Hi everyone
I've had this noise that I just can't seem to locate. It is only present when accelerating around low RPMs. The sound is not noticed when idling, though it can be heard very slightly when reving in P. The noise seems to be coming from the chain/belt side but very hard to pin point. Even driving on a hoist is very difficult to hear as there's no load on the wheels. I have scoured all the forums but no one seems to have the same issue or no actual findings for this. Video attached below recorded why driving.
Car is 2013 Polo 6R GTI.
I have checked/changed/tried the following already with no success:
all fuel lines/heatshields/brackets. nothing loose around and no noise on idle makes me believe it isn't any of those.
Have had the clutch and DMF replaced so can't be a dmf rattle.
have replaced the timing chain and tensioner
replaced waterpump
checked wastegate and its fine.
removed and cleaned sump and oil pick up
https://vimeo.com/457967143
Anyone know what it could be ?
Tapping/Rattling noise when accelerating
- Drives: 2016 GTI (6r)
Re: Tapping/Rattling noise when accelerating
The tensioner for the timing belt, or the waterpump. Maybe ya got a faulty bit.
Get someone to make the noise and use a tube like a hose to listen see if you can pin point more.
Definitely not anything to do with the drive belt as i've tested by replicating the sound without the drive belt on. Seems to be coming from the Oil pump/oil pick up area. Have just replaced the timing chain and tensioner + oil chain pump tensioner. Sound is still there. Next up oil pump itself..
- Drives: 6R 1.2TDI 75hp
My dad has an old passat and one time an injector broke and every time I would accelerate a tapping like sound started. The higher the revs the faster the sounds were.
IDK if this can happen with the 6R's injectors.
SO the sound doesn't go away once accelerating faster ? Mines only there at low rpm, so between idle-1100 rpm when at a stand still, or around 2000rpm when moving. no or very low noise otherwise. Have changed everything I can think off now and it's still there.mirceaculita wrote: ↑Thu Oct 01, 2020 7:48 am My dad has an old passat and one time an injector broke and every time I would accelerate a tapping like sound started. The higher the revs the faster the sounds were.
I think the best route now is for you to record a clip of the car making that sound and linking it here.mengseav wrote: ↑Fri Oct 02, 2020 2:02 am
- Jay-Jay
- Drives: Polo 6R HL 1.2TSI 77kw, Audi S1 MY2018
It could be the variable valve timing pulley.
clip is posted in the main post ^mirceaculita wrote: ↑Fri Oct 02, 2020 7:31 amI think the best route now is for you to record a clip of the car making that sound and linking it here.mengseav wrote: ↑Fri Oct 02, 2020 2:02 am
- amer6R
Main bearing/ crank shaft bearing
