For anyone coming from a 6C GTI DSG and wondering if its worth the upgrade then, based on my experience so far, it most certainly is! Clocked up 85 miles yesterday driving around the New Forest and surrounding area on a mix of roads. Here's a few of my initial observations...
The ride (in Normal) is a notable step up over the 6C GTI.
Build quality appears good. Doors and hatch all close easily with a satisfying clunk. The bonnet I noticed has two catches, one either side, rather than one in the middle.
Also noticed how much quieter it is inside. Wife commented that as a passenger she prefers the sound of the new one over the old one.
Impressed that it averaged 45.7mpg.
Extra space inside and in the boot is/will be a bonus.
The new arm rest is a major improvement. The old one was adjustable for hight via the ratcheted hinge but I found it always in the way of the handbrake so rarely used it. The new one, although not height adjustable (but OK for me), does slide fore and aft so doesn't impede the handbrake; a minor point but noticeable.
I also believe the standard air con works better in the new one than the old. I debated whether to opt for climate control or not and decided not to. Driving around yesterday in 30+ deg C, the standard system coped more than adequately.
Having ordered the car sight unseen I was unsure whether I'd like the red dash but now I have the car, those fears have gone!
Even on a tight engine you can tell it is eager to pull. Better that the 6C? Yes I'd say so. Probably due to the torque increase. The old 6C 7 speed DSG was torque limited over the manual. When it loosens up more I'm sure on-the-road acceleration will be better.
In summary then...
Do I regret buying it - Absolutely not.
Was it worth the wait? - 13 months is a long time but based on just the first 85 miles I'd have to say yes.
Am I impressed with the car? - Very much a yes.
Would I recommend the car to others - Most definitely.
