6R rear badge/camera
Aquavalver
- Drives: 2013 Polo Blue GT
Does anyone know if the Mk7 Golf rear badge/rear camera happens to fit the 6R as I think they are both 110mm. I think the Mk6 Golf one fits with an adapter plate and being as its the same size, I wondered if the Mk7 Golf could fit?
benzinkopf
- Drives: 1.2TSI 105HP DSG7
Re: 6R rear badge/camera
Yes it can. i installed once. for polo, will always need the adaptor. the design is abit diff on the logo surface but actually not that bad.
Aquavalver
Did you use the Mk6 Golf adapter plate? If so, did you need to modify that at all?benzinkopf wrote: Wed May 27, 2020 9:27 am Yes it can. i installed once. for polo, will always need the adaptor. the design is abit diff on the logo surface but actually not that bad.
benzinkopf
no. i used the china adaptor for polo. if not mistaken, one or two locking latch/hook need to be cut.
Aquavalver
This is one of Ali express:benzinkopf wrote: Wed May 27, 2020 9:47 am no. i used the china adaptor for polo. if not mistaken, one or two locking latch/hook need to be cut.
https://www.aliexpress.com/item/4000904 ... hweb201603_
This is the one on Car systems EU:
https://www.carsystems.eu/vw-polo-6r-rv ... d1443.html
benzinkopf
In my 6R, i uses the original bracket (one of the pioneer design) by ciclo. I think its the same as what carsystem offers.
the china is at first a bit confusing, but after several tried for my friend’s polo, it works. the china version is not really an “adaptor”. its just simple integrator means it just lock the camera and the mounting circle frame by clamping both. not like the one ciclo’s design.
The RVC adapter can be used for the Golf MK7's RVC when installed in the 6R, but be careful, you have to take into account that the ORIGINAL camera for Golf MK7 does not use the same video signal as the ORIGINAL camera for Golf MK6, and the Golf7 MK7's RVC is not compatible with the original radio/navigation systems that are factory installed in the 6R (RCD/RNS).
On the 6R you can install:
-RVC Golf MK7 for Composition/Discover media from 6C, T6, etc ... (many things to do here... something complex
-RVC Golf MK6 for RCD/RNS with black 26-pin video connector. ... (plug and play ...
-...and also the exciting world of non-original parts.
Aquavalver
Part of the reason for mentioning the Mk7 Golf RVC, is that I rather like one of the rear badges which I think would go very well with my car. Not sure if the Mk7 badge would fit to the Mk6 RVCciclo wrote: Thu May 28, 2020 6:33 am The RVC adapter can be used for the Golf MK7's RVC when installed in the 6R, but be careful, you have to take into account that the ORIGINAL camera for Golf MK7 does not use the same video signal as the ORIGINAL camera for Golf MK6, and the Golf7 MK7's RVC is not compatible with the original radio/navigation systems that are factory installed in the 6R (RCD/RNS).
-RVC Golf MK7 for Composition/Discover media from 6C, T6, etc ... (many things to do here... something complex)
-RVC Golf MK6 for RCD/RNS with black 26-pin video connector. ... (plug and play ...)
Ok Tim, I think the badges (Golf MK7 vs MK6) are not interchangeable. I'm not sure.
5K0853630B ... MK6
5G0853617A ... MK7
Maybe on AliExpress there is something interesting for the MK6 RVC ... I mean the shiny black background.
5K0853630B ... MK6
5G0853617A ... MK7
Aquavalver
It's actually the shiny black background and the blue edging that I like on this one particular model, as it would go great with my car. I've ordering just the badge for now so I can see-if it won't work, then I'll just sell it onciclo wrote: Sat May 30, 2020 4:03 am Ok Tim, I think the badges (Golf MK7 vs MK6) are not interchangeable. I'm not sure.
5K0853630B ... MK6
5G0853617A ... MK7
