The Seat Forum seems a bit dead so I thought I'd seek advice from you fellow polo owners.
I have a Seat Ibiza 1.2 2007, which is the same in design for drive train components. So I was wondering if anyone has experienced this problem.
Currently I have a harmonic humming sound from as low as 20mph+ which becomes more audible when I increase speed, and when making a right turn. This lead me to believe it was the passenger side wheel bearing, which I finally decided to replace last weekend (after great effort and a 20T press may I add
Did I press the new wheel bearing incorrectly and damage it? I've attached an image of how the new bearing has been pressed, if you fellas want to check this over, I did actually stick to the procedure in the haynes manual rather than using the Gen 2 specialist tools
