polo 6r abs code
cleebrothers
Drives: 6r
polo 6r abs code
Post by cleebrothers »
can any one help me with the abs long coding for a customers vehicle vin wvwzzz6rzay145342, we have changed the pump i have tried every thing i can find, i can post a full scan if needed. thanks for your help
Re: polo 6r abs code
Yes a full scan please
cleebrothers
Drives: 6r
Hi
It will not let me post the full scan, says it contains personal info.
Do you know a way around this?
Just copy and paste the text
cleebrothers
Drives: 6r
VIN: WVWZZZ6RZAY145342 License Plate:
Mileage: 83860km-52108mi Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 09 15 17 19 25 2E 44 56
VIN: WVWZZZ6RZAY145342 Mileage: 83860km-52108miles
Address 01: Engine (CGP) Labels: 03E-906-033-AZQ.lbl
Part No SW: 03E 906 023 L HW: 03E 906 023 L
Component: SIMOS91 1.2l 4V 4489
Revision: --H04--- Serial number:
Coding: 0000031
Shop #: WSC 00001 000 163936
VCID: 2855928898ABDF0FF1-5178
1 Fault Found:
18057 - Powertrain Data Bus
P1649 - 009 - Missing Message from ABS Controller - Intermittent
Readiness: 0110 0001
cleebrothers
Drives: 6r
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AL HW: 6R0 907 379 AF
Revision: --------
Coding: 000000000000000000000000000000000000
Shop #: WSC 13765 790 00051
VCID: 0815F208BF6BFF0FD1-805C
4 Faults Found:
01042 - Control Module; Not Coded
000 - -
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 26
Reset counter: 203
Mileage: 83861 km
Time Indication: 0
Date: 2014.05.12
Time: 06:45:08
Hex Value: 0x0007
Hex Value: 0x0000
Hex Value: 0x3213
Hex Value: 0x1499
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Fault Status: 01100101
Fault Priority: 0
Fault Frequency: 26
Reset counter: 203
Mileage: 83861 km
Time Indication: 0
Date: 2014.05.12
Time: 06:45:08
Hex Value: 0x0007
Hex Value: 0x0000
Hex Value: 0x3251
Hex Value: 0x1B99
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
00493 - ESP-Sensor Unit (G419)
Fault Priority: 0
Fault Frequency: 26
Reset counter: 203
Mileage: 83861 km
Time Indication: 0
Date: 2014.05.12
Time: 06:45:08
Hex Value: 0x0007
Hex Value: 0x0000
Hex Value: 0x32E1
Hex Value: 0x2099
Hex Value: 0x00FF
Hex Value: 0x7F7F
Hex Value: 0x7F00
03306 - Coding Not Valid
000 - - - Intermittent
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 20
Reset counter: 243
Mileage: 83861 km
Time Indication: 0
Date: 2014.05.12
Time: 06:58:10
Hex Value: 0x0002
Hex Value: 0x0000
Hex Value: 0x32E7
Hex Value: 0x2598
Hex Value: 0x00FF
Hex Value: 0x7FAE
Hex Value: 0x78F8
cleebrothers
Drives: 6r
Part No SW: 6R0 937 087 D HW: 6R0 937 087 D
Component: BCM PQ25 H+4 H46 0207
Revision: BF046001 Serial number: 0147 331091311
Coding: 24B029BF08A10000002000003D2B0CD00040410F60860000200000000000
Shop #: WSC 124697 483 00190
VCID: 3E7954D0A92F71BFAB-806A
Subsystem 1 - Part No SW: 6R0 959 802 H HW: 6R0 959 802 H Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 005 0811
Serial number: KU0-KU020.10.0912430
Coding: 08BC30
Subsystem 2 - Part No SW: 6R0 959 801 CB HW: 6R0 959 801 CB Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 8620
Serial number: KU0KU007011550076019
Coding: 0400A0
Part No SW: 6R0 959 655 C HW: 6R0 959 655 C
Component: VW10Airbag00P H09 0018
Revision: -------- Serial number: 003DW009PUA-
Coding: 003050
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 42812020D5D7155FCF-8016
Serial number: 3572SRB40000A6AD2111
Serial number: 3582SRB40000A6A07A8A
Serial number: 3516GRB401N9L20SS4U4
Serial number: 3526GRB4033CFGVNA4BU
1 Fault Found:
12656896 - Databus
U1122 00 [008] - Implausible Message
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 2
Reset counter: 243
Mileage: 83861 km
Date: 2019.12.20
cleebrothers
Drives: 6r
Part No SW: 6R0 920 960 D HW: 6R0 920 960 D
Component: KOMBI H03 0205
Coding: 440800
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
VCID: 36694CF0891FB9FF73-8062
1 Fault Found:
12656896 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Priority: 6
Fault Frequency: 2
Reset counter: 243
Mileage: 83861 km
Date: 2019.12.20
Time: 06:51:48
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087 D
Component: GW-K-CAN TP20 0207
Coding: 002100
VCID: 70E5BAE8A3FBD7CF69-8024
Component: IMMO H03 0205
Serial number:
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03006
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6AD1A8808D272D1F27-803E
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0090
Revision: A1001003 Serial number: 7667666676
Coding: 010000
VCID: 26499CB051BFC97FC3-8072
Part No: 6R0 423 156 A
Component: LenkhilfeTRW V275
Coding: 10150
Shop #: WSC 00788
VCID: 2E596490ED4F813F3B-807A
Part No SW: 5M0 035 186 AA HW: 5M0 035 186 AA
Component: Radio RCD310 016 0049
Revision: 01000000 Serial number: VWZ1Z2I6873427
Coding: 0100040002
VCID: 6BDFAD848ADD34175C-803E
1 Fault Found:
00625 - Vehicle Speed Signal
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 2
Reset counter: 243
Mileage: 83861 km
Time Indication: 0
Date: 2014.05.12
Time: 06:51:53
End-------------------------(Elapsed Time: 02:23)--------------------------
cleebrothers
Drives: 6r
Just managed to post it, thanks for your help in advance regards cleebrothers
Give this a try: 230228E3217100B7C42814E684D300800000
No TPMS, XDS or HHC
cleebrothers
Drives: 6r
i get coding rejected
error 22 conditions not correct of request sequence error
What happened to the car to lose the coding in the first place? Different ECU or instrument cluster?
Second try: 230224E3217100B7C42824E684D300801000
cleebrothers
Drives: 6r
good morning the abs module had no communication so i have swapped it with a second hand one, the second code didnt go in same error as before.
thanks regards cleebrothers
