Re: iichels Polo 6R 1.2TDI Bluemotion --> OEM++ R-Line conversion
:mrgreen:
New transporter is very similar to polo AW
https://forums.ross-tech.com/showthread ... T6-1-Bulli
:lol:
Very interesting that autoscan, thanks. :wink:
I'm wondering that if the original new parts bought by customers and that cannot be used because someone avoids it through software (CP, SWaP, FeC, etc.) are built without contaminating our planet, and if its destruction and recycling process is not Pollute our planet.
hmm...
EN:
“you reap what you sow”
ES:
"Quien siembra vientos, cosecha tempestades"
Since some people ask me, I'll post it here
Dual reverse lights
Dual rear fog lights
What is needed:
LHD unit on the right side: 6R0945096AH, 6C0945096K (or other replacement number)
RHD unit on the left side: 6R0945095AC, 6C0945095L (or other replacement number)
Dual colour LED with BA15s fitting
https://www.drive2.ru/b/516010428715761880/
https://www.drive2.ru/b/537505606160875826/
https://www.drive2.com/b/2851809/
https://ifinterface.com/prog/car/cp2/inprog.php
Select Polo (PO), select year 2010 - 2013 for Polo 6R, 2014-2017 for Polo 6C, group 9 (electrics), subgroup 945-000 (tail lights)
Now, for the pin layout, have a look here:
viewtopic.php?f=56&t=58703&start=390#p482495
TL, DR, Pin layout, images by ciclo
Now, the fitting BA15s is powered by the original wire.
LHD left: T6/1
LHD right: T6/5
RHD left: T6/2
RHD right T6/6
I am calling left the left side of the car, if you stand behind it. Drivers left, so to say.
You need to use this information to determine the absolute correct wiring. You might need to swap wires to keep the correct function.
The LEDs I bought a few years ago have the white light powered by the BA15s socket and the red light by the extra wire. So I needed to solder the wire to the plate that connects T6/1 on the left.
It really depends on the type of LED, what the function of the wire/socket is and the correct wire you must take. In my case, I had to make a modification to the wiring on the left side.
I switched T6/1 and T6/2. If your LED is configured differently, you might need to change T6/5 and T6/6 on the right side.
No reverse/rear fog:
Dual reverse:
Dual rear fog:
Inside of the left side bulb carrier:
Some people are wondering, is my car still alive? Is it still driven?
The answer is YES :mrgreen:
Just not a lot of mods happening... Mostly just maintenance.
Recently done:
- Two new rear wheel bearings
- New windscreen wipers all around
- Respray of the door handles. They were still metallic grey from the donor car. Now they're all L041 uni-black :)
I'm planning to do a MFSW with cruise control with the help of MaDwArLoCk's emulator module.
benzinkopf
Drives: 1.2TSI 105HP DSG7
Post by benzinkopf »
Love to hear that!!!
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
Me too + 1
skappa51
Drives: VW polo 6R
Post by skappa51 »
iichel wrote: Fri Sep 21, 2018 9:04 am I'd take the 2,5 meters, 1,5 is way too short.
White button illumination. Simply lovely :oops:
Yo iichel, do you still remember what kind of LED you used to replace all the red ones?
if so, you stil have a link ? :D
skappa51 wrote: Wed May 06, 2020 7:38 pm
I'm sorry but I don't really remember.
Yee Ha :mrgreen:
Thanks to MaDwArLoCk
GRA high on TDI
Thanks to firegrafik and RoFireman from Russia
ag69
Post by ag69 »
Very nice iichel.
I'm booooored. So a new mod.
You need double-sided tape and fuses :mrgreen:
And I'm too lazy to look up the OEM part numbers for the fuses, lol, but I taped them to the inside of the fuse holder cover.
ag69
Post by ag69 »
You are not only intelligent and talented but also creative.
Preparing for the next mod... Some hardware... Some VCDS... Byte 1 bit 0 -> 1.
But what module? :mrgreen:
Tuesday,26,May,2020,05:16:04:11868
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
www.Ross-Tech.com
Workshop Code: 123 12345 012345
VIN:   License Plate:
Mileage:-  Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 05 08 09 10 15 17 19 20 25 2B 2E 37 3C 44 47 55 56
          57 61 65 69 6C 77
VIN:   Mileage:-
05-Acc/Start Auth. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
47-Sound System -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (J000-CFWA)       Labels:. 03P-906-021-CFW.clb
   Part No SW: 03P 906 021 B    HW: 03P 907 425
   Component: R3 1.2l TDI   H06 9980
   Revision: 12005001    Serial number:
   Coding: 00114036033401080000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ECM12TDI03103P906021B 001043
   ROD: EV_ECM12TDI03103P906021B.rod
   VCID: 270B06DDAF6FF1F3321-8073
Readiness: 0 0 0 0 X
   Part No SW: 6R0 907 379 AS    HW: 6R0 907 379 AS
   Component: ESP9.0i front H02 0002
   Serial number: --------------
   Coding: 21DD2885432500C5841A146EC25500521505
   ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
   VCID: 0F7B4E7D27DF89B3DA1-805B
Address 05: Acc/Start Auth. (J518)       Labels:| 5K0-959-434.clb
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0346244897
   Coding: 030C0C
   ASAM Dataset: EV_KESSYPQ35G A02717
   ROD: EV_KESSY_PQ35GP.rod
   VCID: 372BD69D7FCF6173A21-8063
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H12 0812
   Revision: V0000000
   VCID: 3829D5A172516E0BABB-806D
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 173171327
   Coding: 3EB02FBF68EB2400B33807E0FFEB9FF0F08060EF608D78D071E000030800
   VCID: 2B03FAEDB307D593D69-807F
   Component: RLHS 220816 0  42  0106
   Coding: 0714DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8611
   Serial number: KU0KU011111300010103
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8611
   Serial number: KU0KU007111300016463
   Coding: 1000AB
   Subsystem 8 - Part No SW: 6R0 959 811 G    HW: 6R0 959 811 G
   Component: J388__TSG_HL  008 1611
   Serial number: KU0KU027011200011418
   Coding: 58BC32
   Subsystem 9 - Part No SW: 6R0 959 812 B    HW: 6R0 959 812 B
   Component: J389__TSG_HR  002 0803
   Serial number: KU0-KU004.06.0913330
   Coding: 08BC32
   Part No SW: 7E0 919 475 L    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0106
   Revision: --------    Serial number: 28231422402620
   Coding: 318001
   VCID: 3B23CAAD43E74513469-806F
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX0142TCE
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACD9F691C3DEC9BCDF-801F
   Serial number: 3575HRB40650BI7U48C8
   Serial number: 3585HRB405J09RECEOUJ
   Serial number: 3515RRB405T0BTBEF9G7
   Serial number: 3525RRB405R0BTBEKPFQ
   Part No SW: 6R0 920 870 A    HW: 6R0 920 870 A
   Component: KOMBI         H04 0709
   Coding: 140E01
   VCID: 3333E28D6BB78D539E9-8067
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 042200
   VCID: 688945E162713E8BFBB-803D
   Revision: AA001001
   Coding: 0404000000000000000000
   VCID: 2E05F3F98095A0BBF17-807B
   Component: IMMO          H04 0709
   Coding: 000007
   VCID: 6A8D3FE97CFD0C9BEDF-803F
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
   Component: ELV-PQ35      H20 0240
   Revision: 00000000    Serial number: 11000256123005
   Coding: 4100000000000000
   ASAM Dataset: EV_ELVMarquMPVW36X A01001
   ROD: N/A
   VCID: 2F3BEEFD879FA9B3FA1-807B
No ASAM data for: "EV_ELVMarquMPVW36X" (VW25)
   Part No SW: 5N0 035 342 G    HW: 5N0 035 342 G
   Component: SG EXT.PLAYER H19 0770
   Revision: A1001003    Serial number: 7666620365
   Coding: 010100
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 1T0 035 686 E    HW: 1T0 035 686 H
   Component: RNS-MID       H26 6276
   Revision: AB001001    Serial number: VWZ6Z7P1950254
   Coding: 00070002010000A10001
   VCID: 3635DB997845987BB97-8063
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V16  8536
Address 3C: Lane Change        Labels: Redir Fail!
   Part No SW: 7E0 907 566 B    HW: 4L0 907 566 A
   Component: J0769 SWA MasterH13 0120
   Revision: 00H13000    Serial number: 6PZ 009 014-07
   Coding: 0010161
   Shop #: WSC 02756 790 00000
   VCID: 2F3BEEFD8B1FA9B3FA1-807B
   Subsystem 1 - Part No: 7E0 907 568 B
   Component: J0770 SWA Slave H09 0110
   Subsystem 2 - Serial number: 6PZ 009 014-27
   Subsystem 3 - Serial number: 5F31.03.1100H090003CH21982ˇ
   Subsystem 4 - Serial number: H21982ˇ
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6R1 909 144 AD    HW: 6R1 909 144 E
   Component: EPS_TRW_ALow  312 3124
   Serial number: CF3F0205
   Coding: 000300
   ASAM Dataset: EV_SteerAssisUDSTRW 014026
   ROD: EV_SteerAssisUDSTRW_014.rod
   VCID: 79AF10A5095BB703145-802D
Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H08 6831
   Revision: --------    Serial number: EAA098C0000052
   ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
   ROD: N/A
   VCID: 280905E1A271FE8B3BB-807D
No ASAM data for: "EV_AudioVerst10KanalSTT4" (VW25)
   Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
   Component: AFS-ECU       005 0050
   Revision: --------    Serial number: --------------
   Coding: 0D4A000001000000
   ROD: EV_HeadlRegulVWLWRCC.rod
   VCID: 3A2DCFA94CDD7C1B5DF-806F
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
Address 57: TV Tuner        Labels: None
   Part No SW: 3C0 919 148 B    HW: 3C0 919 148
   Component: R78 DTV-JP          0250
   Revision: R0H14000    Serial number: 80100800042102
   Coding: 0000816
   Shop #: WSC 01324 020 00200
   VCID: 280905E1AEF1FE8B3BB-807D
   Subsystem 1 - Part No: 4F0 919 805
   Component: R204 TVKLeser       0010
   Part No SW: 7E0 907 534     HW: 7E0 937 090 C
   Component: Batt.regelung H82 0752
   Coding: 030F1A5A
   Subsystem 1 - Part No SW: 6C0 915 181     HW: 6C0 915 181
   Component: J367-BDM  H08 0223
   Serial number: 61083A44504351928092
   Serial number: 40000000058319
   ROD: EV_RDKBERU30_005.rod
Address 69: Trailer (J345)       Labels:. 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 E    HW: 1K0 907 383 E
   Component: Anhaenger     H07 0080
   Revision: 3A002002    Serial number: 00000116932377
   Coding: 0100000100000000
   VCID: 2F3BEEFD871FA9B3FA1-807B
Address 6C: Back-up Cam.        Labels: 5N0-907-441.clb
   Part No SW: 7E0 907 441     HW: 7E0 907 441
   Component: J772__Rearview      0040
   Revision: 00H08000    Serial number: 525PA8-J060533
   Coding: 0030115
   VCID: 65974CD5996323E3C0D-8031
Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 E    HW: 3C8 035 730 E
   Component: Telefon       025 0983
   Revision: --------    Serial number: 35502105254406
   Coding: 020100000100010000000101
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi.rod
   VCID: 25170CD5D563E3E300D-8071
End----(Elapsed Time: 02:23, VBatt start/end: 11.7V/11.6V. VIgn 11.4V)-----
It will break the bank :lol: :lol:
benzinkopf
ACC please!
