some errors after upgrading 1S0937087D bcm to 1S0937090F
- Drives: VW UP/Passat B6
Re: some errors after upgrading 1S0937087D bcm to 1S0937090F
Thanks ciclo, I will try to add the missing wire.
Wires?
At this time I will only add the T73a/63 input power signal, that's most important for me (anual checkup fail).
And from what I can see this is just 1 wire
The other wires, I assume you mean for low/high beam and parking lights?
I am thinking about it but to be honest I can live with some errors ...
Thank you,
H2Deetoo
Thank you,
H2Deetoo
Hi ciclo,
I have ordered some parts so while waiting I am studying your solutions in order to understand them better.
Could you tell me why J33 has to be removed for these adjustments?
I see no harm leaving it, but I guess you always like to be "complete" ?
I see you redirect parking bulbs and low beam bulbs directly to bcm, I understand.
But what about the mainn beam, how is that controlled then?
(I understand high beam has always been controlled by bcm through stalk position.)
Rgs H2Deetoo
Rgs H2Deetoo
Crystal-clear viewtopic.php?f=56&t=73901#p562826H2Deetoo wrote: ↑Fri Nov 15, 2019 10:02 am Hi ciclo,
Could you tell me why J33 has to be removed for these adjustments? Isolation of original wires.
But what about the mean beam, how is that controlled then? T73a/62 (HB = main beam)
(I understand high beam has always been controlled by bcm through stalk position.) NO
Rgs H2Deetoo
I mean "flash" beam (highest possible light beam to flash to signal arriving traffic, I don't know what the exact word is for this in English?
I guess this flashing is done by changing intensity of the high beam bulb?
In your LB/HB solution you say "Remove SC13A wire, splice here".
I am not sure what you mean here.
I think it means I need to add an extra wire to SC13A and leave the original wires as they were?
I am sorry not all is clear to me, I am trying to understand
Btw, when I have finished your wirings, does this mean it's possible to activate and use coming home/leaving home? I see CH/LH can use the low beam which is then controlled by bcm.
If with your current solution it is not possible to use CH/LH with dipped beam, would it be possible to explain what to change to do make it work (if possible at all)?
Best regards,
H2Deetoo
Best regards,
H2Deetoo
In your VW up!, the high beam FLASH is powered by a +30 signal without BCM control, either ignition switch ON or OFF.
With the ignition switch ON (+15) and how other electrical components are connected/wired (Stalk switch, J33 relay, light switch) is how the use of high beams is controlled/defined in your VW up!
In no case the high beam (flash or not) have a BCM control in your VW up!
no, your H4 filament bulbs don't do such things ...
e.g. remove A wire, cut A terminal, strip the wires, splice a Butt terminal to this original wire (A) and to the new wire from BCM.
You don't have to do anything else at this point, the image is crystal clear (with colors).
Read https://drive.google.com/file/d/1PBSncn ... 4qT_q/view (again)
Everything is possible.H2Deetoo wrote: ↑Fri Nov 15, 2019 10:05 pm Btw, when I have finished your wirings, does this mean it's possible to activate and use coming home/leaving home? I see CH/LH can use the low beam which is then controlled by bcm.
You need to add the RLS with its wires, also more BCM Max adaptation wires and also the automatic light wiring.
The three images I made is only to adapt BCM Max with the big T17 light switch connector, not for the small T10 light switch connector.
Why is RLS (rain light sensor) needed to support CH/LH ?
(General idea is they're not related at all?!)
I think in your simple solution you still use low/main beam power controlled by T17 switch, so CH/LH can't work if this switch is turned off ?
Is that the main reason CH/LH can't work with this simple solution?
I will study danikd's changes once more!
Rgs H2Deetoo
Rgs H2Deetoo
Yes ok, so split 1 wire into 2 (Y cable) and make sure the original wire remains intact and extra wire goes to bcm.
I guess you leave LB/HB control fully by T17 switch and simply let the bcm output check for voltage/current to detect bulb problem? So it won't trigger the errors?
H2Deetoo wrote: ↑Sat Nov 16, 2019 7:57 am Why is RLS (rain light sensor) needed to support CH/LH ?
Rgs H2Deetoo
H2Deetoo wrote: ↑Sat Nov 16, 2019 8:23 am >e.g. remove A wire, cut A terminal, strip the wires, splice a Butt terminal to this original wire (A) and to the new wire from BCM.
Simply you think, you guess, in a simple way.
There is nothing better than a simple solution for something complex (which you still don't understand).
Presumably you answer something inappropriate, please do it,
write your favorite barbarity for eternal posterity, I promise that I will not erase it or ban you. Thanks.
Ah yes, good luck with the ICs sale.
Weird reaction, is something wrong?
I'm simply trying to understand your solution, searching through wire diagrams, but its all new to me and I don't get the full overview yet.
And is there a problem with me selling clusters?
I do that for many many years already.
Rgs H2Deetoo
Rgs H2Deetoo
if I look at M29 (left low beam) it normally comes from SC13 which comes from J33 which comes from SC1 which comes from battery.
If we remove J33 (as you suggest) then SC13 becomes unconnected, so we can simply pull out SC13A and connect directly to T73a/2. No need to splice?
Is this what you describe in your picture solution?
If M29 is directly controlled by T73a/2 then CH/LH should work if low beam is used for that.
You don't agree?
Can you explain why RLS sensor would be needed for CH/LH ?
Regards,
H2Deetoo
You don't agree?
Regards,
H2Deetoo
I finally realized CH/LH only works when it is dark outside, so it requires the RLS indeed.
Hello,
I finally got around to putting the missing power wires into our VW Up.
I did exactly as you suggested, using 30A fuse in SB2, and splitting to 2 fuses of 15A and put them in SC35 and SC43.
I first installed wire from SC35A to T73a/63.
Then when I looked at T73b/68 I noticed this wire was already present?!
(I can't upload a picture, I get error : board attachment quota has been reached)
Do you have any idea why this wire would be present in my car's setup?
I also checked that I had T73b/12 blue/black and I can confirm it now with a good picture.
Anyway, the reverse light is working now as you sugggested
The rest of the wire changes (to resolve the current light bulb errors) will be for a later time.
I am also thinking of installing an RLS sensor (where/how?) so I can change wiring for auto lights and CH/LH.
Thanks again for helping so far, you can truly perform magic!
Regards,
H2Deetoo
Regards,
H2Deetoo
For completeness, here are the 4 errors which are still remaining in the bcm (until I get that sorted):
Address 09: Cent. Elect. (J519) Labels:. User\1S0-937-09x-V1.lbl
Part No SW: 1S0 937 090 F HW: 1S0 937 090
Component: BCM PQ25 1MX4 H81 0744
Revision: BW081001 Serial number: 0978 215160666
Coding: 7AB82B0000010000080802042D6BBCC800C0400C60020400200000400100
Shop #: WSC 31414 790 00001
VCID: 366390D8814775FA37-8062
Subsystem 1 - Part No SW: 6R0 959 591 B HW: 6R0 959 591 B
Component: J245 PS72.023 H02 0007
Serial number: WOO26347321
Coding: 181100
Subsystem 2 - Part No SW: 2H0 959 442 HW: 2H0 959 442
Component: E221__MFL-DC1 H02 0103
Serial number: 29170001883980077353
Coding: A4FFFF
4 Faults Found:
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 180
Mileage: 104694 km
Time Indication: 0
Date: 2019.11.22
Time: 17:28:26
03432 - Activation of Right Parking Light
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 180
Mileage: 104694 km
Time Indication: 0
Date: 2019.11.22
Time: 17:28:26
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 180
Mileage: 104694 km
Time Indication: 0
Date: 2019.11.22
Time: 17:27:04
00979 - Lamp for Low Beam; Right (M31)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 180
Mileage: 104694 km
Time Indication: 0
Date: 2019.11.22
Time: 17:27:04
I see I now *do* have the error about the left low beam (M29) which I didn't have before.
Regards,
H2Deetoo
Coding: 181100
Coding: A4FFFF
4 Faults Found:
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 180
Mileage: 104694 km
Time Indication: 0
Date: 2019.11.22
Time: 17:28:26
011 - Open Circuit
Fault Priority: 2
Fault Frequency: 1
Reset counter: 180
Mileage: 104694 km
Time Indication: 0
Date: 2019.11.22
Time: 17:28:26
Fault Priority: 3
Fault Frequency: 1
Reset counter: 180
Mileage: 104694 km
Time Indication: 0
Date: 2019.11.22
Time: 17:27:04
Fault Priority: 3
Fault Frequency: 1
Reset counter: 180
Mileage: 104694 km
Time Indication: 0
Date: 2019.11.22
Time: 17:27:04
Regards,
H2Deetoo
