Skoda Fabia VRS 2012. Auto lights retrofit OEM
Forum to discuss the Skoda Fabia
VASILEIOS1972
Drives: Polo 6R 1.2 tsi , Skoda Fabia 5J Vrs 1.4
Re: Skoda Fabia VRS 2012. Auto lights retrofit OEM
Post by VASILEIOS1972 »
ciclo wrote: Fri Oct 11, 2019 10:04 am According to ETKA it would be possible... btw.... have you learned to use it?
According to Elsawin, I don't know because I only have the wiring diagrams for Fabia II until 2013. I don't have them until 2015, which is when the Fabia II production for Europe was finished and that is when the 7H0937090D model was being installed.
The wiring diagrams for Sk Fabia II 2015 are necessary to know how to install this BCM.
Good evening Fernando, as I know my Fabias production stopped since 2014 .
Fabia 2015 is Fabia mk3 , I don't think that is the same platform .
Am I wrong ?
But from a small research that I have done , this bcm works on Fabias from 2011 since 2015, so the question is , why 2011 model must have differences in wiring diagrams with 2015 mk2 Fabia ?
VASILEIOS1972 wrote: Fri Oct 11, 2019 2:23 pm Good evening Fernando, as I know my Fabias production stopped since 2014 .
Fabia 2015 is Fabia mk3 and mk2 , I don't think that is the same platform .
Am I wrong ?
But from a small research that I have done , this bcm works on Fabias from 2011 since 2015, so the question is , why 2011 model must have differences in wiring diagrams with 2015 mk2 Fabia ? Evolution. HW, SW, parameterization according to peripheral units of the vehicle in which it is installed.
Currently, your Fabia VRS is ready for 7H0937090D, but minor setbacks may arise. You must experiment if we want to know what will happen with the J745 unit.
This is not an invitation to do it, it is my particular way of seeing the whole of this matter (due to lack of information).
VASILEIOS1972
Fernando you mean it is not needed downgrading to install 7H0937090D bcm ?
In my experience, the operation/wiring for 7H0937090D (I repeat D) is the same as for the 7E0 BCMs.
VASILEIOS1972
ciclo wrote: Fri Oct 11, 2019 7:31 pm In my experience, the operation/wiring for 7H0937090D (I repeat D) is the same as for the 7E0 BCMs.
so the only think that i have to do is to change the bcm , coding is the same like 7E0 ?
Even ETKA already warns that a physical inspection of the old BCM is necessary before placing an order.
This has a great meaning of how complicated it is to define all this.
Occultism? :lol: (just kidding)
I understand it perfectly, but I think the VW group was too thorough to develop this huge amount of BCMs for the large number of models for the PQ25 platform.
VASILEIOS1972 wrote: Fri Oct 11, 2019 7:48 pm
Supposedly, you have to try it to know.
I will no longer give you answers where I can be guilty of something ... :lol:
VASILEIOS1972
You know that I will never said anything bad about you.
In retrofits you must try and pay to have a success result.
Thank you for everything, I will report soon.
Best regards
Vasilis
:wink:
exantas
Drives: Skoda Fabia 5J 1.2 TSI
Post by exantas »
@Vasileios
What AFS module did you buy ?
5J0907357,5J0907357A or 5J0907357B
VASILEIOS1972
exantas wrote: Fri Oct 11, 2019 9:36 pm @Vasileios
Hello my friend , module part number is 5J0907357B .
Regards
Vasilis
VASILEIOS1972
Good evening Fernando, tell me is it possible Alex from Russia to help me find 7H0937090D bcm in descent pricet to make the test ?
Regards
Vasilis
VASILEIOS1972
Hello Fernando, tell me please
In 7H0 bcm I use the same long coding as 7E0 ?
Regards
Vasilis
VASILEIOS1972
update 7H0 autoscan above , same problem
032200Friday,18,October,2019,17:08:52:38567
VCDS Version: 19.6.2.0
Data version: 20190930 DS308.0
www.Ross-Tech.com
Workshop Code: 123 12345 012345
VIN: TMBEP25XXXXXXXXXX License Plate:
Mileage: 66140km-41097mi Repair Order: 7H0 bcm
Chassis Type: 5J-SK25 (6N0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 37 44 55 56 0B
VIN: TMBEP25ΧΧΧΧΧΧΧΧΧΧ Mileage: 66140km-41097miles
55-Headlight Range -- Status: Cannot be reached 1100
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAVE) Labels:. 03C-907-309-V1.clb
Part No SW: 03C 906 027 CE HW: 03C 906 027 CE
Component: 1.4l R4 TSI H15 9971
Revision: L2H15--- Serial number:
Coding: 00250012002400000000
Shop #: WSC 53850 001 1048576
ASAM Dataset: EV_ECM14TSI01103C906027CE 001013
ROD: EV_ECM14TSI01103C906027CE.rod
VCID: 66C3ED1499F16A7F3D-8032
Readiness: 0000 0000
Part No SW: 0AM 300 060 A HW: 0AM 927 769 D
Component: GSG DSG AG7 431 6563
Revision: 00043014 Serial number: TFK01108310139
Coding: 0000020
VCID: 285FA32C9B65BC0FCF-807C
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AL HW: 6R0 907 379 AF
Revision: --------
Coding: 410148DB437300B3822712E9C2D200411700
Shop #: WSC 13765 790 00049
VCID: 081FC3ACBFA59C0FEF-805C
Serial number: 25021504650800
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF3A574E161D2BFD5-802A
Address 08: Auto HVAC (J255) Labels: 6Q0-907-044.lbl
Part No SW: 5J0 907 044 C HW: 5J0 907 044 C
Component: Climatronic H08 0103
Revision: K0000000
VCID: 2A5B592445698E1FD9-807E
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 D HW: 7H0 937 090
Component: BCM PQ25 Max4 H78 0725
Revision: B9078001 Serial number: 0671 045150994
Coding: 7A980B3848010000013806B03EEB9BC052C0621F60002041200400020000
Shop #: WSC 12345 123 12345
VCID: 2F6D48307E8BEB370E-807A
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 230714 05 54 0403
Coding: 0230AD
Subsystem 2 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3211
Coding: 020000
Subsystem 3 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3211
Coding: 020000
Subsystem 4 - Part No SW: 3T0 959 537 E HW: 3T0 959 537 E
Component: E221__MFL-URO H07 0012
Serial number: 2164426
Coding: 810000
Subsystem 5 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3211
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3211
Coding: 020000
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 S HW: 7N0 919 475
Component: PARKHILFE 8K H06 0210
Revision: -------- Serial number: 28261530202208
Coding: 108101
Shop #: WSC 44700 231 72242
ASAM Dataset: EV_VW75XParkAssis8K 001011
VCID: 428B1184D519765FF1-8016
Component: VW10AirbagT20 H09 0020
Revision: -------- Serial number: 003GX00UUUCP
Coding: 003230
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9B39A4ED29AE1F39-801E
Serial number: 3495RRB40590NHDIJH62
Serial number: 3505RRB40590NHDIAOG2
Part No SW: 5J0 920 841 F HW: 5J0 920 841 F
Component: KOMBI H04 0305
Coding: 110C01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
VCID: 2D5152387C8799273C-8078
1 Fault Found:
13639168 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 211
Mileage: 66143 km
Date: 2019.10.18
Time: 17:01:14
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H78 0725
Revision: B9078001
Coding: 032200
VCID: 70EF8B4CA335B4CF57-8024
2 Faults Found:
01771 - Control Module for Headlight Range (J431)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 211
Mileage: 66143 km
Time Indication: 0
Date: 2014.03.10
Time: 17:02:28
03590 - Control Module for Multifunction Module
Fault Priority: 2
Fault Frequency: 1
Reset counter: 211
Mileage: 66143 km
Time Indication: 0
Date: 2014.03.10
Time: 17:02:31
Component: IMMO H04 0305
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADB99248DE94E1F19-803E
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 5JA 035 193 E HW: 5JA 035 193 E
Component: RNS315-EU H85 0501
Serial number: SKZAZ2R0659899
Coding: 040000110400000000000000
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: 3A7B6964BDC93E9FA9-806E
Data medium:
Subsystem 1 - Part No: 3AA 919 866
Component: EUR_W_V11 0073
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11241
Shop #: WSC 13765
VCID: 2F6D4830EA8BEB370E-807A
Address 55: Headlight Range Labels:
VCID: 55A1DAD8AC97F1E7A4-956C
Address 0B: Sec. Air Heating Labels:
VCID: 55A1DAD8AC97F1E7A4-95D0
End-------------------------(Elapsed Time: 03:00)--------------------------
VASILEIOS1972
My friend Fernando is it possible to respond?
Please my friend give any idea what to try
Regards
Vasilis
