ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP. 🧙♂️
Re: ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP
Does your wife like the menu language of your MIB in English?
I remember your 6R (and Touareg?) having the menus in Spanish.
Personally I have all my devices in English (phone, laptop, television, cars) because sometimes Dutch translations are weird
The language thing is only in deference to the forum.
... although I also like my devices to be in English, but only for working days, ... for weekends and holidays in Spanish.
The worst thing for me to write in English is the apostrophe, with the Spanish keyboard the apostrophe is wrongly placed ...
Golf 7.5 FM2 + DAB Amplifier.
This is the way I installed it.
Ali in one
In the wiring from AliExpress ...
- Two rear USB sockets.
- White LED light for 12V Socket.
- ReMO...E control for door Garage.
- LED ambient light for front storage compartment.
Golf 7.5 Additional fuse box. 4 fuses.
viewtopic.php?f=58&t=72376&start=90#p572693
There is another hole just like this and easier to access at the bottom. Get down and look.
... although it is slightly visible in one of the previous images.
The fuse holder does not fit easily.
When you get bored with the white LEDs, check out the LEDs from Audi A4 B9 (and other models). Then you have the possibility to get 30 colors controlled from the infotainment.
All lamps require an extra wire for LIN-bus and permanent supply. Your BCM should be ready
All lamps from A4 B9 including footwell works with BCM 084.
For Passat / Tiguan that have 086 BCM footwell lights are not working
Thank you very much for your recommendation diskoboy.
In fact, I already made a preliminary study of the colored lights and the necessary adaptations thanks to the madwarlock thread.
https://www.drive2.ru/l/565546726081953800/
He is in the process of doing the entire installation, so it will be a good thread to follow.
Images of previously planned retrofits.
Easy.
Difficulty level = >7 ...(0-10)
viewtopic.php?f=58&t=72376&start=135#p574160
viewtopic.php?f=58&t=72376&p=575108#p575108
Dremel and flamethrower.
Easy.
Holder for the footwell lights - are this part of the holder for BCM or is it a separate one ?
In Ekta it seems as a part of the BCM holder but I’m not sure (need it for another project then Golf)
The holder for front left footwell light is part of the Dashboard structure.
Not related with the BCM holder.
Ok, today I have done some installations of the aforementioned retrofits.
- The white LED light in the front storage compartment is ...hmm... SUPREME! ... I recommend it without a doubt, it is perfect in conjunction with the original ambient white LED lights (footwell lights).
It does not disturb, you only see a warm and pleasant indirect white light if the compartment is open. If it is closed there are no light leaks.
- The ReMODE control for opening/closing the garage door perfectly works! ... better than on my 6R, it has more range and I don't know why, the installation is similar, the only thing that is different is the button (I will have to investigate).
- The two rear USB sockets charge the smartphone or other devices correctly. The structure for ventilation fits wonderfully.
- The USB HUB with second USB socket works perfectly with various types of USB sockets (T6, 6C, Golf). The two USB sockets work for Android, MirrorLink, USB devices, such as charging, I guess it'll be the same for CarPlay. I still have to decide which of the USB sockets to install because they have structural differences depending on the location.
I have images but I want to wait to have everything in order to show them.
The white LED light in the front storage compartment is SUPREME! ...Yuppie!!!
... some pictures of the installation process for 'Ali in one' and USB HUB.
Center console area.
I forgot to take a photo of the crimp with original terminals on the T20 connector. Original and added wires in the same contact-terminal. Easy and clean.
I'll do it later when I change the electronic climate control unit for heated seats. (soon) ... edit viewtopic.php?f=58&t=72376&p=574991#p574991
The images of the results for later, as soon as possible...
