Needle Sweep Activation + Illumination [9N 2004]
FL37TM
Drives: 9N
Post by FL37TM »
Hello,
I need your help to confirm or not if it is possible to activate Needle Sweep + Illumination on the cluster of my Polo 9N 12v 2004 (see attachement) ? i mean the
cluster support this option or not ?
In case of YES, i think it can be done through eeprom update (can't do it via VCDS, option not available).
Please Advice, Many thanks
Bst Rgrds
littlepolo
Re: Needle Sweep Activation + Illumination [9N 2004]
Post by littlepolo »
Not sure about this. I'd guess an EEEPROM update will be rather expensive just to get a needle sweep. BTW that's a low mileage for the year.
