ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP. 🧙♂️
Re: ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP
USB 2 activation:
5F
SA
IDE10480-MAS10742-Interface for external media: activation-Connection 2,not activated ,4 ... (activated)
APP Available Devices.
USB Sockets
I have no reason to install the second USB socket in the front storage compartment.
My priority will be to facilitate access to this second USB socket for the passenger, but also accessible to the driver.
2nd USB
I have chosen the location for the second USB considering which panel was the cheapest to make the hole.
The glove compartment was totally discarded, there is no clear place for its location.
and the two rear USB sockets for charging.
Golf 7.5 IC with Color Display and Blue Needles installed!
Bought on eBay. (I also bought the blue needles on eBay from the same seller, airbone-x, that I bought my first 6R BlueGT IC from a long time ago)
Kms correction. (technohead: requires a special tool, devised by madwarlock, to correct Kms to current)
Blue needles installed. (technohands: skills and good tools are required to solder the LEDs, madwarlock has them)
From
To
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G1 920 750 D HW: 5G1 920 750 D
Component: KOMBI 310 2700
Coding: 07A52A802680000801887A051401000000000000
Shop #: WSC 00200 935 01530
ASAM Dataset: EV_DashBoardVDDMQBAB 009068
ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
VCID: 280905DC9274F02B3A3-807C
Well, I have to correct the position of the small needles, which can be done easily with VCDS (output tests) and some patience.
90º? = NO
Tank completely full? = NO
From
To
Thursday,27,August,2020,18:42:34:32438
VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4526.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW License Plate:
Mileage: 33030km-20523mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 20 42 44 52 5F 65
VIN: WVWZZZAUZKPCICLOW Mileage: 33030km-20523miles
Address 01: Engine (J623-DKRF) Labels:. 04E-907-309-V1.clb
Part No SW: 04C 906 025 L HW: 04C 907 309 BB
Component: R3 1.0l TFS H20 6198
Revision: D7H20000
Coding: 01190032234415082000
Shop #: WSC 00046 028 00070
ASAM Dataset: EV_ECM10TFS01104C906025L 002003
ROD: EV_ECM10TFS01104C906025L_002.rod
VCID: 290F00D8897EC92325D-807C
Readiness: 1110 0001
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 DD HW: 5Q0 614 517 AC
Component: ESC H25 0424
Revision: 00000000 Serial number: 51998000000173
Coding: 01FA6AA114202170477B060560CA2580562884E26006A4733420F0084002430B00000012121212B835351919323200
Shop #: WSC 00046 123 12345
ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
VCID: 76B51BA40840D6DB78F-8022
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5G0 907 044 CE HW: 5G0 907 044 CE
Component: Climatronic H04 1801
Revision: 00001K08
Coding: 00020003200110011005004000101022
Shop #: WSC 00028 028 00068
ASAM Dataset: EV_ACClimaBHBVW37X 006145
ROD: EV_ACClimaBHBVW37X_006_VW37.rod
VCID: 6C8139CC460C1C0B9EB-8038
Fresh Air Blower Front:
Geber für Kältemitteldruck/Kältemitteltemperatur:
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 DD HW: 5Q0 937 084 CG
Component: BCM MQBAB H H38 0273
Serial number: 00001822001136
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_BCMMQB 019001
ROD: EV_BCMBOSCH_019.rod
VCID: 7DA704882D768583395-8028
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 180621 043 0551
Serial number: 180705074106
Coding: 0E4DDD
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 052 0107
Serial number: SBY18M08D06H04M32S34
Coding: 06A8DD
Steering Column Switch:
Subsystem 3 - Part No SW: 5Q1 953 507 HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0060
Serial number: 00000002081804401346
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 5QA 919 294 C HW: 5QA 919 294
Component: PDC 8 KanalH07 0050
Serial number: 000308418018193
Coding: 0471151801
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_EPHVA18AU3700000 009039
ROD: EV_EPHVA18AU3700000_009_VW37.rod
VCID: 4CC1994C264CFC0BFEB-8018
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A
Component: ACC BOSCH MQB H11 0682
Coding: 2B00670119FFC728949C810560400600000000000000000004
ASAM Dataset: EV_ACCBOSCHVW416 002008
ROD: EV_ACCBOSCHVW416_002_VW37.rod
VCID: 44D1B16C0E1C344B36B-8010
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 BJ HW: 5Q0 959 655 BJ
Component: AirbagVW21 006 0339
Serial number: 003VWR4F1CUQ
Coding: 98CCC000000000005C0000CF000800000065
Shop #: WSC 00028 028 00064
ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 094F605869BEA92305D-805C
Belt Pretensioner left:
Subsystem 1 - Part No SW: 5G0 980 945 B HW: 5G0 980 945 B
Component: BeltPretRevFL H37 0350
Serial number: 34169667E30071820325
Coding: 333135
Belt Pretensioner right:
Subsystem 2 - Part No SW: 5G0 980 946 B HW: 5G0 980 946 B
Component: BeltPretRevFR H37 0350
Serial number: 34169668E31071830145
Coding: 333135
Side Sensor Driver Front:
Subsystem 3 - Part No SW: ----------- HW: 480 002 307 18
Component: SideSensor_Df 001 0887
Serial number: 35700000000F8745C23S
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 4 - Part No SW: ----------- HW: 480 002 807 18
Component: SideSensor_Pf 001 0887
Serial number: 358000000000EC18233G
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 5 - Part No SW: ----------- HW: 480 403 107 18
Component: SideSensor_Dr 003 6149
Serial number: 3510001A729FD154210-
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 6 - Part No SW: ----------- HW: 480 403 107 18
Component: SideSensor_Pr 003 6149
Serial number: 3520001A929FD1515577
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 7 - Part No SW: ----------- HW: 480 402 306 18
Component: FrontSensor_D 003 6149
Serial number: 3550001A326704A3C63.
Coding: 2D2D2D
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 433 4368
Revision: -------- Serial number: 0006434834
Coding: 030100047F085700DA000258080F00010001070000000000000000000000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_GatewNF 013025
ROD: EV_GatewNF_VW37.rod
VCID: 6E8533C47010EE1BB0F-803A
Alternator:
Component: 0-00-00-00-00
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 5G0 959 442 AB HW: 5G0 959 442 AB Labels: 3C8-959-537.CLB
Component: E221__MFL-MD9 H18 0052
Serial number: 39190002063230049307
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Component: J367-BDMHella H10 9070
Serial number: 9353818504
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 3G0 857 511 BD HW: 3G0 857 511 BD
Component: FLA H01 0010
Revision: AA001001
Coding: 0404000000000000000000
ASAM Dataset: EV_HighBeamAssisAU33X 001019
ROD: EV_HighBeamAssisAU33X_VW37.rod
VCID: 6B833AD043021B33971-803E
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q4 959 593 F HW: 5Q4 959 593 F
Component: TSG FS 006 0246
Serial number: 0000305474246
Coding: 00150320D000048000001000
Shop #: WSC 00020 999 12345
ROD: EV_DCU2DriveSideMAXHKLO.rod
VCID: 48C9A55C3234102BDA3-801C
Drivers Door Rear Control Module:
Subsystem 1 - Part No SW: 5Q4 959 811 F HW: 5Q4 959 811 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000009798407
Coding: 010000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 AA HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 131 1081
Coding: 011F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 73B322B01B32C3F35F1-8026
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q4 959 592 F HW: 5Q4 959 592 F
Component: TSG BFS 006 0246
Serial number: 0000336638884
Coding: 00150320DE00048000001000
ROD: EV_DCU2PasseSideMAXHKLO.rod
VCID: 47CBA6603F2A1F53D39-8012
Passengers Rear Door Control Module:
Subsystem 1 - Part No SW: 5Q4 959 812 F HW: 5Q4 959 812 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000009846262
Coding: 090000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 874 C HW: 3Q0 035 874 C
Component: MU-S-ND-ER 853 0891
Serial number:
Coding: 02731001FF0000005111010100880A001F0500D401200100CF
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 323DE7B4A4A88AFB947-8066
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H52 8130
Serial number: VWZ6ZHV2691212
Data medium:
Subsystem 2 - Part No SW: 5NA 919 866 AR HW: -----------
Component: ECE AS 20/21 --- 1430
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H04 0009
Serial number: 30000000250801
ROD: EV_RDKBERU30_006_VW37.rod
VCID: 3431E1AC5EBC84CB86B-8060
End----------(Elapsed Time: 01:17, VBatt start/end: 13.4V/13.4V)-----------
90º? = NO
Really nice, I prefer this look better compared to all digital one. The all digital one worth only for the map view, but still is lucking. The map view from an Audi from 2018 car looks way better to what VW is offering in 2020 cars. I think Audi have greater resolution screens and satellite view vs map view on VW.
If you keep this IC for long time, maybe worth to modify the eeprom to show the actual coolant temperature (if vw is using the same scaling system as they do in 6R IC)
Hey exantas, in the real world this IC looks much better than in the pictures. Worth? Yes, as soon as you sit down to drive you realize that you enter a new atmosphere simply because the needles are blue. It makes great sense of all the blue lines on the display and the infotainment system.
If anyone thinks of doing it, I recommend they get in touch with madwarlock, his great skills makes it very difficult to distinguish the soldering of an original LED with the solders he does, even with a magnifying glass. Also for other reasons ... his works are awesome!
Audi is Audi, nothing more to say ... totally agree with you.
I know exactly what you mean by displaying the real temperature of the coolant and I appreciate your recommendation, I have even read magnificent dissertations about it in various forums, all of them with their good and certain reasons, but I have got used to seeing 90ºC, which it offers me a lot of reliability, and also to visualize the engine oil temperature in the menus (IC and 5F) to verify the temperature changes in the engine depending on the required performance and the driving conditions.
Some time ago I was meditating on your recommendation for my 6R, but I prefer the needle at 90ºC, I even consider it essential, it gives me confidence.
That is, and reflecting slightly, it's not a Golf R with 400 HP engine tuning and I prefer the needle to permanently point to 90°C on my wife's Golf ... so that it only moves in the event of a true engine problem.
I really appreciate your comments.
Golf 7.5 Installation of seat heating elements, cables and new drawer.
viewtopic.php?f=58&t=72376&start=90#p572441
viewtopic.php?f=58&t=72376&start=90#p572707
- Refer to erWin to remove the seats and covers. Ultra easy, just like all the times I've done before.
- The following images are for an ultra basic passenger seat, without height adjustment and without any electrical comfort system. With seat occupied recognition and fastened seat belt detection.
- The process for the driver's seat is similar with the difference that it is height adjustable. Nothing to worry about, just flex a metal tab with a hook or small flat screwdriver to remove the plastic handle from the height adjustment lever.
- The added parts are the footwell lights (long ago) and heating elements (now).
edit: Driver seat.
Passenger seat.
It is not necessary to cut the last two upholstery clips at the top of the backrest.
BGS 8872
By the left side the seat heating element wires and by the right side the backrest heating element wires, to join in the middle and continue with the rest of the original wiring. Perfect!
edit: Driver seat.
Passenger seat.
BGS 8872
Yesterday my VW dealer informed me that they had received our new VW T-Cross.
The seller, a lifelong friend, and 'in a particular way', had the deference to send me many photos of its arrival at the VW dealer. a great professional and a better person ...
I made a quick video to share the news with the family:
Original Video : https://www.youtube.com/embed/e70NYt3KO ... autoplay=1
The best feature of the T-Cross in this segment (size) is its ease of access to the interior, was the main reason to buy it.
Fully equipped not to touch in 4 years ... the color was chosen to experience new sensations ...
ciclo's family car for daily use.
Congratulations! Good colour!
- Drives: Cross Polo 2010 TSI
Congratulations Fernando!
Thank you very much to both, my dear friends!
We're thinking of naming it, and everything points to naming it 'the Dutch' ... in Spanish of course, which is something like ... 'el Holandes' (from Holland) ... mainly by the colour.
The day of delivery the VCDS will eat it whole (Autoscan, Adpmaps, etc), to have the original logs of the whole car, ...with the function of reading the whole car it is now easier...
Enjoy the new car ciclo. It's an interesting colour for an interesting looking car. You are going to test first hand the new steering wheel also
Would an auto scan affect somehow the car warranty or something? Does VW would be able to tell if the car has been scanned with the VCDS?
Sent from my Mi Note 10 Pro using Tapatalk
Thank you very much exantas!
We have assumed that it is a good color so as not to worry excessively about its exterior cleaning, once every two weeks with water pressure jets or depending on the weather conditions, ... because it will be used by several members of the family and you already know who will have to worry about said cleaning ...
Yes, it is possible to know all the times that a VW Group car has been scanned/monitoring by the OBD2 port. With VAS, VCDS, etc. In no case does this circumstance affect the car warrantee.
Nowadays, any car repair shop, MOT (ITV, TUV, etc), pertinent authorities, or even the owner must be able to access the vehicle information without any contractual restriction of the warrantee. In fact, VOLKSWAGEN AG, and through the erWin portal, offers its servers for car repair (and more ...) to private owners.
Not loving VW is sometimes hard.
My motto about the warrantee is not to use it, it is the last option for me, only for extreme problems... hmm... well, each one personally has their own concept about what is an extreme problem for him...
Hahahaha, cool Fernando!
I like it
“The flying Dutch”
I wish you you don't ever need to use warranty of courseciclo wrote:Thank you very much exantas!
Nowadays, any car repair shop, MOT (ITV, TUV, etc), pertinent authorities, or even the owner must be able to access the vehicle information without any contractual restriction of the warrantee. In fact, VOLKSWAGEN AG, and through the erWin portal, offers its servers for car repair (and more ...[emoji7]) to private owners.
My motto about the warrantee is not to use it, it is the last option for me, only for extreme problems... hmm... well, each one personally has their own concept about what is an extreme problem for him... [emoji38]
