CNK's Polo 6R 2.0 Shadow Blue
Re: CNK's Polo 6R 1.4 Shadow Blue
next teaser:
- Drives: 1.2TSI 105HP DSG7
great!!!
Thanks Amir!
You made me realize that my first thought about mounting this OEM double 2.0A charger is good.
Now I think about ambiente lights and still can't find nice solution for my Polo. My OEM front footlights have pernament plus, and switched GND (like other interior lights). I want to change it, because I need pernament minus, and one plus when door are opened (like in Golf 5) + second plus to ambiente (from additional relay from ciclo).
Is there a simple way to get a +12V after opening any door?
Or is there any way to get minus only when rest of interior lights are turned off?
Glad that we did talk too. Because of this, you give me lots new idea on the next mod[emoji41]. Cant wait to get the parts later!
Btw, on the permanent plus and minus, i think you will have to get new relay there as usual. But when the door is open, dont you think, there will be signals sent to fuel pump(driver door only i guess), IC and electric seat(although its not available on polo, surely T5/T6 got it) ?
As usual, with the help of Michel, I was able to make a conversion for the switched minus to the switched plus. I used 643 relay for this. Thanks to this relay, I will be able to connect permanent GND to the footwell lights. Today I did temporary installation and it works. Thanks a lot @iichel!
Hi, I probably will connect it when making other, bigger modifications.
So far I tested the charging and made a hole for assembly.
More photos: https://polo.blue/2019/08/05/polo-aw-20 ... surements/
I don't have any schemes from Polo AW 2020 MY but I have plan to connect this socket like people from motortalk - directly to 12V wires from the front lighter. There is something like radiator inside, and after half hour of working it was still cold.
- ag69
- Drives: 1.2TSi 77Kw 7DSG
CNK wrote: ↑Thu Aug 01, 2019 8:02 amHi, I probably will connect it when making other, bigger modifications.
More photos: https://photos.app.goo.gl/6p4BXyfRTywVngw29
Photos are amazing, felt like this was all in front of me.
Thanks for posting so many details, attention to details is top notch --vernier caliper --Cool
Hats off to you CNK (again) !!!
I am wondering how come you have not got an AC vents for rear (yet).
Though it would make things complex. ie AC Vents and USB ports and 12 V socket
Hi firegrafik,firegrafik wrote: ↑Mon Jan 15, 2018 7:02 pm iichel, there are some differences of the wires position for sure between 8,2 and 9,0. Many Polo sedan owners in Russia have the expirience with the wires replacement while retrofiting ABS8,2 to ESP9,0
Can you take a look ad this topic, I need some help.
https://www.uk-polos.net/viewtopic.php? ... 41#p559241
Thx
Ok, the installation of the USB charger in the armrest was successful. More information can be found in my posts on drive2:
Polo AW 2019+ double USB 2.0 charging port in Polo 6R armrest — teaser 1 (measurements)
Polo AW 2019+ double USB 2.0 charging port in Polo 6R armrest — teaser 2 (testing, cutting and fitting)
2G0035954 (2G0 035 954) — VW Polo AW 2019MY double USB charging port:
more changes coming soon...
Thank you very much for the information. Good job!
Reviewing your thread and your updates. I love this picture:
Szymon, do you have any links to Krzycho's Golf apart from this one where it is possible to see the swap from CECM to BCM?
I remember you told me a while ago, but now I can't find the links.
Thanks Fernando!
I can't find any active tutorial on vwgolfv.pl forum, probably @glodek removed it (https://www.vwgolfv.pl/viewtopic.php?f= ... cm#p241230), but I believe spacewalker also know something about this retrofit.
Here's something what I found quickly:
http://www.touranklub.pl/forum/viewtopi ... 15&t=13819 (spacewalker + VW Touran CECM + CCM BCM)
http://forum.octaviaclub.pl/forum/octav ... i-przed-fl (Skoda Octavia II)
Thank you very much again.
hi. nice polo. i got a 6c and i mounted the third bracke light on the boot lid from a vw golf mk7 black... it looks better... if you want i can show pictures to you... it fits perfect.
