Franciswat's Polo 6R 1.6 Bifuel
Re: Franciswat's Polo 6R 1.6 Bifuel
Hi Francesco, Happy New Year 2020!
The problem is that there is no power to the wires T73a/63 and T73b/68 that reach your BCM Max (I imagine that power it's supplied from SB39 and SB59 fuses, i say tha I 'imagine' because I did not manufacture your wiring, but you followed the installation guide).
Do you remember how you made the electric bridge on the J331 relay? Check it out too.
Franciswat
Drives: 6R 1.6 Bifuel
Post by Franciswat »
Thank you Fernando! I've checked immediately the bridge as you told me and I found the problem :shock:
Cannot explay what happened but I can only suppose there was something wrong with the bridge I used.
I admit I made It by myself using a 1mm thick aluminium sheet, not the best choice for this kind of work probably even If worked fine for months.
I replaced the melted relay's holder with a new one and soldered the 2 wires together to avoid further problems.
Thank goodness nothing worst happened.
Thank you mate :roll: I feel very stupid and lucky at this time
The images clarify the facts. (thank you for the images)
Maybe the bridge you made is not the problem, maybe there are too many consumers connected to the power wire (+30) that receives the power from the electric bridge. This wire branches on two wires to the fuses SB39 and SB59 and then feeds the BCM (63a, 68b).
If there is another electrical consumer connected to this wire that is subsequently divided into two wires to the fuses, you must desconected it and take the power for that consumer from another point of the electrical installation (e.g. directly from the battery with new wires)
However, the fact that the original wires have not been damaged by excess temperature suggests that the electrical bridge you made is not of the right materials to evacuate the temperature or was incorrectly placed on the terminals of the relay holder.
I'm inclined to the idea that the materials from which the electric bridge has been made/built are not adequate for electrical installations. :?:
It is good to know that the problem has been solved without other consequences.
Franciswat
ciclo wrote: Thu Jan 02, 2020 5:40 am I'm inclined to the idea that the materials from which the electric bridge has been made/built are not adequate
This is also my idea. I think probably a bad contact between bridge and terminals (maybe because of the oxidation) could lead to an overhead of the brige.
Since that happened immediately after turning on the car lights with no extra power consumption I feel you exclude the other option.
:wink: the important thing is that everything fine :wink:
Thank you ciclo!
Franciswat
Hi guys, I want to share with you my last project.
Since my comfortline has no tweeters in front pilars I purchased a pair of them from Hertz and 3d printed the brackets to use the original fixing points. I'm really satisfied of the result because it looks very similar to the original one. :wink:
More updates coming soon!
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
Very Nice!!!
Looks great, excellent creativity.
Franciswat
Thank you guys. :wink:
Today need to add a new wire in the fusebox for the heated washers jets.
I saw there's a locking mechanism but I do not want to risk to break something.
Do you know how to unlock it? Thanks in advance!
Use a flat screwdriver to move the locking mechanism as you see in the image.
Sometimes it's a little hard the first time ... nothing will break.
Franciswat
Thank you ciclo I did It successfully! :wink:
Do they need to be coded with VCDS?
Any way to check if they works?
Here's some pictures. This time I tried to use 3D printed connectors and they works nice!
I've also completed the mirrors mod with k418 unit and works nice! :wink:
Good job, on both mods!
Nice mods. :wink:
The heated washer jets are automatic, they don't need coding (they are not connected to any codifcable element🤗). You can verify how the resistance varies with a multimeter, they are sensitive to the heat of the hands and the refrigerator in your home.❄😅
Franciswat
Thank you Michael! Thank you ciclo for the explanation! :wink: I'm very happy with the last retrofit!
Unfortunatelly the situation is not quite good here in Italy because as you know we are all forced to stay at home to pervent new contagious but I'm try to keep my mind busy. :roll:
Finally climatronic retrofit on my 6R had been completed! A huge thanks to Michael and CNK for that! Here are some pictures which summarize the work:
Climatronic unit used comes from a 2015 Polo 6C.
The new wiring; I added one connector in order to make it plug and play with the old wiring.
Starting point:
Disassembling:
Interiors almost disassembled:
New 9 pin connector next to the manual control panel will plug and play to the 9 pin connector of the new wiring.
New 2 pin connector next to manual climate unit..
.. will plug and play with the 2 pin connector of new wiring.
Testing and reassembling:
Now everything seems work fine and I am happy with it. The new fa was a bit noisy at low speed at the beginning but now Its noise decreased.
I performed an autoscan and there are no errors. That's a bit strange because I did not code anything:
As far as you know have I to code It?
Thanks :wink:
Sunday,15,March,2020,12:39:37:39744
VCDS Version: 17.1.3.0 (x64)
Data version: 20170203 DS267.2
www.Ross-Tech.com
VIN: WVWZZZ6RZCY540000   License Plate:
Chassis Type: 6R (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 55 56 0B
VIN: WVWZZZ6RZCY540000   Mileage: 103340km-64212miles
56-Radio -- Status: OK 0000
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BC    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0002
   Revision: --------
   Coding: 210224E3217100B5842524E484D700401300
   Shop #: WSC 00788 648 00255
   VCID: 00085B4297984341E9-8054
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H12 0812
   Revision: V0000000
   VCID: 3878F3A28BC8CB8111-806C
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Revision: B9080001    Serial number: 0771 060161479
   Coding: 3CB02BBF08E1240092380E916C6B0DD9DAC0672F608D30D0200000030000
   Shop #: WSC 02737 534 00190
   VCID: 68D863E29BE89B0141-803C
   Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU004011200011991
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU005011200017885
   Coding: 08BC30
   Subsystem 3 - Part No: 1K8 951 171 A
   Subsystem 4 - Part No: 1K0 951 605 F
   Component: LIN BACKUP HO  H01 0008
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H04 0103
   Serial number: 29170002240760027504
   Coding: A40000
   Subsystem 7 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU010011200012406
   Coding: 08BC32
   Subsystem 8 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU009011200013136
   Coding: 08BC32
Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 L    HW: 56D 919 475
   Component: PARKHILFE 8K  H02 0106
   Revision: --------    Serial number: 20231629400567
   Coding: 108001
   Shop #: WSC 12345 123 12345
   ROD: EV_EPHVA18VW250GPCS.rod
   VCID: 3B72ECAEB2FEE099FC-806E
   Component: VW10Airbag022 H09 0020
   Revision: --------    Serial number: 003GX011W0JJ
   Coding: 003232
   ASAM Dataset: EV_AirbaVW1B0PAVW250 A01001
   ROD: N/A
   VCID: 4A9CB96AED24491177-801E
   Subsystem 1 - Serial number: 3575HRB4059124B2F99H
   Subsystem 2 - Serial number: 3585HRB4061131GQCOUS
   Subsystem 3 - Serial number: 3515RRB405P0VC0I5P0W
   Subsystem 4 - Serial number: 3525RRB40510VC0IA9B9
No ASAM data for: "EV_AirbaVW1B0PAVW250" (VW25)
   Part No SW: 6R0 920 871 A    HW: 6R0 920 871 A
   Component: KOMBI         H03 0505
   Coding: 140E01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: 3460C7929FA02FE13D-8060
   Revision: B9080001
   Coding: 002200
   Component: IMMO          H03 0505
   Serial number:
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Imm_oUDS_VDD_RM09 A03009
   ROD: N/A
   VCID: 6ADC19EA8DE4A91157-803E
No ASAM data for: "EV_Imm_oUDS_VDD_RM09" (VW36 *)
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F6AC8FEEA860C3940-807A
Address 55: Headlight Range (J431)       Labels: 6R0-907-357.clb
   Revision: --------    Serial number: --------------
   Coding: 0110000001000000
   VCID: 77FA309ECE5604F9D8-8022
Address 56: Radio (J503)       Labels: None
   Component: Radio         541 5522
   Revision: --------    Serial number: VWZZZ4K6200530
   Coding: 16000400040006
   Shop #: WSC 127395 840 08317
   VCID: 46848D5AF13CAD7193-8012
End-------------------------(Elapsed Time: 03:11)--------------------------
Sometimes it can be necessary to code the engine ECU for climatronic, I had to with my 1.2 TDI with start/stop.
