ciclo's Polo. R-line 1.2 TSI 90hp 119gr.
Under tests.
I already advance that it is necessary to code the BCM.
It is even possible that I have to return to the original ballasts.
Until the tests are finished I will not answer any questions by private message or any other communication way.
55W ballasts Tests, and new OSRAM CBI xenon lamps
55W ballasts Tests (summary)
- Once the new 55W ballasts are installed, no errors are detected in the BCM.
- In the process of starting the xenon lamps, or each time you switch between HB/LB, the xenon lamp of the left headlight has a fast but dim flicker in the projected beam center, which is extraordinarily annoying.
- It was not possible to get rid of this flickering after trying several codings in the BCM.
- I don't see any improvement in the light beam brightness with respect to the original 35W ballasts.
Final decision:
- 55W ballasts discarded. Reinstalled original ballasts. ...
New OSRAM CBI xenon lamps
- Everything works correctly once installed, they're slightly whiter than the original xenon lamps.
- I don't appreciate significant improvements with respect to the original xenon lamps, maybe the lighting has improved slightly due to the cleaning of the lenses (see previous post) by the way, the projector can not be disassembled (ELSA).
It is necessary to adjust the light patterns each time the headlight is removed.
Bosch HTD 815 digital headlight tester
L
H
Yellow (truck) vs 'White' (my 6R)
Wall. Low
Wall. High
What a s**t of pictures.
Final decision:
L
H
Wall. Low
Wall. High
viewtopic.php?f=56&t=70775&sid=9bef8b38 ... 75#p556619
Thanks Adam, you're great!
Security access accepted by the BCM and the virtual GW (PQ25), 7E0 937 090C.
IIRC (some time ago) Alexander (aka firegrafik) did a reading of the BCM eeprom with VCP in engineer mode with this or another security access ... (a deep study he did and he sent me by email ).
For example, it could be useful to know if updating/loading the data set for MKE (fatigue detection) was done correctly, or to modify some data if necessary ...
Because the menu 'Assistants' with 'Fatigue detection' in our MFD/instrument clusters works with a PQ35 gateway in the test bench,
Slavik picture.
... as it does for the VW T6 PQ25, (coffe)
... but at the moment it does not appear in our MFD (T5, 6R, Fabia...)
... even though it works correctly.
aadriver picture.
Slavik picture.
aadriver picture.
Fatigue detection menu. Assistants. (PQ25.. 6R, T5, etc)
T5.1
Fatigue Detection (7E0 BCM, PQ25) How to do it.
Data set to load in the GATEWAY with ODIS-E
https://drive.google.com/file/d/1K8yhjy ... sp=sharing
Coding
19 Gateway... Byte2 Bit2 (04 HEX)
09 BCM... Byte25 Bit2 (04 HEX)
All my thanks to all who made it possible.
Tuesday,11,June,2019,03:33:41:32438
VCDS Version: 19.6.0.2 (x64) HEX-V2 CB: 0.4505.4
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO License Plate: FATIGUE DETECTION. IC menu ☕✅
Mileage: 40750km-25320mi Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 37 44 55 56 65 77
VIN: WVWZZZ6RZDY0CICLO Mileage: 40750km-25320miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZC) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 GD HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 5466
Revision: --H10--- Serial number: 00000000000000
Coding: 001100D6202400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
VCID: 6A8D3FD44CF80237745-803E
Readiness: 0110 0101
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BE HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3216D00B5842814EA84D300401700
Shop #: WSC 40308 002 104857
VCID: 025D77745448FA77DC5-8056
Serial number: 08021613470174
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5038420709E97B8D-802A
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 3829D59C425460A7321-806C
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 122170091
Coding: 3CB02FBF48E12400B3380F317CEB9FD05AC0670F600D30D0200400030800
Shop #: WSC 00046 648 00255
VCID: 2B03FAD08302DB3F4F3-807E
Component: RLHS 220816 0 42 0106
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8612
Coding: 1000A3
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
Subsystem 7 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-DC1 H03 0103
Serial number: 27140003142720054516
Coding: A4FFFF
Subsystem 8 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU003051200017821
Coding: 18BC32
Subsystem 9 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU010051200012315
Coding: 18BC32
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 AA HW: 7N0 919 475
Component: PARKHILFE 8K H06 0212
Revision: -------- Serial number: 28231708304294
Coding: 308001
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_VW75XParkAssis8K 001012
VCID: 71BF28B8612EF1EF35F-8024
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX01JKVVP
Coding: 00314D
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4ACD9F542C38E237545-801E
Serial number: 3575HRB405N1C4LI7929
Serial number: 3585HRB405B1D5MS8GS2
Serial number: 3515RRB405B17ABS901.
Serial number: 3525RRB405B181TUDPKC
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H04 0805
Coding: 140E01
Shop #: WSC 00233 572 00255
VCID: 47CBA6603F2A1F5F4BB-8012
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 002204
VCID: 688945DC52743027621-803C
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 0404000000000000000000
Shop #: WSC 03607 002 104857
VCID: 2E05F3C4B090AE1768D-807A
Component: IMMO H04 0805
Shop #: WSC 00000 000 00000
ROD: EV_Immo_UDS_VDD_RM09.rod
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0530
Revision: A1001003 Serial number: 7662584630
Coding: 010100
VCID: 2A0DFFD48CF8C237B45-807E
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 C
Component: RNS-MID H06 5274
Revision: AB001001 Serial number: VWZ6Z7L7654213
Coding: 04000442040000A10001
Shop #: WSC 12345 123 12345
VCID: 372BD6A04F4A6FDF3BB-8062
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V15 8515
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11221
Shop #: WSC 00788
VCID: 2F3BEEC0BE5AA71F63B-807A
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0112000001000000
VCID: 77AB16A00F4AAFDFFBB-8022
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 40000000050821
ROD: EV_RDKBERU30_005.rod
VCID: 372BD6A04FCA6FDF3BB-8062
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 L HW: 7P6 035 730 L
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664158506
Coding: 0501000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3B23CA9073E24BBFDF3-806E
End----------(Elapsed Time: 02:00, VBatt start/end: 14.1V/14.1V)-----------
T5.1
Coding
Clarification to avoid possible confusion:
Well, the MKE data set file for PQ25 is the same for all BCMs 7E0, (), B, C, D, with security access 30724 !!!
It is not necessary to make a new MKE data set file with security access 84244, this security access allows the reading of BCM EEPROM with VCP.
84244 was a security access that Adam found with the VCP, but it is not related to MKE.
I loaded the data set with ODIS-E.
Adam did it with VCP using the file converter.
You know, my English is not perfect, and the Google translator you use is not perfect either.
I'm going to improve my two front ambient lights.
Reason: some envy of the ambient lights of our Golf mk7.5
New lights.
Current status to improve.
New lights.
Hole: 24x10 mm
Correct as necessary.
Once installed 5TA 947 409 LED lights.
They are perfect as 'ambient lights' for my POLO 6R , I have my doubts that they can be correct as 'footwell lights' for POLO AW.
Coffee
After a trip of 2000Kms, on the way back, between 1600 and 1800 kms appeared the coffee with a 'gong', was established in the menu 'VEHICLE STATUS' MFD 0705sw --> (where are the service/inspection, tire pressure, events), reappeared after approximately 15 minutes of driving. I stopped to have a coffee , when returning to drive the fatigue detection notification was no longer present in the menu.
I made previous stops on the return trip, so I estimate that the coffee appears between 200-400 kms.
Friday,05,July,2019,08:35:33:32438
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
www.Ross-Tech.com
Mileage: 43140km-26805mi Repair Order:
VIN: WVWZZZ6RZDY0CICLO Mileage: 43140km-26805miles
VCID: 6A8D3FD44CF8023774D-803E
Revision: --------
VCID: 025D77745448FA77DCD-8056
Coding: 01
VCID: 7EA5038420709E97B85-802A
Revision: V0000000
VCID: 3829D59C425460A7329-806C
Coding: 3CB02FBF48E12400B3380F317CEB9FD05AC0670F600D39D0220400030800
VCID: 2B03FAD08302DB3F4FB-807E
Coding: 0728DD
Coding: 0200A3
Coding: 1000A3
Coding: A4FFFF
Coding: 18BC32
Coding: 18BC32
Coding: 308001
VCID: 71BF28B8612EF1EF357-8024
Coding: 00314D
VCID: 4ACD9F542C38E23754D-801E
Coding: 140E01
VCID: 47CBA6603F2A1F5F4B3-8012
Revision: B9082001
Coding: 002204
VCID: 688945DC52743027629-803C
Revision: AA001001
VCID: 2E05F3C4B090AE17685-807A
Coding: 010100
VCID: 2A0DFFD48CF8C237B4D-807E
VCID: 372BD6A04F4A6FDF3B3-8062
Coding: 11221
Shop #: WSC 00788
VCID: 2F3BEEC0BE5AA71F633-807A
VCID: 77AB16A00F4AAFDFFB3-8022
VCID: 372BD6A04FCA6FDF3B3-8062
VCID: 3B23CA9073E24BBFDFB-806E
End----------(Elapsed Time: 02:00, VBatt start/end: 13.8V/13.9V)-----------
SW:7E0-937-090-C HW:7E0-937-090-C --- Cent. Elect.
Component:BCM PQ25 Max4 H82 0752, Coding:3CB02FBF48E12400B3380F317CEB9FD05AC0670F600D39D0220400030800
Friday,05,July,2019,08:40:51:32438
VCDS Version: Release 19.6.1 (x64) Data version: 20190529 DS308.0
Channel,,Field 1,Field 2,Field 3,Field 4,
01,0,N/A,N/A,N/A,N/A,
02,,ERROR:,Channel 02,Not,Available,
03,1,N/A,N/A,N/A,N/A,
04,1,N/A,N/A,N/A,N/A,
05,0,N/A,N/A,N/A,N/A,
06,0,N/A,N/A,N/A,N/A,
07,0,N/A,N/A,N/A,N/A,
08,1,N/A,N/A,N/A,N/A,
09,0,N/A,N/A,N/A,N/A,
10,0,N/A,N/A,N/A,N/A,
11,0,N/A,N/A,N/A,N/A,
12,1,N/A,N/A,N/A,N/A,
13,1,N/A,N/A,N/A,N/A,
14,0,N/A,N/A,N/A,N/A,
15,0,N/A,N/A,N/A,N/A,
16,,ERROR:,Channel 16,Not,Available,
17,,ERROR:,Channel 17,Not,Available,
18,,ERROR:,Channel 18,Not,Available,
19,,ERROR:,Channel 19,Not,Available,
20,1,N/A,N/A,N/A,N/A,
21,,ERROR:,Channel 21,Not,Available,
22,1,N/A,N/A,N/A,N/A,
23,1,N/A,N/A,N/A,N/A,
24,0,N/A,N/A,N/A,N/A,
25,0,N/A,N/A,N/A,N/A,
26,1,N/A,N/A,N/A,N/A,
27,0,N/A,N/A,N/A,N/A,
28,1,N/A,N/A,N/A,N/A,
29,1,N/A,N/A,N/A,N/A,
30,2,N/A,N/A,N/A,N/A,
31,0,N/A,N/A,N/A,N/A,
32,80,N/A,N/A,N/A,N/A,
33,60,N/A,N/A,N/A,N/A,
34,20,N/A,N/A,N/A,N/A,
35,1,N/A,N/A,N/A,N/A,
36,2,N/A,N/A,N/A,N/A,
37,100,N/A,N/A,N/A,N/A,
38,21,N/A,N/A,N/A,N/A,
39,15,N/A,N/A,N/A,N/A,
40,14,N/A,N/A,N/A,N/A,
41,20,N/A,N/A,N/A,N/A,
42,5,N/A,N/A,N/A,N/A,
43,5,N/A,N/A,N/A,N/A,
44,5,N/A,N/A,N/A,N/A,
45,100,N/A,N/A,N/A,N/A,
46,1,N/A,N/A,N/A,N/A,
47,15,N/A,N/A,N/A,N/A,
48,15,N/A,N/A,N/A,N/A,
49,,ERROR:,Channel 49,Not,Available,
50,0,N/A,N/A,N/A,N/A,
51,0,N/A,N/A,N/A,N/A,
52,0,N/A,N/A,N/A,N/A,
53,1,N/A,N/A,N/A,N/A,
54,1,N/A,N/A,N/A,N/A,
55,0,N/A,N/A,N/A,N/A,
56,0,N/A,N/A,N/A,N/A,
57,0,N/A,N/A,N/A,N/A,
58,0,N/A,N/A,N/A,N/A,
59,1,N/A,N/A,N/A,N/A,
60,200,N/A,N/A,N/A,N/A,
61,200,N/A,N/A,N/A,N/A,
62,,ERROR:,Channel 62,Not,Available,
63,21,N/A,N/A,N/A,N/A,
64,0,N/A,N/A,N/A,N/A,
65,0,N/A,N/A,N/A,N/A,
66,3,N/A,N/A,N/A,N/A,
67,8,N/A,N/A,N/A,N/A,
68,1,N/A,N/A,N/A,N/A,
69,0,N/A,N/A,N/A,N/A,
70,20,N/A,N/A,N/A,N/A,
71,0,N/A,N/A,N/A,N/A,
72,0,N/A,N/A,N/A,N/A,
73,1,N/A,N/A,N/A,N/A,
74,0,N/A,N/A,N/A,N/A,
75,0,N/A,N/A,N/A,N/A,
76,0,N/A,N/A,N/A,N/A,
77,0,N/A,N/A,N/A,N/A,
78,1,N/A,N/A,N/A,N/A,
79,255,N/A,N/A,N/A,N/A,
80,1,N/A,N/A,N/A,N/A,
81,0,N/A,N/A,N/A,N/A,
82,0,N/A,N/A,N/A,N/A,
83,1,N/A,N/A,N/A,N/A,
84,0,N/A,N/A,N/A,N/A,
85,0,N/A,N/A,N/A,N/A,
86,0,N/A,N/A,N/A,N/A,
87,0,N/A,N/A,N/A,N/A,
88,0,N/A,N/A,N/A,N/A,
89,0,N/A,N/A,N/A,N/A,
90,0,N/A,N/A,N/A,N/A,
91,0,N/A,N/A,N/A,N/A,
92,0,N/A,N/A,N/A,N/A,
93,0,N/A,N/A,N/A,N/A,
94,0,N/A,N/A,N/A,N/A,
95,0,N/A,N/A,N/A,N/A,
96,0,N/A,N/A,N/A,N/A,
97,0,N/A,N/A,N/A,N/A,
98,,ERROR:,Channel 98,Not,Available,
99,0,N/A,N/A,N/A,N/A,
100,,ERROR:,Channel 100,Not,Available,
Info
The coding for my RLHS 5K7 955 547 is rejected with this last VCDS version, that is, I was trying to change the coding and the new coding (0628DD) was rejected.
For sale:
More info here A- Automatic lights wiring + CH/LH
- I made this wiring (in addition to this one) to end the stock of material that I had stored.
- I had this material stored as a precaution in case I had to support someone who bought my wiring looms and would make mistakes during its installation. After all the electrical installations were made successfully it makes no sense to have this material stored. Just that.✌
Interesting thread, Seat Ibiza PQ25. BCM Max & Automatic lights.
viewtopic.php?f=40&t=73130#p555509
Maybe it's possible, I've seen it work correctly in another 6R 1.2 TSI CBZ , more information in September ...
Until then, enjoy your vacations!
5K7 955 547 RLHS
0728DD
New coding
0228DD
- Highway light function (keep up speed 110Km/h for a while). Deactivated.
- Rain closing. Deactivated.
Byte0
Codings accepted!
0728DD
0428DD
0228DD
Coding rejected!
0628DD
;D
0728DD
New coding
0228DD
Byte0
Codings accepted!
0728DD
0428DD
0228DD
Coding rejected!
0628DD
Saturday,10,August,2019,21:16:16:32438
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO License Plate: RLHS 0228DD
Mileage: 43440km-26992mi Repair Order:
VIN: WVWZZZ6RZDY0CICLO Mileage: 43440km-26992miles
Revision: --------
Coding: 01
Revision: V0000000
Part No SW: 7E0 937 090 D HW: 7E0 937 090 D
Component: BCM PQ25 Max4 H82 0762
Revision: B9082001 Serial number: 8602 116190116
VCID: 2C01F9CC860CDC07461-8078
Coding: 0228DD
Coding: 0200A3
Coding: 1000A3
Coding: A4FFFF
Coding: 18BC32
Coding: 18BC32
Coding: 308001
Coding: 00314D
Coding: 140E01
Part No SW: 7E0 909 901 HW: 7E0 937 090 D
Component: GW-K-CAN TP20 H82 0762
Revision: B9082001
Coding: 002204
Revision: AA001001
Coding: 010100
Coding: 11250
Shop #: WSC 00788
End----------(Elapsed Time: 02:00, VBatt start/end: 13.9V/13.9V)-----------
MAPS update. Volkswagen RNS 510 CY Europa West V16 CD_8536
https://gpsunderground.com/forum/forum/ ... a-west-v16
Works great!
Monday,12,August,2019,07:12:48:32438
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO License Plate: MAPS UPDATE V16 CD_8536
Mileage: 43540km-27054mi Repair Order:
VIN: WVWZZZ6RZDY0CICLO Mileage: 43540km-27054miles
Revision: --------
Coding: 01
Revision: V0000000
Coding: 0228DD
Coding: 0200A3
Coding: 1000A3
Coding: A4FFFF
Coding: 18BC32
Coding: 18BC32
Coding: 308001
Coding: 00314D
Coding: 140E01
Revision: B9082001
Coding: 002204
Revision: AA001001
Coding: 010100
Component: EU West V16 8536
Coding: 11250
Shop #: WSC 00788
End----------(Elapsed Time: 02:00, VBatt start/end: 13.9V/13.8V)-----------
SW:7E0-937-090-D HW:7E0-937-090-D --- Cent. Elect.
Component:BCM PQ25 Max4 H82 0762, Coding:3CB02FBF48E12400B3380F317CEB9FD05AC0670F600D39D0220400030800
Thursday,08,August,2019,14:28:20:32438
47,20,N/A,N/A,N/A,N/A,
48,20,N/A,N/A,N/A,N/A,
51,1,N/A,N/A,N/A,N/A,
92,1,N/A,N/A,N/A,N/A,
93,21,N/A,N/A,N/A,N/A,
