Air con not working right? Replace the V68 motor - HOW TO.
littlepolo
Re: Air con not working right? Replace the V68 motor - HOW TO.
Post by littlepolo »
Surgery complete.
One thing to note is the connector assembly and pot can be lifted out together (see photos). I only discovered this after leveraging out the pot on the old motor. I used a marker pen to indicate the position of the gear on the original casing and ensured it was realigned on assembly with the new parts.
Reconnected the plug before reinstalling and checked operation. It appears the motor only goes from cold to open and nothing in between (at least I cannot hear it move in between those extremes). Is any kind of calibration needed?
Replaced the original large bracket without too much difficulty (the new one was not suitable at all).
alexperkins
Site Admin
Post by alexperkins »
Thats right. The air system on these is a bit of a strange beast
You will need to "calibrate" it within the AC controller by performing "basic settings" using VCDS or similar, doing that lets the AC controller know where the mechanical endstops for that flap are, so it drives the motor to each end, ie until it detects no further change in the voltage on the feedback potentiometer, logs it as one end stop, then drives in the other direction, then logs the other endstop. From then on, the furthest it will command that flap motor to move is between these two endstop limits.
alexperkins
Site Admin
Just noticed i totally bypassed the calibration questions lololol i blame lack of sleep
littlepolo
Do I need the full version of VCDS to do this?
alexperkins
Site Admin
No, free is sufficient. Basic settings on the appropriate group under Auto HVAC
JohnJT
Drives: Skoda rapid spaceback
Post by JohnJT »
Just created an account to post on here and say a massive thank you for this thread, I’ve got a Rapid Spaceback so not quite a Polo but had the same problem.
Couldn’t find anything anywhere about it, and any garage I went to said it was a full dash removal job and were talking £££££.
Managed to sort it out myself within an hour tonight, and after a year or so of playing the temperature roulette game I finally have fully selectable temperature again :lol:
littlepolo
I did basic settings and heard the motor moving as it went through the process.
It was hot today so I put the air con on, but no cold air. The air con sounded like it was working and it had been working recently.
Bother, next thing might be a recharge of R134A.
littlepolo
Would one of those kits from a high street retailer do the job?
Difficult to say, it will depend on how short in charge weight the system is, plus I think that some proper AC places or a mobile AC person might only charge the same to recover, weigh, vacuum, refilling that system.
littlepolo
Before going ahead with a regas/air con service I checked the data and found:
3 faults found:
01596 - Motor for Outside/Recirculated Air Flap (V154)
30-10 - Open or Short to Plus - Intermittent
41-10 - Blocked or No Voltage - Intermittent
29-10 - Short to Ground - Intermittent
Cleared the codes (cannot recall if they were there before I replaced the V68)
Did basic settings again.
Engine off
Voltage 12.10V, Fresh Air Blower (V2) Position 0.0V, Coolant Fan (Stage 1) OFF, Coolant Fan (Stage 2) OFF
Compressor Load 0.0%, Refrigerant Pressure (G65) 4.20 bar, Compressor Shut-Off 6.0, Temperature (G263 Evaporator) 20.0C
Engine on
Voltage 13.80V, Fresh Air Blower (V2) Position 6.50V, Coolant Fan (Stage 1) OFF, Coolant Fan (Stage 2) OFF
Compressor Load 82%, Refrigerant Pressure (G65) 5.0 bar, Compressor Shut-Off 0.0, Temperature (G263 Evaporator) 20.0C
Still no cold air.
littlepolo
Just checked for operation of the AC fan when the AC is running. No rotation.
Also had a recurrence of the following fault:
410-10 Blocked or No Voltage - Intermittent.
Edit:
Cleared the code and it has not yet returned.
Fans spin up on the output test.
littlepolo
Correction. Fans spin up initially on the output test but run for just a few seconds before stopping. The test does not proceed.
I've Googled and found this is symptomatic of fan resistor pack problems. That's one avenue to investigate.
littlepolo
I could not find any info on what the correct gas pressures should be for the Polo, but did find the attached chart which is generic for R134a.
On this basis, the 4.2 and 5.0 Bar (engine off/on) I measured is low for the high side.
Going to book in with an AC specialist
