My Polo 1.2 TSI DSG
benzinkopf
- Drives: 1.2TSI 105HP DSG7
Re: My Polo 1.2 TSI DSG
hi albert/ciclo,ciclo wrote:I have not yet made this mod because the door panels are very expensive if you make a mistake when cuttingbut I rescue this interesting information (diagrams) that I published on the Italian forum to warning/illumination lights on the doors.
Driver door
Left and right rear doors
Front passenger door
Pictures (with your permission thealbert)![]()
+Supply from the connector on the unit window. (All is pin 16).
-Ground from the door contact. (see diagrams for exact pin each door).
In this way only turn on the light from the door which is opened.
from this guide, it means the supply for the door exit /warning light is from the wrm which is more than 12v (14v) with engine is running. I know if using normal bulb, theres no issue, but running the led door light means it will burn the led bulb with more than 12v. am i right? or is there solution for using led door light?
benzinkopf
what material is this and where did you source this and how you glued this? great mods and good!! i like.thealbert wrote:Hello guys, I write from Italy and I am a proud owner of three years of a 1.2 hub on which I made a few tweaks, I hope you like it!
As soon as I can I insert photos!
thealbert
- Drives: polo 6r 1.2 tsi dsg
Hello Ciclo, first of all thanks for answering me, I checked and as you said, my pin is missing pin 5, so what should I do?ciclo wrote:easy
Do I have to change the button?
Would you give me the link or the right button code?
Thank you
Inviato dal mio RNE-L21 utilizzando Tapatalk
thealbert
Hello, to do this job you need the adhesive carpet like this, you have to do before the cardboard shapes and then cut the carpet. In the photos you will find the shapes that I used with the measures in cmbenzinkopf wrote:what material is this and where did you source this and how you glued this? great mods and good!! i like.thealbert wrote:Hello guys, I write from Italy and I am a proud owner of three years of a 1.2 hub on which I made a few tweaks, I hope you like it!
thealbert
Until now, a led bulb has never been burnedbenzinkopf wrote:hi albert/ciclo,ciclo wrote:I have not yet made this mod because the door panels are very expensive if you make a mistake when cuttingbut I rescue this interesting information (diagrams) that I published on the Italian forum to warning/illumination lights on the doors.
Driver door
benzinkopf
Thanks albert for the reply. i will try soon[emoji1360]thealbert wrote:Until now, a led bulb has never been burnedbenzinkopf wrote:hi albert/ciclo,ciclo wrote:I have not yet made this mod because the door panels are very expensive if you make a mistake when cuttingbut I rescue this interesting information (diagrams) that I published on the Italian forum to warning/illumination lights on the doors.
Driver door
Hi, How did you install the foot rest pedal?
thealbert
Simple double-sided tape
thealbert
All solved thanks to the Ciclo help
thealbert
Before 108hp and 173nm and now 142hp and 220nm
TheLizardKing
- Drives: VW GT TSI 1.2
Hi ciclo,ciclo wrote: Mon Feb 02, 2015 2:39 am I have not yet made this mod because the door panels are very expensive if you make a mistake when cuttingbut I rescue this interesting information (diagrams) that I published on the Italian forum to warning/illumination lights on the doors.
I know that is a very old post, but it has all the information that I need to attempt this mod in my Polo 6C. I just need a little help with ordering the harnesses. There are two options on AliExpress:
1. Both terminals are box type, like here
1. One terminal is box type and the other is the regular pincer type, like here.
Which is the correct option for the Polo?
Also, will I need any VCDS coding to activate the lights once installed?
Thanks in advance.
There is no problem with the voltage when installing LED lights (12-14v). In fact it is better to install LED lights inside.
The necessary wiring depends on the model of the LED lamp you install, there is no specific wiring for the 6R, you must manufacture it or modify the one you bought. It is not necessary to code anything.
TheLizardKing
Thank you for your help. The supplied harnesses come with the required connector at the lamp end. I needed help with the type of terminals required for the connections at the WRM (+ve) and Door Lock Unitciclo wrote: Tue Sep 17, 2019 7:55 am There is no problem with the voltage when installing LED lights (12-14v). In fact it is better to install LED lights inside.
(GND) ends.
- ag69
- Drives: 1.2TSi 77Kw 7DSG
I assume you/we are talking about LED in doors. Instead of so called ERROR FREE LEDs, can we use the LED Strip SMD 3528 or SMD 5050 in a case? Can all these be used in interior for footwell and dome lights?ciclo wrote: Tue Sep 17, 2019 7:55 am There is no problem with the voltage when installing LED lights (12-14v). In fact it is better to install LED lights inside.
