9N Removing air filter box...
Markino
Post by Markino »
How can I remove it on my 19.TDi? :roll:
sylonien
2nd Stage Warning
Post by sylonien »
Sorry wish I could help, but I've got a 1.4 petrol and I can't even see my bloody air box!
Petrified
Sponsor
Post by Petrified »
It may be a guess but pull the plastic cover off the top of the engine and it should be hidden underneath there, screwed in. At least thats where it is on the FSI & 1.2
James.
sylonien
2nd Stage Warning
Post by sylonien »
"rip" the plastic off?! :shock:
SiDaBa
Sponsor
Post by SiDaBa »
Yeah just pull on the engine cover, carefully obviously.
sylonien
2nd Stage Warning
Post by sylonien »
I highliy doubt I will attempt that. Seems odd just to pull it off. Me too scared to break anything there. :shock:
DJ
Post by DJ »
it's simple... just pull it on.. but remember you have to detach the small tube on the right side of the engine cover.. unscrew all screws (11 screws, if i'm correct), and u will see your air filter...
that's very easy.... give it a try 8)
sylonien
2nd Stage Warning
Post by sylonien »
I shall investigate in to it when I can.
So...
  1. Removing screws.
  2. Remove small tube.
  3. Pull it off theN?
You from Hong kong?[/list]
DJ
Post by DJ »
the procedure is...
1. remove the tube
2. pull off the cover (air box)
3. turn cover upside down
4. unscrew
5. open the air box (cover)
6. There you go.. the Air filter
Yes.. I'm form Hong Kong
DJ
Post by DJ »
pix taken from a Mainland China Polo site
Markino
WOW!!!
Post by Markino »
MANY THANKSSSSSSSSS!!!! :lol:
sylonien
2nd Stage Warning
Post by sylonien »
I shall see what i can find out tonight, even though I can't see the pictures which is rather sad. :(
