Brake discs and pads upgrade
GavinNicholson
Drives: 6c gti
Post by GavinNicholson »
I need new discs all round and would replace the pads aswell
Is it possible to fit slightly bigger discs than standard without too much hassle? Also what pads do people use i drive "fast road" not alot of track use
Any advice or personal experience would be good
Re: Brake discs and pads upgrade
The discs supplied with the car new will have been matched to the calliper carriers, so any increase in disc diameter would need to be accompanied with the correct new calliper carriers or even new callipers and calliper carriers - or callipers that bolted directly onto the hubs.
eki912
Drives: 1.6 tdi, 2013, dsg
Post by eki912 »
They should be able to help you :
https://ebcbrakes.com/automotive-products/
