Polo 6r 2012 - left hand drive
RicardoSoares
Post by RicardoSoares »
Sorry for the english...
This morning, when i press break pedal yellow bulb appears in dashboard and dont have any of the three break lights. Só i turn off the car, turn on and the bulb disapears, if i dont break, the bulb dont appear, if press the break pedal appears again. Right now try again and bulb always on even if i turn off and turn on.
I change the bulbs from left and right break Light but same syntoms. Cant change third break Light.
Its possible to be break Light switch? Where it is located?
Thanks.
Re: Polo 6r 2012 - left hand drive
Your car possibly has a failed brake switch, it is mounted on the brake master cylinder and is a Hall effect device.
If that switch has not failed, your problem could be a wiring problem, for instance a bolt on one of the main front > rear body stiffeners, is too long and has pierced some wiring.
This failure has been reported on many Polo/Ibiza/Fabia motorist's forums but most people do not return to the forums and explain exactly what was done to fix it - sorry.
To be honest, if you are not too happy looking into this sort of problem, it might be cheaper to get a garage to sort it out.
Plugging it into diagnostics will tell you if its a fault brake switch or something else.
RicardoSoares
Thanks for the help.
The problem was a bad cable at trunk door hinge.
Best regards.
