It’s not in eco mode to save fuel. I fill her car up once every 6/7 weeks and it’s only costing about £30/£40 each time with roughly 100/150 miles still displayed on the range so it’s not a cost saving exercise. She doesn’t drive many miles but having the engine in eco mode dampens the throttle response. As she has only been driving since about February it is allowing her to get use to driving and keeping it more smooth. She learnt how to drive in a manual also so this gives her a nice steady pace for getting use to the car without the added fear of pressing the peddle a little too much at junctions or at low speeds. Once she is use to the car and comfortable I’m sure it will end up in normal or sport but at the moment it’s simply not needed for her. After all she’s only drive about 600miles in her life with the rest on the polo driven by myself while she was doing her lessons to run it in.The Random Dan wrote: Sat Jul 18, 2020 4:38 pm Having it in Eco mode all the time on short journeys probably doesn’t help.
Eco mode is a waste of time, just leave it in normal, you won’t see any negative effects on your fuel efficiency
Only the engine mode is in eco, gearbox is in normal drive, steering normal and suspension is also normal.
