1.8tsi dsg
- shaun.quick
1.8tsi dsg
when i cornering one way the car feels like it is trying to brake but doesn't do it the other way? has anyone else had this problem?
Ricmondo
- Drives: Polo Blue GT
Re: 1.8tsi dsg
It’s probably the electronic diff (XDS) having a funny half hour.
Could be a sensor problem, uneven tyre wear or wildly different tyre pressures across the front “axle”.
The system used the cars brakes, does the car pull up in a straight line? If it doesn’t you might have a calliper or brake pad problem.
- shaun.quick
Re: 1.8tsi dsg
it only does it turning right no problems turning left, had 4 new tyres recently, and its had new brakes aswell,
Re: 1.8tsi dsg
You could have a (careful) quick corner with the ESP/ASR/TCS/ESC/whatever-it's-called disabled and see if it makes a difference.
But In the 6R, the ESC light will illuminate when the ESP is helping out. Not sure how this is for the XDS and the 6C though.
- shaun.quick
Re: 1.8tsi dsg
it dose it with tc off , sports mode , eco mode aswell? so im unsure what it could be.
