Installing foglights?
Lhzbwz
Drives: Polo AW
Post by Lhzbwz »
I’m thinking about installing foglights on my polo. Does anyone know if it’s a simple plug-and-play or do I need to change the cables? I guess some programming/activation is needed..
giannis159
Drives: polo aw Rline 1.0 115ps
Re: Installing foglights?
Post by giannis159 »
I installed plug and play and no errors. Nighteye h8.ImageImage
Lhzbwz
Drives: Polo AW
Post by Lhzbwz »
Thanks for the reply! But I want to install foglights on a car that doesn’t have them - not change the bulb to led :D
giannis159
Lhzbwz wrote:Thanks for the reply! But I want to install foglights on a car that doesn’t have them - not change the bulb to led :D
I think you must change to led..
wayne10244
Drives: Polo GTI +
Post by wayne10244 »
Check if you got the correct loom with plug first! If not it’s going to make it harder for you to fit as your would to wire the fuse box plus activator it.
MattHGR
Drives: GTI+
Post by MattHGR »
https://www.kufatec.com/en/volkswagen/v ... -aw1-43545
Comes with a coding dongle and connection guide.
Lhzbwz
Drives: Polo AW
Post by Lhzbwz »
Thanks for the reply’s! By the link you sent I guess i have to change the cables as well.. Even though it looks like the same plug? If I don’t order a complete kit..
MattHGR
Drives: GTI+
Post by MattHGR »
Mine already has fogs, but I'm guessing your fog light housing doesn't have any cables going to it ?
Only thing I can think of for needing a cable set.
