We have had some heavy rain recently but the leak also occurs in normal amounts of rain. I believe I have found where the water is getting into the foot wells but cannot figure out why. I found the water seems to be seeping past a rubber bung which I would guess is to do the bonnet release for left hand drive models. There should be a picture of where I mean attached to this.
The problem is, I cant figure out how the water is getting into this section or why it builds up in there to the extent it is seeping past the rubber bung.
My initial thought after a lot of research into this was that the scuttle drains where blocked especially as when testing these did tend to take a while to drain away, however after cleaning these the best I can with the limited access I have it doesn't seem to have made any difference. the water drains form the scuttle quicker and out of the bottom of the car much better than before but water still seems to end up in the said hole.
The other thing I have tried is drilling a small hole next to the door hinge, behind the hole where the water is, to at least drain the water out of there before it can get into the cabin, but I haven't completed this as this section appears to be double skinned and if I drill through this internal centre layer, the water will end up in the sill which seems even worse to me.
I hope somebody can help because I'm completely out of ideas and am struggling to find anything else on the internet that helps me.
Also the car is a 2002 VW Polo 3dr with no sunroof.
Thanks,
Harry
