After asking about Apple CarPlay I realised I would need to change my head unit and everything however with my version of the composition media system there should still be a MirrorLink app. I have heard the head units with CarPlay have voice button where the mute button is on the older unit. With the older unit it should have a MirrorLink option however I don't have one which is strange as my Grans 2015 Polo has the same head unit but an orange colour scheme and MirrorLink, whereas mine is a blue colour scheme without mirror link.
Thanks for all the help,
Sam
MirrorLink
spotter_sam
- Drives: 2017 MK5 Facelift Polo R-Line
rivatt
- Drives: 6C polo 1.2 TSI
Re: MirrorLink
So what is your question then Sam?
spotter_sam
Re: MirrorLink
Can I get MirrorLink somehow?
Dink
- Platinum Member
- Drives: 2015 GTI
Re: MirrorLink
if you can't get app connect then you can't get mirror link unfortunately
i had the mirror link unit that can't get app connect in my 2015 gti but i have changed to a newer unit so should be able to get app connect now.
Re: MirrorLink
But still not activated? Is your usb port the correct one?Dink wrote: Mon Apr 13, 2020 4:21 pm if you can't get app connect then you can't get mirror link unfortunately
Dink
- Platinum Member
- Drives: 2015 GTI
Re: MirrorLink
the usb port is correct as app connect worked fine when the unit was in CP mode. yeah need to pay to get the whole app connect activatedRlinegrey wrote: Mon Apr 13, 2020 5:28 pmBut still not activated? Is your usb port the correct one?Dink wrote: Mon Apr 13, 2020 4:21 pm if you can't get app connect then you can't get mirror link unfortunately
Re: MirrorLink
Sent me a pm if you like. I can help you with itDink wrote: Mon Apr 13, 2020 5:51 pmthe usb port is correct as app connect worked fine when the unit was in CP mode. yeah need to pay to get the whole app connect activatedRlinegrey wrote: Mon Apr 13, 2020 5:28 pmBut still not activated? Is your usb port the correct one?Dink wrote: Mon Apr 13, 2020 4:21 pm if you can't get app connect then you can't get mirror link unfortunately
Re: MirrorLink
I got you PM, but can not reply yet. Need to fix that with admin
