Polo 6R 09 1.4 85KM
- Drives: polo 1.4 85KM CGGB/GOLF 7.5
Polo 6R 09 1.4 85KM
Hello, my name is Piotrek (Peter in English), I'm owner of Polo 6R 2009 1.4 86ps Higlline with factory rear disks, MFSW and 12V socket in trunk.For now I plan to change BCM and add parking sensors and Full LED headlights from Polo 6C ,AFS and including headlight washers
(i bought R-Line bumpers).
Recently I retrofitted:
- Cruise Control System
6R0953521C
- Polo 6C taillights (via adapters)
6C0945096M
6C0945095M
- RNS-310 RSN-510
A few photos of mine:
[/url
6R0953521C
6C0945096M
6C0945095M
- RNS-310 RSN-510
[/url
Re: Polo 6R 09 1.4 85KM
Yo mate, nice to see you here It's a good place for every Polo 6R owner
Nice 6R (apart from the color), I believe that soon your Polo will be more interesting
He's slightly obsessively in love with the color blue
- ag69
- Drives: 1.2TSi 77Kw 7DSG
ha ha ha ha
Hi Piotrek, thanks for sharing the images of your 6R.
You will have a nice 6R RED when you finish the installations, LED headlights, R-line bumpers, etc ...
Your wiring looms 'B': viewtopic.php?f=62&t=69223&start=105#p563747
The installation guide, download the PDF document.
I will send you a private message to contact me by email. (soon, wait a little please )
Thank you so much, you're greatciclo wrote: ↑Fri Dec 06, 2019 1:51 pm Hi Piotrek, thanks for sharing the images of your 6R.
Welcome ! Next ppl from Poland
Nice Polo ;D colour
Nice Polo ;D colour
... on the Right path.
Did you know that the most beautiful Christmas balls in the world are made in Poland?
Merry Christmas
(only for all those who like Christmas holidays... )
Merry Christmas
Hello dcgumis
If you need help to install the IC in the correct way contact madwarlock (Slavik). Remember that I always recommend what I consider to be best for others considering all possible circumstances.
Ask him to update the software of that IC GTI. From 0607 to 0709.
You have to send him your current IC and one of the keys so that he can transfer the data with his original super tools.
The MFSW is a direct swap in your case. You do not need to wire anything.
It is necessary to check the coding of the new control unit. It would be 820000 for that MFSW GTI, ... in your case.
Subsystem 6 - Part No SW: 5K0 959 542 (x) HW: 5K0 959 542
Component: E221__MFL-TAS H05 0010
Coding: 020000 (to 820000)
Neither of the two references of the stalks you show is correct for your 6R (MY 'A').
- The first one is not compatible with your slip ring.
- The second has no switch for the rear wiper.
The correct one when installing the new MFSW would be 6Q0953513AL.
For example, https://www.ebay.co.uk/itm/VALEO-LENKST ... Sw1r5bZwIq
Thank you for your response
I currently have the 6R0 959 564 slip ring installed
Stalks 6R0953521C
(Yes, I know I don't have a turn sensor)
Sorry, it should be 6R0953521B
6R5953521B is an amarok without rear window wiper
Stalks 6R0953521C
Saturday,09,November,2019,16:05:24:05031
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
www.Ross-Tech.com
VIN: WVWZZZ6RZAY020 License Plate:
Chassis Type: 6R (6N0)
Scan: 01 03 08 09 15 17 19 25 37 44 56
VIN: WVWZZZ6RZAY020707 Mileage: 166740km-103607miles
56-Radio -- Status: OK 0000
Address 01: Engine Labels: 03C-906-024-BXW.lbl
Part No SW: 03C 906 024 BH HW: 03C 906 024 BH
Component: CGGB MM4HV G 9971
Revision: --H09--- Serial number:
Coding: 0000071
Shop #: WSC 53413 001 1048576
VCID: 65C629BBAF726116CE-5072
Readiness: 0010 0001
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6R0 907 379 AC HW: 6R0 907 379 AC
Component: ABS8.2 front H04 0001
Revision: --------
Coding: 200228E3016F00B2042C14E280D800000200
Shop #: WSC 02069 000 00000
VCID: 7F0A9BD3EAEEDBC624-802A
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AP.clb
Part No SW: 6R0 820 045 A HW: 6R0 820 045 A
Component: Climatic 23 0500
Revision: 00 09 23
VCID: 2C509C9F4F18905ED1-8078
1 Fault Found:
16372 - Control Module; Unspecified Internal Error
014 - Defective
Fault Status: 01101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 2234 km
Time Indication: 0
Date: 2010.01.08
Time: 17:45:52
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 087 B HW: 6R0 937 087 B
Component: PQ25 BCM H08 0025
Revision: BF008001 Serial number: 9955A155091657
Coding: 3DB02BB828F32400923800003D2B1CD000C0410F608000002000
Shop #: WSC 124697 483 00190
VCID: 3C70ACDFBF7800DE41-8068
Subsystem 1 - Part No SW: 6R0 959 801 H HW: 6R0 959 801 H Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 0803
Coding: 08BC30
Subsystem 2 - Part No SW: 6R0 959 802 K HW: 6R0 959 802 K Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 0803
Coding: 08BC30
Subsystem 3 - Part No: 1K8 951 171 A
Component: DWA-Sensor 00 001 0103
Subsystem 4 - Part No: 1K8 951 605
Component: LIN BACKUP HO H09 9002
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 6 - Part No SW: 5K0 959 542 HW: 5K0 959 542
Coding: 020000
Subsystem 7 - Part No SW: 6R0 959 811 B HW: 6R0 959 811 B
Component: J388__TSG_HL 002 0803
Coding: 08BC32
Subsystem 8 - Part No SW: 6R0 959 812 B HW: 6R0 959 812 B
Component: J389__TSG_HR 002 0803
Coding: 08BC32
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10Airbag005 H09 0018
Revision: -------- Serial number: 003DW003YHK-
Coding: 003035
ROD: EV_AirbaVW10BPAVW250_SE25.rod
VCID: 428CD227D59C762E0B-8016
Crash sensor for side airbag; driver side:
Serial number: 3572SRB40000911C8A98
Crash sensor for side airbag; front passenger side:
Serial number: 3582SRB4000091185980
Crash sensor for side airbag; rear; driver side:
Serial number: 3516GRB401V9F7IH9SA3
Crash sensor for side airbag; rear; passenger side:
Serial number: 3526GRB40219F7IH1K1-
Part No SW: 6R0 920 860 B HW: 6R0 920 860 B
Component: KOMBI H23 0110
Coding: 140A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 336287E39A26CFA690-8066
Coding: 140A00
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087 B
Component: GW-K-CAN TP20 0025
Coding: 002200
VCID: 70E848EFA3B0B4BEAD-8024
Component: IMMO H23 0110
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 R HW: 1T0 035 680 R
Component: RNS-MID H24 6276
Revision: AB001001 Serial number: VWZ6Z7S0418589
Coding: 00010000010000A00000
Shop #: WSC 01357 011 00200
VCID: 3D76A1DBA46209D676-8068
Subsystem 1 - Part No: 1T0 919 859 C
Component: EU East V15 8522
Part No: 6R0 423 156 A
Component: LenkhilfeTRW V275
Coding: 10150
Shop #: WSC 00000
VCID: 2E549697ED04E24EFF-807A
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
End-------------------------(Elapsed Time: 02:42)--------------------------
Ok, you updated your slip ring (G85 sensor), ... in that case the correct stalks when installing your new MFSW are 6R0953507B.
viewtopic.php?f=56&t=58703&start=1080#p496280
Click on image.
Recommendation
Now that you are going to make new electrical installations you can wire the new slip ring with G85 sensor so that the Static Cornering lights work with your new BCM Max.
It will work properly even if your brake unit is for ABS and nor for ESP.
Click on image.
Recommendation
