Pops out of 5th when accelerating
cannonfodder4j
Drives: 1.4
Post by cannonfodder4j »
Hey everyone
99 POLO 1.4 with 135k miles
the car recently developed this issue that when i accelerate, in fifth gear, the shifter will pop into neutral. i have no issues with the other gears. i changed the gear oil to some fresh 75w/90 last week with no improvement. i didnt see and bits of metal in the waste oil either.
has anyone else faced a similar issue?
am i looking at a new transmission/rebuild?
tia
cannonfodder4j
Drives: 1.4
Re: Pops out of 5th when accelerating
does anyone know if a golf 2001 uses the same gearbox?
cannonfodder4j
Drives: 1.4
or polo 2005?
alexperkins
Site Admin
Post by alexperkins »
The polos have a fairly specific gearbox. Have you tryed adjusting the linkage? What gearbox code have you got
Mk4Maze
Drives: Mk4
Post by Mk4Maze »
Normally I say gearbox overhaul did it ran with enough oil in cause when it pops out without any grinding noise I say adjust but I think I ran with to less of oil to cool and and lubricate 5th gear.
And other gearboxes do fit but polo mk4 or lupo arosa best thing overhaul the original one commen problem seal that leaks where the linkage goes in the gearbox
cannonfodder4j
Drives: 1.4
its an 085
alexperkins
Site Admin
You need the three letter code. 085 is the series but there’s a code like DXB stamped on the bottom of the gearbox which identifies it
