Hi
Anyone recommend in Aberdeen for programming?
Got full sat nav with appleplay media unit comping and want it all switched on once plugged in, in case the bum shuts it all down again
Cheers Rob
VCDS PROGRAMMING
Re: VCDS PROGRAMMING
I don't know an awful lot about Aberdeen. What I do know is that enabling these functions requires tools a lot more capable and dangerous than vcds (ie Odis or hacking tools)
Robbo770
- Drives: Polo SEL 1.4 tdi 2014
Hi I HEL, can you help at all, with now having mib2 discovery spec system, do I need a new usb wiring and socket, if so do you know which ones?
Cheers Rob
Cheers Rob
Find out where your local VAG Indies are located and email/phone them to see if they can remove Component Protection - some can some can't it depends on how well they have equipped themselves with VW Group kit and licences - if they can do that, they will be able to change any associated codings required when swopping ICE.
Edit:- I've just noticed your other posting, so most of the above is not needed!
Robbo770
Thanks for the reply,
Would you happen to known the part numbers of the upgrade cabling and the suitable usb socket I need to get to finish the u[grade off?
Cheers Rob
Cheers Rob
Sorry, no, the online resource that I normally use seems to have been taken down or currently not available as I was looking for another part number earlier today - it might reappear later/tomorrow/etc so I'll keep looking.
