WRC Rear bumper part numbers
ZahariGeorgiev
Drives: Polo 6R 1.6 TDI
Post by ZahariGeorgiev »
Hello,
I want to replace my rear bumper with that from WRC:
I Want to know the OEM numbers for all necessary parts. So far as i found they are:
- rear bumper : 6R6807421BDGRU
- left light reflector : 6R0945105D
- right light reflector : 6R0945106D
- black cover : 6R6807568N 041
- cover for tow hitch: 6R6807441A 041
Is that correct, and are those all necessary parts for that replacement?
Last edited by ZahariGeorgiev on Sun Apr 05, 2020 8:37 pm, edited 1 time in total.
Re: WRC Rear bumper part numbers
I think this is the correct list, for fitting on a 6R
ZahariGeorgiev
Thanks iichel!
Soon i will do PDC retrofit + headlight washing system and WRC body kit :)
Some helpful links will be nice.
Front and/or rear PDC?
ZahariGeorgiev
Front and Rear PDC
Keep in mind that this has never been done by factory on a WRC. That means you'll have to determine to location of the front holes yourself on the front bumper
ZahariGeorgiev
i saw this:
on one russian forum, and one more thing:
- also planing to install front WRC bumper, already know all part numbers, and do i need to replace the bracket for front bumper?
What do you mean by front bracket?
ZahariGeorgiev
I mean bracket for the front bumper...but i think they are the same
i saw this set:
and wondering what is that in the bag?
I still don't quite understand what you mean by bracket. In the bag are the foam inserts that go on top of the metal inner bumper. You can keep the old ones.
ZahariGeorgiev
my mistake: this is called "mounting for main beam headl"
Ah yes. If you're familiar with etka, you can try to figure out the pr code for the wrc bumper and check all the parts specific for the wrc package. I think for example R-line is 2JE
ZahariGeorgiev
According to Etka, this mounting is the same for all. One more wondering: what is the max rims size for ours polo's. I found that original WRC rims is with following specs: 7.5 J x 18" ET:46, PCD 5x100, so can i go on 7.5 J x 18" ET 42, PCD 5x100, without any modification ? or should i go with 7J x 17" ET 46?
7,5x18 et42 should be no problem. 7x17 et46 is OEM size so that's also perfectly fine
ZahariGeorgiev
Thanks for information :)
