Favi's Polo 6R 1.2TSI Red Flash "strawberry" :)
Re: Favi's Polo 6R 1.2TSI Red Flash "strawberry" :)
Keep in mind that the AFS ECU for bi-xenon headlights won't work with the LED headlights. You'll need a C unit with parameterization for LED headlights, i.e. from Russia or India (original) or flash the correct parameters with ODIS or VCP --> https://www.drive2.ru/l/519838378447864355/
+1iichel wrote: ↑Wed Aug 14, 2019 11:00 am Keep in mind that the AFS ECU for bi-xenon headlights won't work with the LED headlights. You'll need a C unit with parameterization for LED headlights, i.e. from Russia or India (original) or flash the correct parameters with ODIS or VCP --> https://www.drive2.ru/l/519838378447864355/
6R0 907 357C Z09 in his case.
favi, I have the parameters for VCP if you need them. (by email)
I had 6R0 907 357
So need to buy 6R0 907 357C
This will be okay?
https://allegro.pl/oferta/modul-sterown ... 8396395581
I have this module:
30.06.11
6R0 907 357
0070 H02
010 178-20 AC
0004 0659 HLR-0W5
after disconnection - no ESP and TPMS errors, cornering works.
After connecting the module - errors return.
This will be okay?
I have this module:
30.06.11
6R0 907 357
0070 H02
010 178-20 AC
0004 0659 HLR-0W5
I can't open channel 55 at all - headlight range. Control not responded
I will check today ground point, and fuse box one again
Everything works fine. I have 2 errors on both AFS modules. Below are photos. I can't encode any of them.
6R0 907 357C Z09
6R0 907 357
The problem was ... in the cube T26, which I bought in one of the popular vag modification shop. Someone inversely CAN HI / CAN LOW plucked into T26. I thought that the instruction that is attached to the harness does not require verification of the pins in the cube, and only wires to connect to other cubes. I stripped my T26, swapped pin 23 and 24 with T / 26 and it works. I solved the power and mass problem according to the idea of @firegrafik. Two wires for the right reflector cube T10 / 1 and T10 / 3. Everything works
Now the struggle with coding the lights again remains. When I have Auto and the DRL are on, flash high beam does not work. ON indicator, lights are not working. In AUTO mode - night, works OK.
6R0 907 357C Z09
6R0 907 357
I did all from this link https://www.drive2.ru/l/519838378447864355/
I cant change the encoding of the AFS module. I can't upload a file from TinyQ . Communication error. What's the problem? I can't change the encoding in VCDS either
Anyone have an idea?
Maybe the parameterization from TinyQ is not correct for 6R (EU) and is correct for Polo Sedan (RUS), it is something I don't know.
If I were you, I would contact Szymon (CNK), who successfully installed LED headlights on his 6R with the right tools (original VCDS and VCP).
I would meet him and invite him to a couple of beers or whatever are necessary, ... or the refreshing drink he likes best, coffee, tea, RED BULL, etc... (or one of those Russian/Poland drinks that awakens the dead ).
Subsequently, we would investigate the problems of your 6R by temporarily exchanging between cars the units involved in the installation of LED headlights.
You may not come to any conclusions about the problems your 6R experiences with the installation of LED headlights but it is a great opportunity to have a nice day.
If you cannot solve the problem remotely, I will plan a trip to Szymonciclo wrote: ↑Fri Jan 03, 2020 2:35 am Maybe the parameterization from TinyQ is not correct for 6R (EU) and is correct for Polo Sedan (RUS), it is something I don't know.
In the suitcase, of course, a good Polish drink - Bimber (strong vodka) xD
Unfortunately or not, I don't have teamviewer or whatsapp to make instant remote connections, I'll be one of the last hominids to have those 'free' applications.
... surely the pygmies of Congo already have whatsapp and I don't.
As you are going to meet with Szymon, tell him to update and parameterize your BCM too. (in case you haven't done it)
- Drives: 1.2TSI 105HP DSG7
Re: Favi's Polo 6R 1.2TSI Red Flash "strawberry" [emoji3]
i wish i can do roadtrip there to szymon as well. he just got so many interesting stuffs inside his garage[emoji12]
Hey every one
I have little problem.
1. Swapped headlining on the car. I mounted the black from the POLO GTI.
I disconnected the plug from the RLS (T3 RLS) for a moment and after reconnecting the "Auto light" function stopped working - it detects the night non-stop. CH / LH function does not work when unlocking the car.
VCDS sees RLS in long coding. No errors with RLS
2. The second problem, after starting the engine, the air conditioning does not start. The button doesn't seem to work. Only after driving about 20 meters, the air conditioning starts. What's the problem?
This happens after the BCM is changed to 7E0.
