Dashboard rattle
Sanpe11egino+
Drives: Tiguan
Dashboard rattle
Post by Sanpe11egino+ »
Hi hope everyone is keeping safe , my son picked up his brand new polo gti+ reef blue end of March, so far he has just clocked 300 miles ,an annoying rattle /vibration sound has developed around what seems to be coming from around the dashboard area , has anyone else had a similar problem , obviously once the dealers are back open I will book it in
OomStu_ZA
Drives: 2019 VW Polo GTi
Re: Dashboard rattle
Post by OomStu_ZA »
IMy car had a dash rattle from factory which turned out to be the sound actuater, once they (VW mechanic) turned it off the problem went away.
The soundaktor is a common cause of dash area vibrations / rattles on the mk7 / mk7.5 Golf. Turning it down or disconnecting it often cures the problem.
I’d always be reluctant to let the dealer pull a car’s interior trim apart to find the source of a rattle; they may create further unwanted rattles or damage parts of the interior trim.
MattHGR
Drives: GTI+
Post by MattHGR »
Please check the metal handbrake button.
Mine rattles when the car is cold, and it took a while to work out where it was coming from!
POLO Clive
Post by POLO Clive »
VWs aren't supposed to have squeaks and rattles, he said remembering this TV ad from long ago. lol :D
https://www.youtube.com/watch?v=eKmf0YjZXqo
MattHGR
Drives: GTI+
Post by MattHGR »
POLO Clive wrote:VWs aren't supposed to have squeaks and rattles, he said remembering this TV ad from long ago. lol :D
Can't lie, made me chuckle a little !
LeebzP
Drives: 1.0 TSI R-Line - Energetic Orange
Post by LeebzP »
Check the handbrake button. Mine took me months to figure that out and drove me mad. I slipped in a small piece of paper inside and has never bothered me since. You cant even see the paper. Alternatively, you can go to a VW dealer and explain them your issue.
milessy
Drives: Polo GTI+ 2019
Post by milessy »
I picked up my gti+ in April 2019, and about 3 months later, it developed an intermittant clicking noise from the passenger side (door/dash) but it sounded mainly as if coming from behind the air vent. The car has been into garage several times, initially VW blamed the fitting of a tracker (which wasnt on that side!) and a loose fitting kessy module (claimed by VW due to tracker install) for which I was charged! Later, after I requested the tracking company check out the car, VW then had the car for a few days with a technician using/keeping overnight so he could assess - I agreed as living with this problem has been a total nightmare. VW have now replaced the whole air vent part on the passenger side, in mid March 2020. I took photos of the interior each time it went into the garage (about 5 times over 8 months) just in case there was any damage. But it seems the noise has gone, but of course I haven't been able to test the car properly, as I am holed up at home due to covid 19. VW dismissed the soundaktor and handbrake possibles in my case, which I think was the right call.
Ima
Drives: Polo GTi+ on order
Post by Ima »
The soundaktor can be a pain as it sits in the engine bay just by the bottom of the windscreen and by design vibrates to make the noise. I had an Octavia VRS that would rattle and buzz terribly because of it. Despite the TPI fix it often still did it. On my test drive in the Polo GTI it also did it when on max volume. Have you turned it off in settings to see if that helps?
Sanpe11egino+
Drives: Tiguan
Hi thanks for the replies ,is it possible to turn off the sound soundaktor in the settings ,if so how do I go about it
LeebzP
Post by LeebzP »
Theres a channel on YouTube called HumbleMechanic. Check out his golf R videos, theres a video where he disables the soundaktor. It's on the Golf R but I think it uses roughly the same system as your Polo.
OomStu_ZA
Post by OomStu_ZA »
Sanpe11egino+ wrote: Fri Apr 24, 2020 11:58 am Hi thanks for the replies ,is it possible to turn off the sound soundaktor in the settings ,if so how do I go about it
VW dealer will do it free of charge.
stuartrendall
Drives: 2020 POLO GTI+
Post by stuartrendall »
I believe in the drive mode settings if you go to individual and then change at the top right of the screen set engine sound to eco and it turns it off.
Sanpe11egino+
Drives: Tiguan
Thanks for the replies the rattle was like a few of you said was the handbrake button
Dazeredo
Drives: Polo aw1 1.0t 95hp
Post by Dazeredo »
On mine it had a rattle in the door button to deactivate the rear windows but I solved with a little of fabric tape. It's something to talk about when I really need to go to the dealership.
