BCM nearly inaccessible
Fraysa
Drives: 2011 6R
Post by Fraysa »
Hello everyone!
I’m currently in the process of retrofitting cruise control using a new stalk and a wire set I bought online.
After routing the cables from my steering wheel to the foot well area, I’m required to assign the correct pins to the white connector on the BCM, however the loom is super tight and won’t budge even a little. I can’t see anything up there.
Has anyone messed with it and can provide tips on what to do in this case? My Polo is a 2011 6R.
Thanks.
Re: BCM nearly inaccessible
Hello, welcome.
It's not related but maybe it helps you ... https://drive.google.com/file/d/0B2nv91 ... E1bk0/view (remove the BCM)
In this forum there is a lot of info about it.
Fraysa
Drives: 2011 6R
Post by Fraysa »
Anyone?
