How to look after your car during lockdown
Scotty_boy vw
Re: How to look after your car during lockdown
Post by Scotty_boy vw »
Noonoo632 wrote: Thu Apr 09, 2020 3:15 pm Good afternoon all
I changed my car just over three weeks ago from a Seat Leon 1.4 tsi to a new Vw polo sel with winter pack and style pack in deep pearl black. ( my 4th. VW and third polo ).Car has done just over 100 miles by me and I have not been out in it for over two and a half weeks and my question is how would you look after it during this lockdown perhaps for a few more weeks??
Come to me for coding and retro fitting after Carona is done with seeing as im in Dundee too :D
Scott
aaddaamm94
Drives: 2019 Polo GTI+
Post by aaddaamm94 »
ho8882000 wrote:
OomStu_ZA wrote: Thu Apr 09, 2020 3:37 pm
aaddaamm94 wrote: Thu Apr 09, 2020 3:19 pm I've filled my tank up to 100% to prevent the fuel from evaporating and causing rust. You can get fuel additives as well that stop the fuel going bad because I think petrol only last a few months.
I make sure to take it out once a week for the food shop so that the tyres arn't sitting in the same position for weeks.
Are'nt these new vehicles sold with a plastic petrol tank these days?
I checked my 2019 VW Polo 1.6 MPi yesterday, the fuel tank is plastic.
I also check my 2018 VW Caddy 1.6 Crewbus, the fuel tank is also plastics.
Hadn’t even occurred to me it was plastic [emoji28] my bad.
ho8882000
Drives: 2019 (AW)
Post by ho8882000 »
Griff74 wrote: Fri Apr 10, 2020 1:42 pm Yes, exactly what I said I was going to do, in fact have now done - GPF regeneration can only be performed in “non power” conditions, meaning that regeneration is normally achieved under deceleration. Deceleration increases the amount of oxygen following through the engine and exhaust system.
:roll:
Sorry, my bad.
I miss understood your previous post. :oops:
Noonoo632
Drives: 2020 polo sel 115ps
Post by Noonoo632 »
Scotty_boy vw wrote: Fri Apr 10, 2020 3:29 pm
Scott
Thanks Scott may take you up on that after all this is over as I did some mods on my Seat with Carista. Once I find out how to pm you on this site, just getting used to it 😂😂
Your next plan needs to be to get your "post count" up beyond maybe 10 as you will need that before you are able to PM anyone - and that will be for good reasons.
Noonoo632
Post by Noonoo632 »
Ah yes cheers forgot about that. Active member on seatcupra.net for a number of years.
fazzy
Drives: GTi++/TT/TDi/190E
Post by fazzy »
ho8882000 wrote: Fri Apr 10, 2020 12:07 pm
I think this is the crappiest thing about the Polo.... Not the material which it is made of but the size.
I wish some tuner will come up with a mod of exchanging this little crappy thing for something bigger.
With a range of about 420 km/260 mi on a tank, the dude at the petrol station remembers me by name...
fazzy wrote: Sat Apr 11, 2020 9:46 pm
Fully agree with that. The effective range of this Polo HTI is the smallest I've ever known
I used to get more miles per tank with my Golf R.
ho8882000
Drives: 2019 (AW)
Post by ho8882000 »
I get about 600km per full tank of petrol, my 2019 Polo have the 1.6 MPi petrol engine.
Do you have the GTi? And what is your fuel consumption (l/100km)?
^Fazzy means the GTI, as do I.
I typically got about 280-300 miles per tank (33-35 overall mpg) for a car that officially does 48mpg. That of course was derived from short and longer journeys (no more than 15 miles each way). I'd say this is representative of average use.for most. Prior to the introduction of stop-start tech in 2013 and the false skew that gave the official mpg a 20% boost, I could always achieve the combined mpg figure. With that in mind, 40mpg average was my aim, so about 350 miles a tank expectation.
Since I changed jobs and my commute changed from 13 miles each way to 32 miles, my tank mpg has jumped up to averaging 38mpg. I don't consider it typical.
The GTI should have a bigger tank because it's a thirstier car if you're not doing 30+ mile journeys.
monty831
Drives: 2019 GTI Plus
Post by monty831 »
monkeyhanger wrote:^Fazzy means the GTI, as do I.
That is about what I get for a 28 to 30 mile commute a day. I can stretch 300 miles to a tank and only go over this if I have had a longer commute to Manchester and back
The app is use to track fuel use states my average after 12 full tanks is 34.14mpg
I did once get 37.78mpg
Lowest was 31.25mpg
Sent from my ONEPLUS A6003 using Tapatalk
Dazeredo
Drives: Polo aw1 1.0t 95hp
Post by Dazeredo »
I'm charging the battery every 15 days or so. I needed to do a run a few days, if not I would take the car out the garage to roll the wheels. Also verify the tire pressure to avoid empty tires.
monty831 wrote: Sun Apr 12, 2020 1:43 pm
Lowest was 31.25mpg
On my new 32 mile each way commute, I'm generally getting 40mpg going and 44mpv coming back, attributing the difference to ambuent temp differences. Best I've had was 53mpg on a 90 mile run back from York to Newcastle, religiously sticking to 70mph. Same trip doing 80mph on A19 was 46mpg.
giannis159
Drives: polo aw Rline 1.0 115ps
Post by giannis159 »
Scott
Hey Scott! Any codding in Greece!??[emoji1787][emoji1787]
fazzy
Post by fazzy »
ho8882000 wrote: Sun Apr 12, 2020 10:38 am I get about 600km per full tank of petrol, my 2019 Polo have the 1.6 MPi petrol engine.
Ja, ’n GTi.
Here are pics from my onboard - longterm.
Both, in l/100km and mpg.
Maar, ek se vir jou boet, op die pad ek vat nie kak nie 🤣🤣😊
