Skoda Fabia VRS 2012. Auto lights retrofit OEM
Forum to discuss the Skoda Fabia
exantas
Drives: Skoda Fabia 5J 1.2 TSI
Re: Skoda Fabia VRS 2012. Auto lights retrofit OEM
Post by exantas »
VASILEIOS1972 wrote: Wed Oct 02, 2019 6:34 am Good morning my friend Fernando
You have absolutely right about the comfort function
Best regards
Vasileios
Can you please describe how you fixed it? In case someone else comes across the same issue
VASILEIOS1972
Drives: Polo 6R 1.2 tsi , Skoda Fabia 5J Vrs 1.4
Post by VASILEIOS1972 »
exantas wrote: Wed Oct 02, 2019 10:02 pm
Best regards
Vasileios
Good morning my friend , to fix this problem is easy.
All you have to do is press each window switch 4 times to go up and down the glass .
That's all .
Best regards
Vasilis
exantas
Post by exantas »
Best regards
Vasileios
That's all .
Best regards
Vasilis
Thanks for the answer
VASILEIOS1972
Hello master (Fernando) , polo 6r dimmer works fine with no problems or errors
photos above
VASILEIOS1972
Perfect! :wink:
Have you checked the headlights range regulator?
VASILEIOS1972
Hello Fernando , your help please with address 55 , autoscan above
Friday,04,October,2019,18:02:17:38567
VCDS Version: 19.6.2.0
Data version: 20190930 DS308.0
www.Ross-Tech.com
Workshop Code: 123 12345 012345
VIN: TMBEP25XXXXXXXXXX License Plate:
Mileage: 65020km-40401mi Repair Order: afs installation
Chassis Type: 5J-SK25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 37 44 55 56 0B
VIN: TMBEP25XXXXXXXXXX Mileage: 65020km-40401miles
55-Headlight Range -- Status: Cannot be reached 1100
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAVE) Labels:. 03C-907-309-V1.clb
Part No SW: 03C 906 027 CE HW: 03C 906 027 CE
Component: 1.4l R4 TSI H15 9971
Revision: L2H15--- Serial number:
Coding: 00250012002400000000
Shop #: WSC 53850 001 1048576
ASAM Dataset: EV_ECM14TSI01103C906027CE 001013
ROD: EV_ECM14TSI01103C906027CE.rod
VCID: 66C3ED1499F16A7F3D-8032
Readiness: 0000 0000
Part No SW: 0AM 300 060 A HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6563
Revision: 00043014 Serial number: TFK01108310139
Coding: 0000020
VCID: 285FA32C9B65BC0FCF-807C
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AL HW: 6R0 907 379 AF
Revision: --------
Coding: 410148DB437300B3822712E9C2D200411700
Shop #: WSC 13765 790 00049
VCID: 081FC3ACBFA59C0FEF-805C
Serial number: 25021504650800
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF3A574E161D2BFD5-802A
Address 08: Auto HVAC (J255) Labels: 6Q0-907-044.lbl
Part No SW: 5J0 907 044 C HW: 5J0 907 044 C
Component: Climatronic H08 0103
Revision: K0000000
VCID: 2A5B592445698E1FD9-807E
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 122170091
Coding: 7A980B3848010000013806B03EEB9BC052C0621F60002041200400020000
Shop #: WSC 12345 123 12345
VCID: 2B555C204A93971722-807E
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 230714 05 54 0403
Coding: 0230AD
Subsystem 2 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3211
Coding: 020000
Subsystem 3 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3211
Coding: 020000
Subsystem 4 - Part No SW: 3T0 959 537 E HW: 3T0 959 537 E
Component: E221__MFL-URO H07 0012
Serial number: 2164426
Coding: 810000
Subsystem 5 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3211
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3211
Coding: 020000
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 S HW: 7N0 919 475
Component: PARKHILFE 8K H06 0210
Revision: -------- Serial number: 28261530202208
Coding: 108101
Shop #: WSC 44700 231 72242
ASAM Dataset: EV_VW75XParkAssis8K 001011
VCID: 428B1184D519765FF1-8016
Component: VW10AirbagT20 H09 0020
Revision: -------- Serial number: 003GX00UUUCP
Coding: 003230
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9B39A4ED29AE1F39-801E
Serial number: 3495RRB40590NHDIJH62
Serial number: 3505RRB40590NHDIAOG2
Part No SW: 5J0 920 841 F HW: 5J0 920 841 F
Component: KOMBI H04 0305
Coding: 120C01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
VCID: 2D5152387C8799273C-8078
1 Fault Found:
13639168 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 228
Mileage: 65020 km
Date: 2019.10.04
Time: 17:58:20
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 032204
VCID: 68DFE32C9BE57C0F0F-803C
1 Fault Found:
01771 - Control Module for Headlight Range (J431)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 228
Mileage: 65020 km
Time Indication: 0
Date: 2014.02.24
Time: 17:57:04
Component: IMMO H04 0305
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADB99248DE94E1F19-803E
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 5JA 035 193 E HW: 5JA 035 193 E
Component: RNS315-EU H85 0501
Serial number: SKZAZ2R0659899
Coding: 040000110400000000000000
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: 3A7B6964BDC93E9FA9-806E
Data medium:
Subsystem 1 - Part No: 3AA 919 866
Component: EUR_W_V11 0073
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11241
Shop #: WSC 13765
VCID: 2F6D4830EA8BEB370E-807A
Address 55: Headlight Range
Cannot be reached
Address 0B: Sec. Air Heating Labels:
VCID: 55A1DAD8AC97F1E7A4-95D0
End-------------------------(Elapsed Time: 02:53)--------------------------
best regards
Vasilis
VASILEIOS1972
is it possible to tell me what to look ?
ciclo wrote: Fri Oct 04, 2019 1:34 pm
1. You should have done this check before installing the J745 unit.
2. Have you registered address 55 in the Gateway-address 19 installation list?
VASILEIOS1972
first of all yesterday headlight regulator works fine
yes I have insert in coding list of gateway address 55
VASILEIOS1972 wrote: Fri Oct 04, 2019 7:20 pm first of all yesterday headlight regulator works fine
OK.👍
Take pictures of how you connected the CAN lines for the J745 unit, in IC harness (old CAN lines) and T18 connector.
VASILEIOS1972
VASILEIOS1972
VASILEIOS1972
to be sure I have all ready change places for pin 13 and 14 in t18 , but the problems still exist
