.clb
Part No: 6J0 959 441
Component: MF-Modul 0007 0001
Coding: 0000001
Shop #: WSC 77005 000 00000
VCID: 70E58E1263A315C4E8-8024
Address 56: Radio (J503) Labels:. 6J0-035-153.clb
Part No SW: 6J0 035 153 HW: 6J0 035 153
Component: Radio 009 0025
Revision: R0009000 Serial number: SEZAZ1H7219297
Coding: 0501040002
VCID: 61C3FB567849AC4C77-8034
End-------------------------(Elapsed Time: 02:42)--------------------------
- Franciswat
- Drives: 6R 1.6 Bifuel
I had similar problem with my Polo 6R; I was no more able to autoscan engine because I always got an "engine cannot be reached" error (but anyway autoscan still goes on with the rest of addresses). Please take a look here to last ciclo's post. I solved that issue thanks to his solutions:
viewtopic.php?f=56&t=70398&start=150
kowaltom99
I finally solved the problem. I've read on Spanish Seat forum, that sometimes newer CAN gateway has a problem with connection to older modules (e. g. engine).
I've bought older BCM 7H0937089D.
I've changed back CAN wires from IC to BCM. After replacing BCM - everything works well. No errors, I can make full autoscan using VCDS.
It seems that BCM 7H0937090B was too new for my car (my car is 2008).
I have original light swith AUTO from Seat Ibiza - this weekend the final assembling - adding Auto light mode.
