LED headlamp retrofit
VWPOL0GTL
Drives: GTI
Post by VWPOL0GTL »
Hi guys,
Has anyone with halogen headlights on their Polo's tried retrofitting the LED headlamps? There's a few videos on youtube which shows it as a straight plug and play with something like this. Just curious on what are people’s experience with retrofitting these and the quality/longevity (since these are aftermarket and not OEM).
Also does anyone know if the 10 pin plug is standard across all VW Polo AW’s (specifically GTI), or does it differ country by country (I’m from Australia). I presume it’ll be standard across since from memory all Polo AW’s are manufactured in South Africa
[https://www.aliexpress.com/item/4000009 ... x5TxmDN2pQ](https://www.aliexpress.com/item/4000009 ... B-3w5dppX8)
giannis159
Drives: polo aw Rline 1.0 115ps
Re: LED headlamp retrofit
Post by giannis159 »
Ι οrdered them and now i am waiting... I spoke with some guys in Instagram and its perfect!!! I suggest them! If i they come i can present them..
VWPOL0GTL
Drives: GTI
Post by VWPOL0GTL »
giannis159 wrote: Wed Apr 29, 2020 5:31 pm Ι οrdered them and now i am waiting... I spoke with some guys in Instagram and its perfect!!! I suggest them! If i they come i can present them..
Yeah man please make a post of them when you receive them 👌
giannis159
Οκ
petros.samaras
Post by petros.samaras »
any updates?
giannis159
My package is in customs i will receive the package maybe tomorrow or next day. Then i will inform you..
giannis159
petros.samaras wrote:any updates?
Έλα ρε φιλαράκι Έλληνας? Plug and play!ImageImage
OomStu_ZA
Drives: 2019 VW Polo GTi
Post by OomStu_ZA »
The top LED strip seems a lot wider than OEM?
giannis159
OomStu_ZA wrote:The top LED strip seems a lot wider than OEM?
A little bit yes.Image
petros.samaras
Μπραβο ρε φιλε. Πες μου link να τα παρω και εγω. Η λωρίδα led φωτιζει συνεχεια ή πρεπει να έχεις τα φώτα ανοιχτα;
ROG3R
Drives: Polo Mk6
Post by ROG3R »
I was one of the first to buy, and I'm using since November 2019, got the all led version with red stripe. Working good so far.
I got from this link, but for some reason the seller deleted my review :?: :!:
http://s.click.aliexpress.com/e/_d9CXEbq
some pics:
Extra information:
-Low beam uses D2H lamp (hard to find), and high beam a H7
-The turn signal (blinker) is "dynamic", different from the OEM headlight
-When you turn on, it has a bizarre animation (the LEDs flash, the top bar turns blue and then turns white again, like a Mercedes-Benz
petros.samaras
Does it require extra wiring for the DRL? OR its plug and play? Also the link from aliexpress is not working. I have the polo 2018 (aw1) i think it will be safe to buy these headlights. Right?
giannis159
Its plug and play if have same car(i mean headlights, drl and fog lights). Are you greek? Because i wrote in greek language in my previous. #Aliexpress € 533,00 25%OFF | AKD Car Styling for VW Polo Headlights 2019-2020 New Polo LED Headlight DRL Head Lamp Low Beam High Beam ALL LED Accessories
https://a.aliexpress.com/_dXQYiMG post.Image
giannis159
petros.samaras wrote:Μπραβο ρε φιλε. Πες μου link να τα παρω και εγω. Η λωρίδα led φωτιζει συνεχεια ή πρεπει να έχεις τα φώτα ανοιχτα;
Φιλαράκι να ξέρεις θα φας τελωνείο. Τα φανάρια γαμανε άμα θες και είσαι Αθήνα να συναντηθούμε να τα δεις. Εγώ με dhl τα πήρα σε 5 μέρες είχαν έρθει.
petros.samaras
Ποσο τελωνειο πληρωσες; Εχω την highline εκδοση, που εχει φωτα ημερας led στον προφυλακτηρα αλλα οχι στα φαναρια. Ειμαι απο μακρυα δυστηχως φιλε μου.
