Rain Light Sensor, RLS, Volkswagen Vento
Jerryncg93
Drives: Volkswagen Vento 1.2 tsi
Post by Jerryncg93 »
Hi, seeking help on my installed RLS, 5K7 955 559B. I have installed the RLS accordingly, but the problem I have faced was the headlight will turn on, but other parts like instrument cluster and steering wheels light will not turn on.
Below photo are when auto mode, no instrument cluster and steering light. Manual mode is normal.
Also, now when I code it as 0728DD, it says coding accepted, but when open again, it's still the original code, is there anything wrong with my rls?
Please help :(
massimo23
Drives: Polo Beats 2017
Re: Rain Light Sensor, RLS, Volkswagen Vento
Post by massimo23 »
Have you set the rls options in 09 Central Electric?
Could you please attach a full autoscan?
BCM Byte27 Bit1
iichel wrote: Sat Aug 03, 2019 1:49 pm Could you please attach a full autoscan?
+1
Jerryncg93
Sure, here you go
Sunday,04,August,2019,19:59:07:39370
VCDS Version: 19.6.1.0 (x64)
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: PPVZZZ60ZHL000691 License Plate:
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 15 17 19 25 44 55 56
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 6270
Revision: --H10--- Serial number:
Coding: 00250056232400080000
Shop #: WSC 83300 833 00019
ASAM Dataset: EV_ECM1T2FS02103F906070KC 004006
ROD: N/A
VCID: 6DD1F044BC08342742-8038
No ASAM data for: "EV_ECM1T2FS02103F906070KC" (VW25)
Readiness: 0110 0101
Part No SW: 0AM 300 065 T HW: 0AM 927 769 F
Component: GSG DQ200G2_PQ 052 2501
Revision: 00005026 Serial number: CU501610166993
Coding: 0000020
VCID: 408F79F0131A094FD9-8014
Part No SW: 6R0 907 379 BN HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0001
Serial number: --------------
Coding: 62DD2C63412307C0461A34728252E0800908
VCID: 0B159EDCA2DC9A17FC-805E
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 41897CF4D8100047D6-8014
Part No SW: 7E0 937 089 A HW: 7E0 937 089
Component: BCM PQ25 MMI4 H81 0744
Revision: BB081001 Serial number: 0972 249160236
Coding: 3B904BBF08A12400133806007CEB969000C0604F60C53970210000000820
VCID: 31692C3468B090C726-8064
Subsystem 1 - Part No: 5K7 955 559 B
Component: RLS 111115 03 37 0059
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 802 DF HW: 6R0 959 802 DF
Component: J386__TSG_FT 022 1522
Serial number: 13102722161128150914
Subsystem 3 - Part No SW: 6R0 959 801 DD HW: 6R0 959 801 DD
Component: J387__TSG_BT 022 1522
Serial number: 13102723161128100109
Subsystem 4 - Part No: 6RU 951 171
Component: Sensor, DWA 0 005 0502
Subsystem 5 - Part No: 6RU 951 171
Subsystem 6 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Serial number: 3141607500501037AB2B
Coding: 240000
Subsystem 7 - Part No SW: 6R0 959 811 S HW: 6R0 959 811 S
Component: J388__TSG_HL 022 1522
Serial number: 13102728161128145629
Subsystem 8 - Part No SW: 6R0 959 812 S HW: 6R0 959 812 S
Component: J389__TSG_HR 022 1522
Serial number: 13102729161121011402
1 Fault Found
01504 - Bulb for License-Plate Light (X)
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 219
Mileage: 35217 km
Time Indication: 0
Date: 2016.05.23
Time: 19:55:12
Address 15: Airbags (J234) Labels: Redir Fail!
Component: VW10AirbagU0E H10 0020
Revision: -------- Serial number: 003GX02BDKZ4
Coding: 003045
Shop #: WSC 83300 833 00007
ASAM Dataset: EV_AirabVW10BPAVW250 A01001
ROD: N/A
VCID: 4A9B5BD8ED26C31F07-801E
Subsystem 1 - Serial number: 3495RRB40185735IJHJK
Subsystem 2 - Serial number: 3505RRB40185735IA9R3
No ASAM data for: "EV_AirabVW10BPAVW250" (VW25)
Address 17: Instruments (J285) Labels:. 5K0-920-xxx-17.clb
Part No SW: 6RF 920 861 B HW: 6RF 920 861 B
Component: KOMBI H01 0215
Coding: 140A000000
ASAM Dataset: EV_Kombi_UDS_DVD_RM09 A05729
ROD: N/A
No ASAM data for: "EV_Kombi_UDS_DVD_RM09" (VW36 *)
Part No SW: 7E0 909 901 HW: 7E0 937 089
Component: GW-K-CAN TP20 H81 0744
Revision: BB081001
Coding: 002300
VCID: 68DF81509BEA110F31-803C
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H01 0215
Serial number:
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_DVD_RM09 A03710
ROD: N/A
VCID: 6ADBFB588DE6231F27-803E
No ASAM data for: "EV_Immo_UDS_DVD_RM09" (VW36 *)
Address 44: Steering Assist (J500) Labels:. 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Coding: 0001000101000000
Shop #: WSC 83300 833 00009
ASAM Dataset: EV_SteerAssisSNK 014008
ROD: N/A
VCID: 41897CF4D0100047D6-8014
No ASAM data for: "EV_SteerAssisSNK" (VW25)
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 C HW: 6R0 907 357 B
Component: AFS-ECU 005 0050
Revision: -------- Serial number: --------------
Coding: 0D0C000001000000
ASAM Dataset: EV_HeadlRgeulVWLWRCC 002006
ROD: N/A
VCID: 3A7B0B18BDC6539F97-806E
No ASAM data for: "EV_HeadlRgeulVWLWRCC" (VW25)
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 541 5515
Revision: -------- Serial number: VWZZZ4J6270757
Coding: 16000440040005
Shop #: WSC 12345 123 61029
VCID: 46836FE8F13E277FE3-8012
End-------------------------(Elapsed Time: 02:50)--------------------------
I guess your VENTO has no dimmer for interior lights next to the light switch.
Jerryncg93
It's finally done! Thanks to a friend of mine Alvin, he instructed me to change the adaption channel 69, value change to 1. Wonderful!
Also thanks to Ciclo and iichel for sharing and teaching. :D :D
Now I've re-scan, here are the problems in the report.
Sunday,04,August,2019,22:56:39:39370
www.Ross-Tech.com
VIN: PPVZZZ60ZHL000691 Mileage: 35220km-21884miles
ASAM Dataset: EV_EMC12TFS02103F906070KC 004006
ROD: N/A
No ASAM data for: "EV_EMC12TFS02103F906070KC" (VW25)
Coding: 0000020
ASAM Dataset: EV_Brake1ESP9i0BOSCH 003031
ROD: N/A
No ASAM data for: "EV_Brake1ESP9i0BOSCH" (VW25)
Revision: V0000000
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 802 DF HW: 6R0 959 802 DF Labels: 6R0-959-802.CLB
Subsystem 3 - Part No SW: 6R0 959 801 DD HW: 6R0 959 801 DD Labels: 6R0-959-801.CLB
Coding: 240000
Address 15: Airbags (J234) Labels:. 5K0-959-655.clb
Coding: 003045
ASAM Dataset: EV_AirbaWV10BPAVW250 A01001
ROD: N/A
No ASAM data for: "EV_AirbaWV10BPAVW250" (VW25)
Coding: 140A000000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
Revision: BB081001
Coding: 002300
Serial number:
ROD: EV_Immo_UDS_VDD_RM09.rod
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
ROD: EV_SteerAssisNSK_014.rod
ROD: EV_HeadlRegulVWLWRCC.rod
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:49)--------------------------
Please advice :)
Congrats! 8)
I would like to have the original electrical diagrams from your Vento 2017 (IND), LED Headlights, to make some checks. Unfortunately I don't have it. :|
Jerryncg93
ciclo wrote: Sun Aug 04, 2019 10:22 pm Congrats! 8)
Can you show me some sample of the electrical diagrams you're looking for? I can't find it in my car's user manual. Maybe I'll ask the service center. :D
Easy:
- Diagram for the Light switch, T10/10 and all wire diagrams that link to T10/10.
- Diagrams for LED headlights. (BCM connections)
