Hi !
Coding change to 0000000000 after instaling for a moment instruments from my friend car
off corse I did not autoscan before this
RCD310 is safe and abs/esp, tpms is flasing. CAn anoyone help here ?
I tried
210224C2217200B2842924E584D800401200
210224C2217200B2842924E584D800400200
but it's not working "error 22"
ESP/ABS 8.2i long coding
Re: ESP/ABS 8.2i long coding
I have never used it but there is this program to calculate the ABS coding.
https://skodapilot.com/espcalculator-bosch/
For the car radio, if you put back your original cluster it should automatically fix it self after start driving (at least it did in my car on the factory fitted radio). The PIN code is stored in your IC, so provided that your radio was previously adapted correctly, it should work with your original cluster.
I'm going to need a full scan of the car please
And info on RHD/LHD, tpms and hill hold
